- * @file main.c
- * @author Supowang any question please send mail to 512965803@qq.com
- * @version V1.0
- * @date 2016-12-07
- * @brief Huawei LiteOS第三方开发板移植DEMO
- * 本例程仅供学习参考,Huawei LiteOS和所有驱动代码版权由原作者享有。
- /* Includes ------------------------------------------------------------------*/
- // Huawei LiteOS头文件
- #include "stdio.h"
- #include "stdlib.h"
- #include "string.h"
- #include "los_base.h"
- #include "los_config.h"
- #include "los_typedef.h"
- #include "los_hwi.h"
- #include "los_task.ph"
- #include "los_sem.h"
- #include "los_event.h"
- #include "los_memory.h"
- #include "los_queue.ph"
- // STM32硬件相关头文件
- #include "stm32f10x.h"
- #include "bsp_led.h"
- #include "bsp_usart.h"
- #include "bsp_lcd.h"
- #include "bsp_dht11.h"
- void Delay(__IO u32 nCount);
- #define SOFT_DELAY Delay(0x0FFFFF);
- UINT32 g_TestTskHandle;
- DHT11_Data_TypeDef DHT11_Data;
- void Delay(__IO uint32_t nCount) //简单延时
- for(; nCount != 0; nCount--);
- void hardware_init(void)
- LED_GPIO_Config();
- USART_Config();
- DHT11_Init();
- LCD_Init ();
- ILI9341_GramScan ( 1 );
- ILI9341_Clear ( 0, 0, 240, 320, macWHITE);
- ILI9341_DispString_EN ( 0, 10, " Welcome to Huawei LiteOS!", macWHITE, macRED );
- ILI9341_DispString_EN ( 10, 40, "Task1 Running Count is: ", macWHITE, macBLUE );
- ILI9341_DispString_EN ( 10, 60, "Task2 Running Count is: ", macWHITE, macBLUE );
- ILI9341_DispString_EN ( 45, 90, "Task3: DHT11 DEMO ", macWHITE, macBLUE );
- ILI9341_DispString_EN ( 30, 110, "Temperature is:", macWHITE, macBLACK );
- ILI9341_DispString_EN ( 30, 130, "Humidity is:", macWHITE, macBLACK );
- VOID task1(void)
- UINT32 uwRet = LOS_OK;
- UINT32 count=0;
- char str[10];
- while(1)
- count++;
- sprintf(str,"%d",count);
- ILI9341_DispString_EN ( 200, 40, str, macWHITE, macRED );
- printf("This is task 1,count is %d\r\n",count);
- LED1_TOGGLE;
- LED2_TOGGLE;
- uwRet = LOS_TaskDelay(1000);
- if(uwRet !=LOS_OK)
- return;
- UINT32 creat_task1(void)
- TSK_INIT_PARAM_S task_init_param;
- task_init_param.usTaskPrio = 1;
- task_init_param.pcName = "task1";
- task_init_param.pfnTaskEntry = (TSK_ENTRY_FUNC)task1;
- task_init_param.uwStackSize = LOSCFG_BASE_CORE_TSK_DEFAULT_STACK_SIZE;
- task_init_param.uwResved = LOS_TASK_STATUS_DETACHED;
- uwRet = LOS_TaskCreate(&g_TestTskHandle,&task_init_param);
- return uwRet;
- return uwRet;
- VOID task2(void)
- UINT32 count=0;
- char str[10];
- while(1)
- count++;
- ILI9341_DispString_EN ( 200, 60, str, macWHITE, macRED );
- printf("This is task 2,count is %d\r\n",count);
- LED2_TOGGLE;
- LED3_TOGGLE;
- uwRet = LOS_TaskDelay(2000);
- return;
- UINT32 creat_task2(void)
- task_init_param.pcName = "task2";
- task_init_param.pfnTaskEntry = (TSK_ENTRY_FUNC)task2;
- return uwRet;
- return uwRet;
- VOID DHT11_task(void)
- char cStr1[10];
- char cStr2[10];
- while(1)
- if(DHT11_Read_TempAndHumidity(&DHT11_Data)==SUCCESS)
- sprintf(cStr1,"%d.%d C",DHT11_Data.temp_int,DHT11_Data.temp_deci);
- sprintf(cStr2,"%d.%d %%RH",DHT11_Data.humi_int,DHT11_Data.humi_deci);
- ILI9341_DispString_EN ( 160, 110, cStr1, macWHITE, macRED );
- ILI9341_DispString_EN ( 140, 130, cStr2, macWHITE, macRED );
- printf("\r\n ??DHT11??,???%d.%d C,??? %d.%d %%RH",\
- DHT11_Data.temp_int,DHT11_Data.temp_deci,DHT11_Data.humi_int,DHT11_Data.humi_deci);
- else
- printf("DHT11 ERROR!\r\n");
- return;
- UINT32 creat_DHT11_task(void)
- task_init_param.usTaskPrio = 0;
- task_init_param.pcName = "DHT11_task";
- task_init_param.pfnTaskEntry = (TSK_ENTRY_FUNC)DHT11_task;
- return uwRet;
- return uwRet;
- UINT32 osAppInit(void)
- UINT32 uwRet = 0;
- hardware_init();
- LED1_ON;
- SOFT_DELAY;
- uwRet = creat_task1();
- return uwRet;
- uwRet = creat_task2();
- return uwRet;
- uwRet = creat_DHT11_task();
- return uwRet;
- return LOS_OK;
- /*********************************************END OF FILE**********************/
温湿度检测.7z
257.04 KB, 下载次数: 23, 下载积分: 黑币 -5
