这个是无字库的12864屏 KS0108驱动
- /* --- STC MCU Limited ------------------------------------------------*/
- /* --- STC 1T Series MCU Demo Programme -------------------------------*/
- /* 如果要在程序中使用此代码,请在程序中注明使用了STC的资料及程序 */
- /************* 本程序功能说明 **************
- 驱动LCD128*64黑白点阵屏.
- 用户可以修改宏来选择时钟频率.
- 显示效果为: 第一行显示模拟的RTC时间, 7、8行显示8个16*16点的汉字. 本程序使用的LCD是有两个片选的.
- 注意: LCD接口的16脚是空脚, 本程序要把这个脚接到P2.2做另一页的片选.
- #include "reg51.h"
- #include "intrins.h"
- #define MAIN_Fosc 11059200L //定义主时钟
- typedef unsigned char u8;
- typedef unsigned int u16;
- typedef unsigned long u32;
- sfr TH2 = 0xD6;
- sfr TL2 = 0xD7;
- sfr IE2 = 0xAF;
- sfr INT_CLKO = 0x8F;
- sfr AUXR = 0x8E;
- sfr AUXR1 = 0xA2;
- sfr P_SW1 = 0xA2;
- sfr P_SW2 = 0xBA;
- sfr S2CON = 0x9A;
- sfr S2BUF = 0x9B;
- sfr ADC_CONTR = 0xBC; //带AD系列
- sfr ADC_RES = 0xBD; //带AD系列
- sfr ADC_RESL = 0xBE; //带AD系列
- sfr P1ASF = 0x9D; //只写,模拟输入(AD或LVD)选择
- sfr P4 = 0xC0;
- sfr P5 = 0xC8;
- sfr P6 = 0xE8;
- sfr P7 = 0xF8;
- sfr P1M1 = 0x91; //PxM1.n,PxM0.n =00--->Standard, 01--->push-pull
- sfr P1M0 = 0x92; // =10--->pure input, 11--->open drain
- sfr P0M1 = 0x93;
- sfr P0M0 = 0x94;
- sfr P2M1 = 0x95;
- sfr P2M0 = 0x96;
- sfr P3M1 = 0xB1;
- sfr P3M0 = 0xB2;
- sfr P4M1 = 0xB3;
- sfr P4M0 = 0xB4;
- sfr P5M1 = 0xC9;
- sfr P5M0 = 0xCA;
- sfr P6M1 = 0xCB;
- sfr P6M0 = 0xCC;
- sfr P7M1 = 0xE1;
- sfr P7M0 = 0xE2;
- sbit P00 = P0^0;
- sbit P01 = P0^1;
- sbit P02 = P0^2;
- sbit P03 = P0^3;
- sbit P04 = P0^4;
- sbit P05 = P0^5;
- sbit P06 = P0^6;
- sbit P07 = P0^7;
- sbit P10 = P1^0;
- sbit P11 = P1^1;
- sbit P12 = P1^2;
- sbit P13 = P1^3;
- sbit P14 = P1^4;
- sbit P15 = P1^5;
- sbit P16 = P1^6;
- sbit P17 = P1^7;
- sbit P20 = P2^0;
- sbit P21 = P2^1;
- sbit P22 = P2^2;
- sbit P23 = P2^3;
- sbit P24 = P2^4;
- sbit P25 = P2^5;
- sbit P26 = P2^6;
- sbit P27 = P2^7;
- sbit P30 = P3^0;
- sbit P31 = P3^1;
- sbit P32 = P3^2;
- sbit P33 = P3^3;
- sbit P34 = P3^4;
- sbit P35 = P3^5;
- sbit P36 = P3^6;
- sbit P37 = P3^7;
- sbit P40 = P4^0;
- sbit P41 = P4^1;
- sbit P42 = P4^2;
- sbit P43 = P4^3;
- sbit P44 = P4^4;
- sbit P45 = P4^5;
- sbit P46 = P4^6;
- sbit P47 = P4^7;
- sbit P50 = P5^0;
- sbit P51 = P5^1;
- sbit P52 = P5^2;
- sbit P53 = P5^3;
- sbit P54 = P5^4;
- sbit P55 = P5^5;
- sbit P56 = P5^6;
- sbit P57 = P5^7;
- /************* IO口定义 **************/
- sbit P_HC595_SER = P4^0; //pin 14 SER data input
- sbit P_HC595_RCLK = P5^4; //pin 12 RCLk store (latch) clock
- sbit P_HC595_SRCLK = P4^3; //pin 11 SRCLK Shift data clock
