烟雾,光敏亮度,火焰等传感器数据的采集,上位机实现窗帘的开关
C#源程序如下:- using System;
- using System.Collections.Generic;
- using System.ComponentModel;
- using System.Data;
- using System.Drawing;
- using System.Linq;
- using System.Text;
- using System.Threading.Tasks;
- using System.Windows.Forms;
- using System.IO.Ports;
- namespace smartLed
- public partial class FormMain : Form
- private SerialPort sp = new SerialPort(); //串口类
- private bool isOpen = false; //打开串口的标志位
- private bool usart_closing = false; //是否正在关闭串口
- private bool usart_listening = false; //监听是否在执行串口
- private List<byte> buffer = new List<byte>(4096); //分配1页内存
- private long SendCount = 0;
- private long ReceiveCount = 0;
- //串口窗体初始化
- private void SerialSettingInit()
- for (int i = 0; i < 32; i++)
- cboxCOM.Items.Add("COM" + (i + 1).ToString());
- cboxCOM.SelectedIndex = 0;
- //列出波特率
- cboxBaudRate.Items.Add("1200");
- cboxBaudRate.Items.Add("2400");
- cboxBaudRate.Items.Add("4800");
- cboxBaudRate.Items.Add("9600");
- cboxBaudRate.Items.Add("19200");
- cboxBaudRate.Items.Add("38400");
- cboxBaudRate.Items.Add("43000");
- cboxBaudRate.Items.Add("56000");
- cboxBaudRate.Items.Add("57600");
- cboxBaudRate.Items.Add("115200");
- cboxBaudRate.SelectedIndex = 9;
- //列出停止位
- cboxStopBits.Items.Add("0");
- cboxStopBits.Items.Add("1");
- cboxStopBits.Items.Add("1.5");
- cboxStopBits.Items.Add("2");
- cboxStopBits.SelectedIndex = 1;
- //列出数据位
- cboxDataBits.Items.Add("8");
- cboxDataBits.Items.Add("7");
- cboxDataBits.Items.Add("6");
- cboxDataBits.Items.Add("5");
- cboxDataBits.SelectedIndex = 0;
- //列出奇偶校验位
- cboxParity.Items.Add("无");
- cboxParity.Items.Add("奇校验");
- cboxParity.Items.Add("偶校验");
- cboxParity.SelectedIndex = 0;
- countClear();
- //检测可用串口
- private void buttonCheck_Click(object sender, EventArgs e)
- bool comExistence = false; //有可用串口标志位
- cboxCOM.Items.Clear(); //清除串口号中所有串口
- try
- SerialPort sp = new SerialPort("COM" + (i + 1).ToString());
- sp.Open();
- sp.Close();
- comExistence = true;
- catch (Exception)
- continue;
- if (comExistence)
- cboxCOM.SelectedIndex = 0; //使ListBox显示
- else
- MessageBox.Show("没有找到可用串口!", "错误提示");
- //检测串口设置
- private bool CheckPortSetting()
- if (cboxCOM.Text.Trim() == "") return false;
- if (cboxBaudRate.Text.Trim() == "") return false;
- if (cboxDataBits.Text.Trim() == "") return false;
- if (cboxParity.Text.Trim() == "") return false;
- if (cboxStopBits.Text.Trim() == "") return false;
- return true;
- //开启串口按键响应
- private void buttonOpen_Click(object sender, EventArgs e)
- if (isOpen == false)
- if (CheckPortSetting())
- sp.PortName = cboxCOM.Text.Trim();//设置串口名
- sp.BaudRate = Convert.ToInt32(cboxBaudRate.Text.Trim());//设置串口的波特率
- float f = Convert.ToSingle(cboxStopBits.Text.Trim());//设置停止位
- if (f == 0)
- sp.StopBits = StopBits.None;
- else if (f == 1.5)
- sp.StopBits = StopBits.OnePointFive;
- else if (f == 1)
- sp.StopBits = StopBits.One;
- else if (f == 2)
- sp.StopBits = StopBits.Two;
- else
- sp.DataBits = Convert.ToInt16(cboxDataBits.Text.Trim());//设置数据位
- string s = cboxParity.Text.Trim(); //设置奇偶校验位
- if (s.CompareTo("无") == 0)
- sp.Parity = Parity.None;
- else if (s.CompareTo("奇校验") == 0)
- sp.Parity = Parity.Odd;
- else if (s.CompareTo("偶校验") == 0)
- sp.Parity = Parity.Even;
- else
- else
- return;
- //设置超时读取时间
- sp.ReadTimeout = -1;
- sp.RtsEnable = true;
- //定义DataReceived 事件,当串口收到数据后触发事件
- sp.DataReceived -= new SerialDataReceivedEventHandler(sp_DataReceived);
- sp.DataReceived += new SerialDataReceivedEventHandler(sp_DataReceived);
- try//打开串口
- sp.Open();
- isOpen = true;
- buttonOpen.Text = "关闭串口";
- //串口打开后则相关的串口设置按钮便不可再用
- cboxCOM.Enabled = false;
