标题: LM1084引脚图+电路与英文资料 [打印本页]
作者: Rolicecate    时间: 2017-11-22 11:06
LM1084的英文介绍
The LM1084 is a regulator with a maximum dropout of 1.5 V at 5 A of load current. The device has the
same pinout as TI's industry standard LM317.
Two resistors are required to set the output voltage of the adjustable output voltage version of the LM1084.
Fixed output voltage versions integrate the adjust resistors.
The LM1084 circuit includes a zener trimmed
bandgap reference, current limiting, and thermal shutdown.
Refer to LM1085 for the 3A version, and the LM1086 for the 1.5A version.
LM1084引脚图:
LM1084管脚功能介绍:
LM1084应用电路:
完整的pdf格式文档51黑下载地址:
lm1084.pdf (2.12 MB, 下载次数: 31)
作者: kevind    时间: 2020-5-8 22:41
这个器件最大输入电压多少?