- u8 hour,minute,second;
- void delay_ms(u8 ms);
- void DisableHC595(void);
- void SetStartAddress(u8 x,u8 y);
- void FillPage(u8 y,u8 color); //Clear Page LCD RAM
- void FillAll(u8 color); //Clear CSn LCD RAM
- void Initialize_LCD(void); //initialize LCD
- void WriteAscii6x8(u8 x,u8 y,u8 ascii,u8 color);
- void WriteHZ16(u8 x,u8 y,u16 hz,u8 color);
- #define P0n_push_pull(bitn) P0M1 &= ~(bitn), P0M0 |= (bitn) //01
- /**************** 外部函数声明和外部变量声明 *****************/
- /********************** 显示时钟函数 ************************/
- void DisplayRTC(void)
- if(hour >= 10) WriteAscii6x8(0,0,hour / 10 + '0',0);
- else WriteAscii6x8(0,0,':',0);
- WriteAscii6x8(6, 0,hour % 10 +'0',0);
- WriteAscii6x8(12,0,':',0);
- WriteAscii6x8(18,0,minute / 10+'0',0);
- WriteAscii6x8(24,0,minute % 10+'0',0);
- WriteAscii6x8(30,0,':',0);
- WriteAscii6x8(36,0,second / 10 +'0',0);
- WriteAscii6x8(42,0,second % 10 +'0',0);
- /********************** RTC演示函数 ************************/
- void RTC(void)
- if(++second >= 60)
- second = 0;
- if(++minute >= 60)
- minute = 0;
- if(++hour >= 24) hour = 0;
- /********************** 主函数 ************************/
- void main(void)
- u8 i;
- P0M1 = 0; P0M0 = 0; //设置为准双向口
- P1M1 = 0; P1M0 = 0; //设置为准双向口
- P2M1 = 0; P2M0 = 0; //设置为准双向口
- P3M1 = 0; P3M0 = 0; //设置为准双向口
- P4M1 = 0; P4M0 = 0; //设置为准双向口
- P5M1 = 0; P5M0 = 0; //设置为准双向口
- P6M1 = 0; P6M0 = 0; //设置为准双向口
- P7M1 = 0; P7M0 = 0; //设置为准双向口
- Initialize_LCD();
- DisableHC595(); //禁止掉学习板上的HC595显示,省电
- hour = 12; //初始化时间值
- minute = 0;
- second = 0;
- DisplayRTC();
- for(i=0; i<8; i++) WriteHZ16(i*16,4,i,0);
- while(1)
- delay_ms(250); //延时1秒
- delay_ms(250);
- delay_ms(250);
- delay_ms(250);
- RTC();
- DisplayRTC();
- // 函数: void delay_ms(u8 ms)
- // 描述: 延时函数。
- // 参数: ms,要延时的ms数, 这里只支持1~255ms. 自动适应主时钟.
- // 返回: none.
- // 版本: VER1.0
- // 日期: 2013-4-1
- // 备注:
- u16 i;
- do{
- i = MAIN_Fosc / 13000;
- while(--i) ; //14T per loop
- }while(--ms);
- u8 i;
- P_HC595_SER = 1;
- for(i=0; i<20; i++)
- P_HC595_SRCLK = 1;
- P_HC595_SRCLK = 0;
- P_HC595_RCLK = 1;
- P_HC595_RCLK = 0; //锁存输出数据
- P_HC595_RCLK = 1;
- unsigned char code HZK16[]={
- 0X10,0X50,0X92,0X14,0XF0,0X10,0X20,0X24,0X24,0XA4,0X24,0XFF,0X20,0X24,0X28,0X00, //1783斌
- 0X20,0X10,0X0D,0X02,0X05,0X18,0X40,0X7F,0X40,0X3F,0X22,0X07,0X38,0X40,0XE0,0X00,
- 0X20,0X42,0X0C,0X40,0X7C,0X40,0XFF,0X48,0X4A,0XF2,0X1A,0XD6,0X12,0XFB,0X12,0X00, //1784濒
- 0X04,0X7C,0X03,0X44,0X23,0X10,0X0F,0X84,0X82,0X4F,0X20,0X1F,0X20,0X4F,0XC0,0X00,
