本程序为带CRC校验的单片机串口收发例程,CRC校验为查表法,实验单片机型号为STC12C5A32S2。例程中加入了包头和包尾作为初步校验,但包头包尾均不参加CRC计算。
例程数据包格式如下:
发送:EF FE data1data2 data3 crcL crcH FD EA 包头 数据位1-3 CRC校验位 包尾 接收:EF FE data1data2 data3 data4 data5 data6 data7 crcL crcH FDEA 包头 数据位1-7 CRC校验位 包尾
(注:包头包尾不参与CRC计算,仅数据位进行CRC校验)
- 以下为部分代码(源程序及工具在附录):
- /******CRC 高位字节值表******/
- uchar8 code auchCRCHi[256] =
- 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0,
- 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
- 0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0,
- 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
- 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1,
- 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41,
- 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
- 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40,
- 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1,
- 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
- 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0,
- /******CRC低位字节值表******/
- uchar8 code auchCRCLo[256] =
- 0x00, 0xC0, 0xC1, 0x01, 0xC3, 0x03, 0x02, 0xC2, 0xC6, 0x06,
- 0x07, 0xC7, 0x05, 0xC5, 0xC4, 0x04, 0xCC, 0x0C, 0x0D, 0xCD,
- 0x0F, 0xCF, 0xCE, 0x0E, 0x0A, 0xCA, 0xCB, 0x0B, 0xC9, 0x09,
- 0x08, 0xC8, 0xD8, 0x18, 0x19, 0xD9, 0x1B, 0xDB, 0xDA, 0x1A,
- 0x1E, 0xDE, 0xDF, 0x1F, 0xDD, 0x1D, 0x1C, 0xDC, 0x14, 0xD4,
- 0xD5, 0x15, 0xD7, 0x17, 0x16, 0xD6, 0xD2, 0x12, 0x13, 0xD3,
- 0x11, 0xD1, 0xD0, 0x10, 0xF0, 0x30, 0x31, 0xF1, 0x33, 0xF3,
- 0xF2, 0x32, 0x36, 0xF6, 0xF7, 0x37, 0xF5, 0x35, 0x34, 0xF4,
- 0x3C, 0xFC, 0xFD, 0x3D, 0xFF, 0x3F, 0x3E, 0xFE, 0xFA, 0x3A,
- 0x3B, 0xFB, 0x39, 0xF9, 0xF8, 0x38, 0x28, 0xE8, 0xE9, 0x29,
- 0xEB, 0x2B, 0x2A, 0xEA, 0xEE, 0x2E, 0x2F, 0xEF, 0x2D, 0xED,
- 0xEC, 0x2C, 0xE4, 0x24, 0x25, 0xE5, 0x27, 0xE7, 0xE6, 0x26,
- 0x22, 0xE2, 0xE3, 0x23, 0xE1, 0x21, 0x20, 0xE0, 0xA0, 0x60,
- 0x61, 0xA1, 0x63, 0xA3, 0xA2, 0x62, 0x66, 0xA6, 0xA7, 0x67,
- 0xA5, 0x65, 0x64, 0xA4, 0x6C, 0xAC, 0xAD, 0x6D, 0xAF, 0x6F,
- 0x6E, 0xAE, 0xAA, 0x6A, 0x6B, 0xAB, 0x69, 0xA9, 0xA8, 0x68,
- 0x78, 0xB8, 0xB9, 0x79, 0xBB, 0x7B, 0x7A, 0xBA, 0xBE, 0x7E,
- 0x7F, 0xBF, 0x7D, 0xBD, 0xBC, 0x7C, 0xB4, 0x74, 0x75, 0xB5,
- 0x77, 0xB7, 0xB6, 0x76, 0x72, 0xB2, 0xB3, 0x73, 0xB1, 0x71,
- 0x70, 0xB0, 0x50, 0x90, 0x91, 0x51, 0x93, 0x53, 0x52, 0x92,
- 0x96, 0x56, 0x57, 0x97, 0x55, 0x95, 0x94, 0x54, 0x9C, 0x5C,
- 0x5D, 0x9D, 0x5F, 0x9F, 0x9E, 0x5E, 0x5A, 0x9A, 0x9B, 0x5B,
- 0x99, 0x59, 0x58, 0x98, 0x88, 0x48, 0x49, 0x89, 0x4B, 0x8B,
- 0x8A, 0x4A, 0x4E, 0x8E, 0x8F, 0x4F, 0x8D, 0x4D, 0x4C, 0x8C,
- 0x44, 0x84, 0x85, 0x45, 0x87, 0x47, 0x46, 0x86, 0x82, 0x42,
- 0x43, 0x83, 0x41, 0x81, 0x80, 0x40
- void Uart1_Init( )
- PCON &= 0x7F; //波特率不倍速
- SCON = 0x50; //8位数据,可变波特率
- AUXR &= 0xBF; //定时器1时钟为Fosc/12,即12T
- AUXR &= 0xFE; //串口1选择定时器1为波特率发生器
- TMOD &= 0x0F; //清除定时器1模式位
- TMOD |= 0x20; //设定定时器1为8位自动重装方式
- TL1 = 0xFD; //设定定时初值
- TH1 = 0xFD; //设定定时器重装值
- ET1 = 0; //禁止定时器1中断
- TR1 = 1; //启动定时器1
- ES=1;
- EX0=1; //开外部中断0
- IT0=1; //负跳变触发
- EA=1;
- void UART1_Routine(void) interrupt 4
- uchar8 i;
- if(RI)
- i = SBUF;
- RI = 0;
- if(Rx_stop_flag == 0)
- if(Rx_start_flag)
- Rx_BUF[Rx_count] = i;
- if((Rx_count > 4) && (Rx_BUF[Rx_count - 1] == 0xfd) && (Rx_BUF[Rx_count] == 0xea))//判断包尾(0xfd, 0xea)同时判断是否有数据(包头包尾占4个)
- Rx_stop_flag = 1;
- Rx_start_flag = 0;
- Rx_count ++;
- if(!Rx_start_flag && (i == 0xef))//判断第一个包头0xef
- Rx_start_flag = 1;
- Rx_count = 0;
复制代码 全部资料51hei下载地址:
CRC串口程序.zip
(554.02 KB, 下载次数: 119)
