标题: 6个16*16点阵(12字符)广告牌仿真和源代码 交替闪烁效果 [打印本页]
作者: liu1308117580    时间: 2017-11-8 11:34
设计12字符点阵LED,能显示中文字符,并交替闪烁。
  1. #include<AT89X52.H>
  2. sbit ST=P3^5;
  3. sbit E1=P3^4;
  4. sbit MR=P3^7;
  5. char cashe[12];
  6. char code wd[12][16]={
  7. {0xFE,0xFE,0xFE,0xFE,0xFE,0xDE,0xDE,0xDE,0xDE,0xDE,0xDE,0xDE,0xDE,0x80,0xDF,0xFF},
  8. {0xFF,0xFF,0xFF,0xFF,0xFF,0xFB,0xFB,0xFB,0xFB,0xFB,0xFB,0xFB,0xFB,0x03,0xFB,0xFF},/*"山",0*/
  9. {0xFD,0xFD,0x80,0xFB,0xF7,0xF7,0xEF,0xE0,0xFF,0xF7,0xF3,0xE7,0xEF,0xDD,0xFE,0xFF},
  10. {0xFF,0xFF,0x03,0xFF,0x7F,0x7F,0x7F,0x07,0x7F,0x5F,0x6F,0x77,0x73,0x7B,0x7F,0x7F},/*"东",1*/
  11. …………限于本文篇幅 余下代码请从51黑下载附件…………
  12. {0xFF,0xFF,0xFF,0xFF,0xFF,0x01,0xFF,0x7F,0x7F,0xBF,0xBF,0xDF,0xEF,0xE7,0xF1,0xFB},/*"大",4*/
  13. {0xFE,0xEF,0xF3,0xF7,0x80,0xBF,0x70,0xFF,0xFF,0x80,0xFF,0xFF,0xFF,0xFF,0xFD,0xFE},
  14. {0xF7,0x73,0x37,0x6F,0x01,0xFB,0x17,0xBF,0x7F,0x01,0x7F,0x7F,0x7F,0x7F,0x7F,0xFF},/*"学",5*/
  15. };
  16. void del(int i)//============================//延时程序
  17. {while(i--);}
  18. aline()        ////=======================发送一行的显示程序
  19. {
  20. char i=0;
  21. TI=0;
  22. for(i=0;i<12;i++)
  23. {SBUF=cashe[i];while(~TI);TI=0;} //将缓存中的信息转存入595的存储器中,到此不显示
  24. }
  25. main()
  26. {
  27. int m=0,n=0;
  28.         TI=0;
  29.         SM0=0;
  30.         SM1=0;
  31. E1=0;
  32. while(1)
  33. for(m=0;m<16;m++)      //共有16行  循环16次显示这16行  串行的595送出行的数据
  34.         {                                        //由74hc154选中要显示的行
  35.         for(n=0;n<12;n++)         //这个for循环用来向缓存数组中装载要显示的内容
  36.                 {cashe[11-n]=wd[n][m];}  //将第m个字的第n行信息装载  ,因为595串接 数据第一个进去的会在最后一个595中,最后进去的会在第一个595中
  37.     aline();     //将缓存中的一行信息载入595缓存中
  38.         ST=0;ST=1; //595产生上升沿 输出595锁存的数据
  39.         P2=m;  //选中要显示的行输出数据
  40.
  41.         del(100);//延时一段时间,以造成视觉暂存效应
  42.           }
  43. }
16_16(12)点阵LED.rar (99.75 KB, 下载次数: 56)
作者: tiny44    时间: 2018-1-24 23:49
能滚动吗?