- 0X20,0X42,0X0C,0XD0,0X0C,0X04,0XE4,0XA4,0XA5,0X96,0X94,0XC4,0X84,0X14,0X0C,0X00, //1785滨
- 0X04,0X04,0XFE,0X09,0X08,0X88,0X6F,0X28,0X08,0X08,0X2F,0X48,0XC8,0X0C,0X08,0X00,
- 0X00,0X10,0X0C,0X04,0XE4,0XA4,0XA5,0XA6,0X94,0X94,0XD4,0X84,0X14,0X0C,0X00,0X00, //1786宾
- 0X08,0X08,0X08,0X88,0X6F,0X28,0X08,0X08,0X08,0X2F,0X48,0XC8,0X08,0X0C,0X08,0X00,
- 0X10,0X10,0X10,0XFF,0X90,0X5C,0X04,0XE4,0XA4,0XA5,0X96,0XD4,0X84,0X14,0X0C,0X00, //1787摈
- 0X02,0X42,0X81,0X7F,0X08,0X08,0X88,0X6F,0X28,0X08,0X08,0X2F,0X48,0XCC,0X08,0X00,
- 0X00,0X00,0X00,0X00,0XFC,0X44,0X44,0X44,0X42,0XC2,0X43,0X62,0X40,0X00,0X00,0X00, //1788兵
- 0X04,0X04,0X84,0X44,0X27,0X34,0X04,0X04,0X04,0X17,0X24,0X64,0XC4,0X06,0X04,0X00,
- 0X00,0X02,0X04,0XCC,0X20,0X20,0XA0,0X60,0XFF,0XC0,0X20,0X10,0X08,0X0C,0X00,0X00, //1789冰
- 0X02,0X02,0XFF,0X10,0X08,0X06,0X41,0X80,0X7F,0X00,0X01,0X02,0X0C,0X18,0X08,0X00,
- 0X10,0X10,0XD0,0XFF,0X90,0X14,0XC4,0X44,0X44,0XFC,0X44,0X44,0X44,0XE6,0X44,0X00, //1790柄
- 0X04,0X03,0X00,0XFF,0X00,0X01,0XFF,0X08,0X04,0X03,0X02,0X44,0X8C,0X7F,0X00,0X00,
- unsigned char code ASCII6x8[]={
- 0x3E,0x51,0x49,0x45,0x3E,0x00, //0 0
- 0x00,0x42,0x7F,0x40,0x00,0x00, //1 1
- 0x42,0x61,0x51,0x49,0x46,0x00, //2 2
- 0x21,0x41,0x45,0x4B,0x31,0x00, //3 3
- 0x18,0x14,0x12,0x7F,0x10,0x00, //4 4
- 0x27,0x45,0x45,0x45,0x39,0x00, //5 5
- 0x3C,0x4A,0x49,0x49,0x30,0x00, //6 6
- 0x01,0x01,0x79,0x05,0x03,0x00, //7 7
- 0x36,0x49,0x49,0x49,0x36,0x00, //8 8
- 0x06,0x49,0x49,0x29,0x1E,0x00, //9 9
- 0x7E,0x11,0x11,0x11,0x7E,0x00, //A A
- 0x41,0x7F,0x49,0x49,0x36,0x00, //B B
- 0x3E,0x41,0x41,0x41,0x22,0x00, //C C
- 0x41,0x7F,0x41,0x41,0x3E,0x00, //D D
- 0x7F,0x49,0x49,0x49,0x49,0x00, //E E
- 0x7F,0x09,0x09,0x09,0x01,0x00, //F F
- 0x3E,0x51,0x49,0x45,0x3E,0x00, //10 0
- 0x00,0x42,0x7F,0x40,0x00,0x00, //11 1
- 0x42,0x61,0x51,0x49,0x46,0x00, //12 2
- 0x21,0x41,0x45,0x4B,0x31,0x00, //13 3
- 0x18,0x14,0x12,0x7F,0x10,0x00, //14 4
- 0x27,0x45,0x45,0x45,0x39,0x00, //15 5
- 0x3C,0x4A,0x49,0x49,0x30,0x00, //16 6
- 0x01,0x01,0x79,0x05,0x03,0x00, //17 7
- 0x36,0x49,0x49,0x49,0x36,0x00, //18 8
- 0x06,0x49,0x49,0x29,0x1E,0x00, //19 9
- 0x7E,0x11,0x11,0x11,0x7E,0x00, //1A A
- 0x41,0x7F,0x49,0x49,0x36,0x00, //1B B
- 0x3E,0x41,0x41,0x41,0x22,0x00, //1C C
- 0x41,0x7F,0x41,0x41,0x3E,0x00, //1D D
- 0x7F,0x49,0x49,0x49,0x49,0x00, //1E E
- 0x7F,0x09,0x09,0x09,0x01,0x00, //1F F
- 0x00,0x00,0x00,0x00,0x00,0x00, //20 CHAR address=ASCII*6
- 0x00,0x00,0x4F,0x00,0x00,0x00, //21 !