- cboxBaudRate.Enabled = false;
- cboxStopBits.Enabled = false;
- cboxDataBits.Enabled = false;
- cboxParity.Enabled = false;
- buttonCheck.Enabled = false;
- catch (Exception)
- //打开串口失败后,相应标志位取消
- isOpen = false;
- MessageBox.Show("串口无效或已被占用!", "错误提示");
- else
- try//关闭串口
- usart_closing = true;//告诉Invoke串口正在关闭
- while (usart_listening) Application.DoEvents();//等待到Invoke执行完
- sp.Close();
- usart_closing = false;//以上代码旨在防止关闭串口时发生锁死现象
- isOpen = false;
- buttonOpen.Text = "打开串口";
- cboxCOM.Enabled = true;
- cboxBaudRate.Enabled = true;
- cboxStopBits.Enabled = true;
- cboxDataBits.Enabled = true;
- cboxParity.Enabled = true;
- buttonCheck.Enabled = true;
- countClear();
- catch (Exception)
- //打开串口失败后,相应标志位取消
- isOpen = false;
- MessageBox.Show("关闭串口时发生错误!", "错误提示");
- //串口发送字符串
- private void UartSend(String str)
- if (isOpen == true)
- try
- sp.Write(str);
- SendCount += Encoding.Default.GetBytes(str).Length;
- refreshSendCount();
- catch
- PortErrorDeal();
- else
- MessageBox.Show("串口未打开!", "错误提示");
- //发送数组
- private void UartSend(byte[] buf, int len)
- try
- sp.Write(buf, 0, len);
- SendCount += len;
- catch
- PortErrorDeal();
- else
- //发送数组
- private void UartSend(byte[] buf)
- UartSend(buf, buf.Length);
- //串口接收事件
- private void sp_DataReceived(object sender, SerialDataReceivedEventArgs e)
- if (usart_closing)
- return;
- else
- usart_listening = true;
- //this.Invoke跨线程访问ui
- try
- this.Invoke((EventHandler)(delegate
- int Bytes_n = sp.BytesToRead; //避免缓存不一致
- Byte[] ReceivedDatabuf = new Byte[Bytes_n]; //创建接收字节数组
- sp.Read(ReceivedDatabuf, 0, Bytes_n); //读取所接收到的数据
- buffer.AddRange(ReceivedDatabuf); //缓存数据
- ReceiveCount += Bytes_n;
- refreshReceiveCount();
- catch
- PortErrorDeal();
- finally
- usart_listening = false;
- //串口出错处理
- private void PortErrorDeal()
- MessageBox.Show("串口断开或者拔下!", "错误提示");
- try
- sp.Close();
- catch
- isOpen = false;
- //刷新接收计数
- private void refreshReceiveCount()
- labReiveCount.Text = "接收:" + ReceiveCount.ToString();
- //刷新发送计数
- private void refreshSendCount()
- labSendCount.Text = "发送:" + SendCount.ToString();
- //计数值清零
- private void countClear()
- SendCount = 0;
- ReceiveCount = 0;
- //发送数据变化
- private void labSendCount_TextChanged(object sender, EventArgs e)
- //接收数据变化
- private void labReiveCount_TextChanged(object sender, EventArgs e)
- if (ReceiveCount == 0)
- buffer.Clear();
- else
- recevivedData();
- /*@end Serial Base*********************************************/
- /*@start command Base******************************************/
- private string createCommand(string comm, int param)
- return (comm + param.ToString() + "\r\n");
- private string createCommand(string comm, string param)
- return (comm + param + "\r\n");
- private int getCommand(string source, string comm, out int param)
- int commPos = source.IndexOf(comm);
- int endPos = source.IndexOf("\r\n");
- int valueLen = endPos - commPos - comm.Length;
- if (commPos > -1 && endPos > -1 && valueLen > 0)
- string value = source.Substring(endPos - valueLen, valueLen);
- try
- param = int.Parse(value);
- return getFirstEndFlag();
- catch
- param = 0;
- return -1;
- private int getCommand(string source, string comm, out string param)
- param = source.Substring(endPos - valueLen, valueLen);
- param = "";
- return -1;
- private int getFirstEndFlag()
- int i = buffer.IndexOf((byte)'\r');
- int j = buffer.IndexOf((byte)'\n');
- if (i > -1)
- if (j == (i + 1))
- return i;
- else
- buffer.RemoveRange(0, i + 1);
- return -1;
- private void recevivedData()
- if (getFirstEndFlag() > -1)
- analysisData();
- * 作用:解析串口接收过来的数据,根据字符标志位进行数据截取到对应的显示地方
- private void analysisData()
