分享关于单片机的I2C总线代码
周鑫鑫鑫666
2017-11-24 13:21
分享关于单片机的I2C总线代码
#include<reg52.h>
sbit sda=P2^0;
sbit scl=P2^1;
uchar a;
void delay()
void start() //开始信号
sda=1;
delay();
scl=1;
delay();
sda=0;
delay();
void stop() //停止
sda=0;
delay();
scl=1;
delay();
sda=1;
delay();
void respons() //应答
uchar i;
scl=1;
delay();
while((sda==1)&&(i<250))i++;
scl=0;
delay();
void init()
sda=1;
delay();
scl=1;
delay();
void write_byte(uchar date)
uchar i,temp;
temp=date;
for(i=0;i<8;i++)
temp=temp<<1;
scl=0;
delay();
sda=CY;
delay();
scl=1;
delay();
// scl=0;
// delay();
scl=0;
delay();
sda=1;
delay();
uchar read_byte()
uchar i,k;
scl=0;
delay();
sda=1;
delay();
for(i=0;i<8;i++)
scl=1;
delay();
k=(k<<1)|sda;
scl=0;
delay();
return k;
void delay1(uchar x)
uchar a,b;
for(a=x;a>0;a--)
for(b=100;b>0;b--);
void write_add(uchar address,uchar date)
start();
write_byte(0xa0);
respons();
write_byte(address);
respons();
write_byte(date);
respons();
stop();
uchar read_add(uchar address)
uchar date;
start();
write_byte(0xa0);
respons();
respons();
start();
write_byte(0xa1);
respons();
date=read_byte();
stop();
return date;
init();
write_add(23,0xaa);
delay1(100);
P1=read_add(23);
while(1);