- 0x00,0x07,0x00,0x07,0x00,0x00, //22 "
- 0x14,0x7F,0x14,0x7F,0x14,0x00, //23 #
- 0x24,0x2A,0x7F,0x2A,0x12,0x00, //24 $
- 0x23,0x13,0x08,0x64,0x62,0x00, //25 %
- 0x36,0x49,0x55,0x22,0x50,0x00, //26 &
- 0x00,0x05,0x03,0x00,0x00,0x00, //27 '
- 0x00,0x1C,0x22,0x41,0x00,0x00, //28 (
- 0x00,0x41,0x22,0x1C,0x00,0x00, //29 )
- 0x14,0x08,0x3E,0x08,0x14,0x00, //2A *
- 0x08,0x08,0x3E,0x08,0x08,0x00, //2B +
- 0x00,0x50,0x30,0x00,0x00,0x00, //2C ,
- 0x08,0x08,0x08,0x08,0x08,0x00, //2D -
- 0x00,0x60,0x60,0x00,0x00,0x00, //2E .
- 0x20,0x10,0x08,0x04,0x02,0x00, //2F /
- 0x3E,0x51,0x49,0x45,0x3E,0x00, //30 0
- 0x00,0x42,0x7F,0x40,0x00,0x00, //31 1
- 0x42,0x61,0x51,0x49,0x46,0x00, //32 2
- 0x21,0x41,0x45,0x4B,0x31,0x00, //33 3
- 0x18,0x14,0x12,0x7F,0x10,0x00, //34 4
- 0x27,0x45,0x45,0x45,0x39,0x00, //35 5
- 0x3C,0x4A,0x49,0x49,0x30,0x00, //36 6
- 0x01,0x01,0x79,0x05,0x03,0x00, //37 7
- 0x36,0x49,0x49,0x49,0x36,0x00, //38 8
- 0x06,0x49,0x49,0x29,0x1E,0x00, //39 9
- 0x00,0x36,0x36,0x00,0x00,0x00, //3A :
- 0x00,0x56,0x36,0x00,0x00,0x00, //3B ;
- 0x08,0x14,0x22,0x41,0x00,0x00, //3C <
- 0x14,0x14,0x14,0x14,0x14,0x00, //3D =
- 0x00,0x41,0x22,0x14,0x08,0x00, //3E >
- 0x02,0x01,0x51,0x09,0x06,0x00, //3F ?
- 0x32,0x49,0x79,0x41,0x3E,0x00, //40 @
- 0x7E,0x11,0x11,0x11,0x7E,0x00, //41 A
- 0x41,0x7F,0x49,0x49,0x36,0x00, //42 B
- 0x3E,0x41,0x41,0x41,0x22,0x00, //43 C
- 0x41,0x7F,0x41,0x41,0x3E,0x00, //44 D
- 0x7F,0x49,0x49,0x49,0x49,0x00, //45 E
- 0x7F,0x09,0x09,0x09,0x01,0x00, //46 F
- 0x3E,0x41,0x41,0x49,0x7A,0x00, //47 G
- 0x7F,0x08,0x08,0x08,0x7F,0x00, //48 H
- 0x00,0x41,0x7F,0x41,0x00,0x00, //49 I
- 0x20,0x40,0x41,0x3F,0x01,0x00, //4A J
- 0x7F,0x08,0x14,0x22,0x41,0x00, //4B K
- 0x7F,0x40,0x40,0x40,0x40,0x00, //4C L
- 0x7F,0x02,0x0C,0x02,0x7F,0x00, //4D M
- 0x7F,0x06,0x08,0x30,0x7F,0x00, //4E N
- 0x3E,0x41,0x41,0x41,0x3E,0x00, //4F O
- 0x7F,0x09,0x09,0x09,0x06,0x00, //50 P
- 0x3E,0x41,0x51,0x21,0x5E,0x00, //51 Q
- 0x7F,0x09,0x19,0x29,0x46,0x00, //52 R
