1602字符液晶自动水平和垂直滚动演示程序加仿真
panpanpan
2017-11-27 21:27
在单片机的控制下能实现自动水平滚动与自动垂直滚动,并且带有暂停开始按钮
(19.18 KB, 下载次数: 44)
下载附件
2017-11-28 01:09 上传
(42.33 KB, 下载次数: 50)
下载附件
2017-11-28 01:09 上传
/*************** writer:shopping.w ******************/
#include <reg52.h>
#include <string.h>
void Initialize_LCD();
void ShowString(uchar,uchar,uchar *);
sbit K1 = P3^0;
sbit K2 = P3^1;
sbit K3 = P3^2;
uchar code Prompt[]="PRESS K1--K4 TO START DEMO PROG";
uchar const Line_Count = 6;
uchar code Msg[][80]=
"Many CAD users dismiss",
"process of creating PCB",
"of view.with PCB layout",
"placement and track routing,",
"can often be the most time",
"And if you use circuit simulation",
"you are going to spend even more"
uchar Disp_Buffer[32];
void Delayxms(uint ms)
uchar i;
while(ms--)
for(i=0;i<120;i++);
void V_Scroll_Display()
uchar i,j,k = 0;
uchar *p = Msg[0];
uchar *q = Msg[Line_Count] + strlen(Msg[Line_Count]);
while(p<q)
for(i=0;(i<16)&&(p<q);i++)
if(((i==0)||(i==15))&& *p == ' ')
p++;
if(*p != '\0')
Disp_Buffer[i] = *p++;
if(++k>Line_Count)
break;
p = Msg[k];
for(j=i;j<16;j++)
Disp_Buffer[j]=' ';
while(F0)
Delayxms(5);
ShowString(0,0," ");
Delayxms(150);
while(F0)
Delayxms(5);
ShowString(0,1,Disp_Buffer);
Delayxms(150);
while(F0)
Delayxms(5);
ShowString(0,0,Disp_Buffer);
ShowString(0,1," ");
Delayxms(150);
void H_Scroll_Display()
uchar m,n,t = 0,L=0;
uchar *p = Msg[0];
for(m=0;m<16;m++)
Disp_Buffer[m]=' ';
while(p<q)
if((m=16||m==31)&& *p == ' ')
p++;
for(m=16;m<32&&p<q;m++)
if(*p != '\0')
Disp_Buffer[m] = *p++;
if(++t>Line_Count)
break;
p = Msg[t];
for(n=m;n<32;n++)
Disp_Buffer[n]=' ';
for(m=0;m<=16;m++)
while(F0)
Delayxms(5);
ShowString(0,L,Disp_Buffer+1);
while(F0)
Delayxms(5);
Delayxms(20);
L = (L==0)? 1:0;
Delayxms(200);
if(L==1)
void EX_INT0() interrupt 0
F0 = !F0;
uint Count = 0;
IE = 0x81;
IT0 = 1;
…………限于本文篇幅 余下代码请从51黑下载附件…………
60 1602字符液晶滚动演示程序.zip
(63.09 KB, 下载次数: 33)
2017-11-27 21:27 上传
点击文件名下载附件
下载积分: 黑币 -5
15160308129
2019-5-4 19:02
很好,解决了我很大问题
