标题: 求助!各位大神帮我看看哪里错误 [打印本页]
作者: hhch86    时间: 2017-11-8 12:02
标题: 求助!各位大神帮我看看哪里错误
错误提示如下:
程序如下:
//#include "NUC505Series.h"
//#include "PressureSensor.h"
//#define PSESNOR_ADDR 0x6D
volatile uint8_t i2c1_read = 0;
volatile uint8_t i2c1_addr = 0;
volatile uint8_t i2c1_reg = 0;
volatile uint8_t i2c1_data;
volatile uint8_t i2c1_done = 0;
uint8_t gpu8Pressure[5] = {0};
void I2C1_IRQHandler(void)
    uint32_t u32Status;
    u32Status = I2C_GET_STATUS(I2C1);
    if (I2C_GET_TIMEOUT_FLAG(I2C1))
        I2C_ClearTimeoutFlag(I2C1);
        if (i2c1_read)
         switch (u32Status)
case 0x08:
//Write SLA+W to Register I2CDAT
I2C_SET_DATA(I2C1, (i2c1_addr << 1));
I2C_SET_CONTROL_REG(I2C1, I2C_SI);
break;
case 0x18:
//SLA+W has been transmitted and ACK has been received
I2C_SET_DATA(I2C1, i2c1_reg);
break;
case 0x20:
//SLA+W has been transmitted and NACK has been received
I2C_SET_CONTROL_REG(I2C1, I2C_STA | I2C_STO | I2C_SI);
break;
case 0x28:
I2C_SET_CONTROL_REG(I2C1, I2C_STA | I2C_SI);
break;
case 0x10:
//Repeat START has been transmitted and prepare SLA+R
I2C_SET_DATA(I2C1, (i2c1_addr << 1) | 0x01);  //Write SLA+R to Register I2CDAT
break;
case 0x40:
//SLA+R has been transmitted and ACK has been received
break;
case 0x58:
//DATA has been received and NACK has been returned
i2c1_data = I2C_GET_DATA(I2C1);
I2C_SET_CONTROL_REG(I2C1, I2C_STO | I2C_SI);
i2c1_done = 1;
break;
         switch (u32Status)
case 0x08: //START has been transmitted and prepare SLA+W
I2C_SET_DATA(I2C1, (i2c1_addr << 1)); //Write SLA+W to Register I2CDAT
break;
case 0x18: // SLA+R has been transmitted and ACK has been received
break;
case 20:
break;
case 0x28: //DATA has been received and NACK has been returned
I2C_SET_DATA(I2C1, i2c1_data);
i2c1_done = 1;
break;
void I2C1_Read(uint8_t u8Addr, uint8_t u8RegAddr, uint8_t *pu8RetValue)
    i2c1_done = 0;
    i2c1_read = 1;
    i2c1_addr = u8Addr;
    i2c1_reg = u8RegAddr;
    I2C_SET_CONTROL_REG(I2C1, I2C_STA);
    while (!i2c1_done);
    *pu8RetValue = i2c1_data;
void I2C1_Write(uint8_t u8Addr, uint8_t u8RegAddr, uint8_t u8Value)
    i2c1_done = 0;
    i2c1_read = 0;
    i2c1_addr = u8Addr;
    i2c1_data = u8Value;
    while (!i2c1_done);
void Sample()
   I2C1_Write(PSESNOR_ADDR, 0x30, 0x0A);
   I2C1_Read(PSESNOR_ADDR, 0x30, &gpu8Pressure[0]);
   I2C1_Read(PSESNOR_ADDR, 0x06, &gpu8Pressure[0]);
   I2C1_Read(PSESNOR_ADDR, 0x07, &gpu8Pressure[1]);
   I2C1_Read(PSESNOR_ADDR, 0x08, &gpu8Pressure[2]);
   I2C1_Read(PSESNOR_ADDR, 0x09, &gpu8Pressure[3]);
   I2C1_Read(PSESNOR_ADDR, 0x0A, &gpu8Pressure[4]);
void TMR2_IRQHandler(void)
    // clear timer interrupt flag
    TIMER_ClearIntFlag(TIMER2);
    //Sample();
    TIMER_GetIntFlag(TIMER2);
void PressureSensor_Init(void)
uint8_t u8A5 = 0;
I2C_Open(I2C1, 400000);
I2C_EnableInt(I2C1);
NVIC_EnableIRQ(I2C1_IRQn);
I2C1_Read(PSESNOR_ADDR, 0xA5, &u8A5);
u8A5 &= 0xFD;
I2C1_Write(PSESNOR_ADDR, 0xA5, u8A5);
    while (1)
        Sample();
        msDelay(100);
TIMER_Open(TIMER2, TIMER_PERIODIC_MODE, 10);
    TIMER_EnableInt(TIMER2);
    NVIC_EnableIRQ(TMR2_IRQn);
    TIMER_Start(TIMER2);
作者: zl2168    时间: 2017-11-9 19:31
为什么这么长时间没人回帖?冗长程序没人看,特别是没有注解的。你想啊!别人有那么多时间吗?
作者: 1848654500    时间: 2017-11-9 20:32
没注解不好看
作者: 850128cat    时间: 2017-11-9 23:03
路过学习一下
作者: zl2168    时间: 2017-11-10 12:13
850128cat 发表于 2017-11-9 23:03
路过学习一下
你怎么“学习一下”?请谈谈体会。
作者: ktoto2011    时间: 2017-11-10 13:56
提示在XG....c文件的第四行在i2c1_read缺一个分号,可以检查下这个位置是不是中英切换出现的问题。也可以看看XG....h头文件在定义时定义错误
作者: 天0    时间: 2017-11-10 14:43
确认一下void I2C1_Read函数上面是不是多了一个}
作者: 以电会友    时间: 2017-11-10 14:47
同意这个方法
作者: hhch86    时间: 2017-11-12 17:20
谢谢各位大神的回复,这段程序是压力传感器厂家提供的测试程序。由于看不懂C,想用Keil uVision5编译后,修改为汇编程序。现在编译错误,无法进行下一步。
本人用汇编写过一些小项目,也正在学习C。
作者: hhch86    时间: 2017-11-12 17:29
谢谢您的回复,我也是抱着试试看的心态,希望能解决。这段程序是传感器厂家提供的测试程序。
作者: summer_xqx    时间: 2017-11-12 20:07
一般注释是可以用颜色区分的,这么长有点看不懂了,你可以把一些无关紧要的语句删掉,这样看起来省力点
作者: bioger    时间: 2017-11-12 22:32
上一行 少一个分号  应该是
作者: 15505185161    时间: 2017-11-13 14:02
你把if (i2c1_read)改成if (2c1_read==0)试试
作者: lilingzhi1987    时间: 2017-11-13 17:55
坐等。。。。。。。。。。。。。。
作者: hpfhpf    时间: 2017-11-13 18:59
路过学习一下
作者: ox3in1    时间: 2017-11-13 21:10
第三十七行有多打東西