- bool getDataFlag = false;
- {//光敏亮度显示
- string source = System.Text.Encoding.Default.GetString(buffer.ToArray());
- string param;
- int dataLen = getCommand(source, LIGHT, out param);
- if (dataLen > 0)
- label_light.Text = "LIGHT\r\n" + param[1] + param[2] + param[3];
- buffer.RemoveRange(0, dataLen + 2);
- if (param[1] >= '6') //当亮度大于600时,关闭灯光
- for (int i = 0; i < 10; i++)
- UartSend(createCommand(LIGHT, "0"));
- else //否则,灯光一直显示亮起
- UartSend(createCommand(LIGHT, "1"));
- getDataFlag = true;
- {//火焰显示
- string param;
- int dataLen = getCommand(source, FIRE, out param);
- if (dataLen > 0)
- label_fire.Text = "FIRE\r\n" + param[2] + param[3];
- if (param[3] == '1') //当检测到火焰气体 param[3] == '1' 时,发出警报1
- UartSend(createCommand(FIRE, "1"));
- else //此时若没监测火焰气体 param[3] == '0',关闭警报2,也可以在上位机的按钮关掉
- UartSend(createCommand(FIRE, "0"));
- {//烟雾显示
- string param;
- int dataLen = getCommand(source, SMOKE, out param);
- if (dataLen > 0)
- label_smoke.Text = "SMOKE\r\n" + param[2] + param[3];
- {//人体显示
- string param;
- int dataLen = getCommand(source, HUMAN, out param);
- if (dataLen > 0)
- label_human.Text = "HUMAN\r\n" + param[2] + param[3];
- if (param[3] == '1') //当检测到人体 param[3] == '1' 时,发出警报2
- UartSend(createCommand(HUMAN, "1"));
- else //此时若没监测到人体 param[3] == '0',关闭警报2,也可以在上位机的按钮关掉
- UartSend(createCommand(HUMAN, "0"));
- {//PM2.5显示
- string param;
- int dataLen = getCommand(source, PM, out param);
- if (dataLen > 0)
- label_pm.Text = "PM2.5\r\n" + param[2] + param[3];
- {//温度显示
- string param;
- int dataLen = getCommand(source, TEMPERATURE, out param);
- if (dataLen > 0)
- label_temperature.Text = "温度\r\n" + param[0] + param[1] + "°C";
- label_humidity.Text = "湿度\r\n" + param[3] + param[4] + "%";
- //如果还存在结束符
- int endPos = getFirstEndFlag();
- if (endPos > -1)
- if (!getDataFlag)
- buffer.RemoveRange(0, endPos + 2);
- analysisData();
- /*@end command Base********************************************/
- public FormMain()
- InitializeComponent();
- private void FormMain_Load(object sender, EventArgs e)
- SerialSettingInit();
- //gboxSwithSetting.Enabled = false;
- //gboxSwith2Setting.Enabled = false;
- //gboxSwith3Setting.Enabled = false;
- * 作用:定义数据标志位,进而获取对应终端节点的数据
- private const string LIGHT = "L"; //光敏亮度
- private const string HUMAN = "H"; //人体感应
- private const string FIRE = "F"; //火焰
- private const string SMOKE = "S"; //烟雾
- private const string PM = "P"; //PM2.5
- private const string CURTAIN = "C"; //窗帘
- private const string TEMPERATURE = "T"; //温度
- private const string HUMIDITY = "D"; //湿度
- private void txtThreshol_KeyPress(object sender, KeyPressEventArgs e)
- if ((e.KeyChar < 48 || e.KeyChar > 57) && (e.KeyChar != 8))
- e.Handled = true;
- base.OnKeyPress(e);
- * 作用:下发数据命令进行终端节点的控制,“L1”,“L0”,“S1”,“S0”
- private void button1_Click_1(object sender, EventArgs e)
- //关警报2
- private void button2_Click(object sender, EventArgs e)
- private void button3_Click(object sender, EventArgs e)
- //关警报1
- private void button4_Click(object sender, EventArgs e)
- //开风扇
- private void button5_Click(object sender, EventArgs e)
- UartSend(createCommand(SMOKE, "1"));
- //关风扇
- private void button6_Click(object sender, EventArgs e)
- UartSend(createCommand(SMOKE, "0"));
- //开窗帘
- private void button7_Click_1(object sender, EventArgs e)
- UartSend(createCommand(CURTAIN, "1"));
- //关窗帘
- private void button8_Click(object sender, EventArgs e)
- UartSend(createCommand(CURTAIN, "0"));
- //开灯
- private void button9_Click(object sender, EventArgs e)
- //关灯
- private void button10_Click(object sender, EventArgs e)
C#代码下载:
智能家居(上位机).7z
(703.6 KB, 下载次数: 85)
