查看: 1717|回复: 1
STC15W204S单片机控制RGB灯程序,push调光
ID:406986 发表于 2021-12-1 17:17 | 显示全部楼层 回帖奖励 |倒序浏览 |阅读模式
#include "PWM.h"
#include "LED.h"
volatile uint16_t PWM_Timing = 0;
volatile uint8_t PWM_Dutycycle = 100;
volatile uint8_t dutycycle = 0;
void Colour_RGBW(uint8_t RGBW, uint8_t Duty)
    uint16_t DutyTiming = 0;
    if (Duty > MaxDutycycle)
        return;
    if (0 == Duty)
        LightStatus = OFF;
        PWM1 = 0;
        PWM2 = 0;
        PWM3 = 0;
        return;
        LightStatus = ON;
    if (PWM_Timing <= Duty)
        switch (RGBW)
            case 'R':            PWM1 = 1;       PWM2 = 0;       PWM3 = 0;            break;
            case 'G':            PWM1 = 0;       PWM2 = 1;       PWM3 = 0;            break;
            case 'B':            PWM1 = 0;       PWM2 = 0;       PWM3 = 1;            break;
            case 'W':            PWM1 = 1;       PWM2 = 1;       PWM3 = 1;            break;
            default:
                break;
        PWM1 = 0;
        PWM2 = 0;
        PWM3 = 0;
Keil代码下载: Dimming.zip (66.48 KB, 下载次数: 50)
收藏收藏1 分享淘帖 顶1 踩