- 0x26,0x49,0x49,0x49,0x32,0x00, //53 S
- 0x01,0x01,0x7F,0x01,0x01,0x00, //54 T
- 0x3F,0x40,0x40,0x40,0x3F,0x00, //55 U
- 0x1F,0x20,0x40,0x20,0x1F,0x00, //56 V
- 0x7F,0x20,0x18,0x20,0x7F,0x00, //57 W
- 0x63,0x14,0x08,0x14,0x63,0x00, //58 X
- 0x07,0x08,0x70,0x08,0x07,0x00, //59 Y
- 0x61,0x51,0x49,0x45,0x43,0x00, //5A Z
- 0x00,0x7F,0x41,0x41,0x00,0x00, //5B {
- 0x02,0x04,0x08,0x10,0x20,0x00, /*5C \*/
- 0x00,0x41,0x41,0x7F,0x00,0x00, //5D }
- 0x04,0x02,0x01,0x02,0x04,0x00, //5E ^
- 0x40,0x40,0x40,0x40,0x40,0x00, //5F _
- 0x01,0x02,0x04,0x00,0x00,0x00, //60 '
- 0x20,0x54,0x54,0x54,0x78,0x00, //61 a
- 0x7F,0x48,0x44,0x44,0x38,0x00, //62 b
- 0x38,0x44,0x44,0x44,0x28,0x00, //63 c
- 0x38,0x44,0x44,0x48,0x7F,0x00, //64 d
- 0x38,0x54,0x54,0x54,0x18,0x00, //65 e
- 0x00,0x08,0x7E,0x09,0x02,0x00, //66 f
- 0x0C,0x52,0x52,0x4C,0x3E,0x00, //67 g
- 0x7F,0x08,0x04,0x04,0x78,0x00, //68 h
- 0x00,0x44,0x7D,0x40,0x00,0x00, //69 i
- 0x20,0x40,0x44,0x3D,0x00,0x00, //6A j
- 0x00,0x7F,0x10,0x28,0x44,0x00, //6B k
- 0x00,0x41,0x7F,0x40,0x00,0x00, //6C l
- 0x7C,0x04,0x78,0x04,0x78,0x00, //6D m
- 0x7C,0x08,0x04,0x04,0x78,0x00, //6E n
- 0x38,0x44,0x44,0x44,0x38,0x00, //6F o
- 0x7E,0x0C,0x12,0x12,0x0C,0x00, //70 p
- 0x0C,0x12,0x12,0x0C,0x7E,0x00, //71 q
- 0x7C,0x08,0x04,0x04,0x08,0x00, //72 r
- 0x58,0x54,0x54,0x54,0x64,0x00, //73 s
- 0x04,0x3F,0x44,0x40,0x20,0x00, //74 t
- 0x3C,0x40,0x40,0x3C,0x40,0x00, //75 u
- 0x1C,0x20,0x40,0x20,0x1C,0x00, //76 v
- 0x3C,0x40,0x30,0x40,0x3C,0x00, //77 w
- 0x44,0x28,0x10,0x28,0x44,0x00, //78 x
- 0x1C,0xA0,0xA0,0x90,0x7C,0x00, //79 y
- 0x44,0x64,0x54,0x4C,0x44,0x00, //7A z
- 0x00,0x08,0x36,0x41,0x00,0x00, //7B {
- 0x00,0x00,0x77,0x00,0x00,0x00, //7C |
- 0x00,0x41,0x36,0x08,0x00,0x00, //7D }
- 0x02,0x01,0x02,0x04,0x02,0x00, //7E ~
- 0xFF,0xFF,0xFF,0xFF,0xFF,0x00, //7F all display
- 0xFF,0x00,0x00,0x00,0x00,0x00}; //80 cursor
- /************* 功能说明 **************
- LCD12864的基本驱动程序,兼容IC:HD61202 KS0108B SED1520.
