查看: 2201|回复: 8
萌新求学,c语言逻辑运算
ID:89515 发表于 2018-10-22 10:51 | 显示全部楼层
#include<windows.h>
#include<stdio.h>
#include<stdlib.h>
#include<time.h>
#include<conio.h>
#include<dos.h>
void gotoxy(int x, int y)
         COORD coord;    //定义一个坐标结构变量
         HANDLE hscr;    //定义一个句柄
         coord.X = x;    //给坐标赋值
         coord.Y = y;
         hscr = GetStdHandle(STD_OUTPUT_HANDLE); //获得标准输出句柄(就是显示器)
         SetConsoleCursorPosition(hscr, coord);  //设置控制台光标的到指定坐标
void guess(int n)
        int acount,bcount,i,j,k=0,flag,a[10],b[10];
        do
                flag=0;
                srand((unsigned)time(NULL));//利用系统时钟设定种子
                for(i=0;i<n;i++)
                        a[i]=rand()%10;
                for(i=0;i<n-1;i++)
                        for(j=i+1;j<n;j++)
                                if(a[i]==a[j])
                                        flag=1;
                                        break;
        }while(flag==1);
        do///////////////////////比较函数/////////////////////////////////
                k++;
                acount=0;
                bcount=0;
                gotoxy(25,k+2);
                printf("guess:");
                for(i=0;i<n;i++)
                        scanf("%d",&b[i]);
                for(i=0;i<n;i++)
                        for(j=0;j<n;j++)
                                if(a[i]==b[i])
                                        acount++;
                                        break;
                                if(a[i]==b[j]&&i!=j)
                                        bcount++;
                                        break;
                gotoxy(35,k+2);
                printf("clue on:%dA%dB\n",acount,bcount);
                if(acount==n)//不同猜测次数赢得游戏后的界面
                        if(k==1)
                                        printf("you are the topmost rung of Fortune's ladder!!\n\n");
                        else if(k<=5)
                                        printf("you are genius!!\n\n");
                        else if(k<=10)
                                        printf("you are cleaver!!\n\n");
                                        printf("you need try hard!!\n\n");
                        break;
        }while(1);
        int i,n;
        {//////////////////////////////////开始界面//////////////////////////////////////
                system("cls");//清屏
                gotoxy(30,6);
                printf("1.start game?(y/n)");
                gotoxy(30,8);
                printf("2.Rule");
                gotoxy(30,10);
                printf("please choose:");
                scanf("%d",&i);
                switch(i)
                        case 1:
                                system("cls");
                                printf("please input n:\n");
                                scanf("%d",&n);
                                guess(n);
                                Sleep(2000);
                                break;
                        case 2://游戏规则
                                system("cls");
                                gotoxy(40,6);
                                printf("\n\n\n\t\tThe Rules OF The Game\n");
                                printf("step1:inpur of the number of difits\n");
                                printf("step2:input the number,separated by a apace between two number\n");
                                printf("step3:A represent location and data are correcr\n");
                                printf("      B represent location is correct but data is wrong!\n");
                                Sleep(10000);
                                break;
                        case 3:
                        //        system("exit");
                                return;
                        default:
                                break;
