标题: 给大家来个步进电机的程序 [打印本页]
作者: 这个人    时间: 2017-9-21 18:01
标题: 给大家来个步进电机的程序
#include "keyboard.h"
unsigned char keySta[] = {1,1,1,1,1,1,1};//按键状态
unsigned int keyTime[] = {0,0};
unsigned char keyCnt[] = {0,0};
extern void CheckKey(unsigned char key);
void ScanKey()
        static unsigned char keyBuff[] = {0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F};//保存按键状态
        unsigned char i;
        keyBuff[0] = (keyBuff[0] << 1)|Key0;//读取按键状态
        keyBuff[1] = (keyBuff[1] << 1)|Key1;//读取按键状态
        keyBuff[2] = (keyBuff[2] << 1)|Key2;//读取按键状态
        keyBuff[3] = (keyBuff[3] << 1)|Key3;//读取按键状态
        keyBuff[4] = (keyBuff[4] << 1)|Key4;//读取按键状态
        keyBuff[5] = (keyBuff[5] << 1)|Key5;//读取按键状态
        keyBuff[6] = (keyBuff[6] << 1)|Key6;//读取按键状态
        for(i = 0;i < 7;i++)
                if((keyBuff[i]&0x0F) == 0x0F)//判断按键是不是弹起
                        keySta[i] = 1;
                        if(i == 2)
                                keyCnt[0] = 0;
                                keyTime[0] = 0;
                        else if(i == 3)
                                keyCnt[1] = 0;
                                keyTime[1] = 0;
                else if((keyBuff[i]&0x0F) == 0x00)//判断按键是不是按下
                        keySta[i] = 0;
                        if(i == 2)
                                keyCnt[0]++;
                                if(keyCnt[0] >= 200)
                                        keyCnt[0] = 0;
                                        keyTime[0]++;//为长按键输入加
                        else if(i == 3)
                                keyCnt[1]++;
                                if(keyCnt[1] >= 200)
                                        keyCnt[1] = 0;
                                        keyTime[1]++;//为长按键输入减
void KeyDrive()
        static unsigned char keyBack[] = {1,1,1,1,1,1,1};//保存更改后的按键
        static unsigned int keyTim[] = {3,3};//第一次大于600毫秒才长按输入,以后每200毫秒输入一次
        unsigned char i;
                if((keyBack[i] != keySta[i]))//如果按键状态更改
                        if(keySta[i] == 0)//如果是按下了某个按键
                                CheckKey(i);
                        keyBack[i] = keySta[i];
        if(keyTime[0] > 0)//长按加
                if(keyTime[0] > keyTim[0])
                        CheckKey(2);
                        keyTim[0]++;
                keyTim[0] = 3;
        if(keyTime[1] > 0)//长按减
                if(keyTime[1] > keyTim[1])
                        CheckKey(3);
                        keyTim[1]++;
                keyTim[1] = 3;