- /********************* LCD 128*64 Module, Controler HD61202U *************************************
- R_W L: write data to LCD; H: read data from LCD
- RS L: Instruction Code Input or state output; H: data input or output
- RESET H: normal work; L: reset LCD
- CS1 H: disable Pice 1, L:enable Pice 1
- CS2 H: disable Pice 2, L:enable Pice 2
- CS3 H: disable Pice 3, L:enable Pice 3
- E L: disable; H: read State or data from LCD;
- H-->L: write command or data to LCD
- D0~D7 Data bus
- RS R/W
- 0 0 :write command to LCD
- 0 1 :read status from LCD
- 1 0 :write display data to LCD
- 1 1 :read display data from LCD
- #define C_Busy 0x80
- #define C_On_Off 0x20
- #define C_Reset 0x10
- #define LCD_On 0x3F
- #define LCD_Off 0x3E
- #define LCD_StartLine0 0xC0 //Set display start line(0~3FH), real start line=(0C0H+Line Number)
- #define LCD_Page0 0xB8 //Set Page (X Address)(0~7), real page = 0B8H+Page Number
- #define LCD_SetColumn0 0x40 //Set Y address (0~3FH), real column = 40H + column number
- // 1----VSS
- // 2----VDD +5V
- // 3----Vo LCD Opration Voltage
- sbit RS = P2^5; // 4----RS L-->Command,H-->Data
- sbit R_W = P2^6; // 5----R_W L-->Write, H-->Read
- sbit LCD_EN = P2^7; // 6----E H-->L: write command or data to LCD,H: read State or data from LCD;
- sfr LCD_DATA = 0x80; // 7~14--D0~D7 Data bus
- sbit CS1 = P2^4; // 15---CS1 L-->Chip select1
- sbit CS2 = P2^2; // 16---CS2 L-->Chip select2
- sbit LCD_RESET = P2^3; // 17---RESET L-->Enable
- // 18---VEE L-->Chip select3
- // 19---LED- LED A Back Light LED Drive
- // 20---LED+ LED K Back Light LED Drive
- sbit LCD_BUSY = LCD_DATA^7;
- #define CMD_WriteCMD() RS=0, R_W=0
- #define CMD_ReadStatus() RS=0, R_W=1
- #define CMD_WriteData() RS=1, R_W=0
- #define CMD_ReadData() RS=1, R_W=1
- #define SELECT 1
- #define UNSELECT 0
- void LCD_delay(void)
- u8 i;
- // i = (u8)(MAIN_Fosc / 2000000UL);
- i = (u8)(MAIN_Fosc / 1000000UL);
- while(--i) ;
- u8 CheckBusy(void) //不需要检测忙
- u8 i;
- LCD_DATA = 0xFF;
- CMD_ReadStatus();
- LCD_EN = 1;
- LCD_delay();
- for(i=0; i<100; i++) //检测忙, 一般最大 大约10us, 这个使用超时退出
- if(LCD_BUSY == 0) break; // 11T / loop, 0.5us at 11.0592MHZ
- LCD_EN = 0;
- if(i >= 100) return 1; //超时
- return 0; //正确
- void WriteCMD(u8 cmd)
- if(CheckBusy() > 0) return; //检测忙错误
- CMD_WriteCMD();
- LCD_DATA = cmd;
- LCD_delay();
- LCD_EN = 1;
- LCD_delay();
- LCD_EN = 0;
- LCD_delay();
- LCD_DATA = 0xFF;
- void WriteData(u8 dat) //write display data to LCD
- CMD_WriteData();
- LCD_DATA = dat;
- LCD_delay();
- LCD_EN = 1;
- LCD_delay();
- LCD_EN = 0;
- LCD_DATA = 0xFF;
- WriteCMD(x + LCD_SetColumn0);
- WriteCMD(y + LCD_Page0);
- void FillPage(u8 y,u8 color) //Clear Page LCD RAM
- u8 j;
- SetStartAddress(0,y);
- for(j=0; j<64; j++) WriteData(color);
- void FillAll(u8 color) //Clear CSn LCD RAM
- u8 i;
- for(i=0; i<8; i++) FillPage(i,color);
- void Initialize_LCD(void) //initialize LCD
- LCD_RESET = 0;
- delay_ms(10);
- LCD_RESET = 1;
- delay_ms(150);
- // CS1 = SELECT;
- // CS2 = SELECT;
- WriteCMD(LCD_Off); //0x3E turn off LCD
- WriteCMD(LCD_StartLine0); //#0C0H set the start line is the first line
- WriteCMD(LCD_On); //#3FH turn on display
- FillAll(0);
- CS1 = UNSELECT;
- CS2 = UNSELECT;
- u8 code *p;
- u8 i;
- p = ascii * 6 + ASCII6x8;
- if(x < 64) CS1 = SELECT;
- else CS2 = SELECT, x -= 64;
- SetStartAddress(x,y);
- for(i=0; i<6; i++) {WriteData((*p) ^ color); p++;}
- CS1 = UNSELECT;
- CS2 = UNSELECT;
- u8 code *p;
- u8 i;
- p = hz * 32 + HZK16;
- for(i=0; i<16; i++) {WriteData((*p) ^ color); p++;}
- SetStartAddress(x,y+1);
- CS1 = UNSELECT;
- CS2 = UNSELECT;
