查看: 1906|回复: 13
单片机程序怎么修改设置好对应时间,等待10s左右自动倒计时,不用按键触发倒计时
ID:858009 发表于 2021-10-28 11:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. #include<reg51.h>
  3. #define uint unsigned int
  4. uchar min,sec,count,sec1,sec2,min0,min1,min2,keystopc,temp;
  5. sbit keystop=P3^0;
  6. sbit keyh=P3^1;
  7. sbit keym=P3^2;
  8. sbit keys=P3^3;
  9. sbit lcden=P3^4;
  10. sbit lcdrw=P3^6;
  11. sbit lcdrs=P3^5;
  12. uchar code table[]={'0','1','2','3','4','5','6','7','8','9',':'};
  13. void init()                                                //定时器初始化
  14. {
  15.         count=0;
  16.         min=0;
  17.         sec=59;
  18.         TMOD=0x01;
  19.         TH0=(65536-50000)/256;
  20.         TL0=(65536-50000)%256;
  21.         TR0=0;
  22.         ET0=1;
  23.         EA=1;
  24. }
  25. void delay(uint z)                //延时程序
  26. {
  27.         uint x,y;
  28.         for(x=z;x>0;x--)
  29.          for(y=110;y>0;y--);
  30. }
  31. /**************************************************************
  32. ------LCD1602显示函数------
  33. *************************************************************/
  34. void write_com(uchar com)
  35. {
  36.         lcdrs=0;
  37.         P0=com;
  38.         delay(5);
  39.         lcden=1;
  40.         delay(5);
  41.         lcden=0;
  42. }
  43. void write_data(uchar date)
  44. {
  45.         lcdrs=1;
  46.         P0=date;
  47.         delay(5);
  48.         lcden=1;
  49.         delay(5);
  50.         lcden=0;
  51. }
  52. void init_1602()                                //初始化1602
  53. {
  54.         lcden=0;
  55.         lcdrw=0;
  56.         write_com(0x38);
  57.         write_com(0x0c);
  58.         write_com(0x06);
  59.         write_com(0x01);
  60.         write_com(0x80);
  61. }
  62. void write_Char(unsigned char x,unsigned char y,unsigned char date)
  63. {
  64.          if (y == 0)
  65.          {
  66.                 write_com(0x80 + x);
  67.          }
  68.         else
  69.          {
  70.                 write_com(0xC0 + x);
  71.          }
  72.         write_data(date);
  73. }
  74. void display(uchar min0,uchar min1,uchar min2,uchar sec1,uchar sec2)         //显示程序
  75. {
  76.         write_Char(3,0,table[min0]);
  77.         write_Char(4,0,table[min1]);
  78.         write_Char(5,0,table[min2]);
  79.         write_Char(6,0,table[0x0a]);
  80.         write_Char(7,0,table[sec1]);
  81.         write_Char(8,0,table[sec2]);
  82. }
  83. /************************************************************
  84. ------计时器/定时器0-----
  85. *************************************************************/
  86. void count0() interrupt 1
  87. {
  88.         TH0=(65536-50000)/256;
  89.         TL0=(65536-50000)%256;
  90.         count++;
  91.         if(count==20)
  92.                 {
  93.                         count=0;
  94.                         if(sec==0)
  95.                         {
  96.                                 if (min!=0)
  97.                                 {
  98.                                         sec=59;
  99.                                         min--;
  100.                                 }
  101.                         }
  102.                         else sec--;
  103.                 }
  104. }
  105. /************************************************************
  106. ------主函数------
  107. *************************************************************/
  108. void main()
  109. {
  110.         init();
  111.         init_1602();
  112.         while(1)
  113.         {
  114.                 if(keystop==0)                             //检测是否停止键按下
  115.                 {
  116.                         delay(10);
  117.                         if(keystop==0)
  118.                         {
  119.                                 if(keystopc!=1)   keystopc++;      //按停止键的次数
  120.                                 else              keystopc=0;
  121.                                 while(keystop==0);                 //松手检测
  122.                                 delay(5);
  123.                                 while(keystop==0);
  124.                         }
  125.                         switch(keystopc)
  126.                         {
  127.                                 case 1:TR0=0;break;                // 按键一次就停止计数
  128.                                 case 0:TR0=1;break;
  129.                                 default:break;
  130.                         }
  131.                 }
  132.                 if(keyh==0)                 //实现小时加一
  133.                 {
  134.                         delay(50);
  135.                         if(keyh==0)
  136.                         {
  137.                                 if(min!=110)
  138.                                 {
  139.                                         min++;
  140.                                 }
  141.                         }
  142.                         while(!keym);                  //松手检测
  143.                         delay(5);
  144.                         while(!keym);
  145.                 }
  146.                 if(keym==0)              //实现分钟加一
  147.                 {
  148.                         delay(100);
  149.                         if(keym==0)
  150.                         {
  151.                                 if(min!=0)
  152.                                 {
  153.                                         min--;
  154.                                 }
  155.                         }
  156.                         while(!keyh);                //松手检测
  157.                         delay(5);
  158.                         while(!keyh);
  159.                 }
  160.                 min0=min/100;
  161.                 min1=min%100/10;
  162.                 min2=min%10;
  163.                 sec1=sec/10;
  164.                 sec2=sec%10;
  165.                display(min0,min1,min2,sec1,sec2);  //一直显示时钟
  166.         }
  167. }
ID:480510 发表于 2021-10-28 14:00 | 只看该作者
再用一个定时器来控制10秒
ID:624769 发表于 2021-10-28 14:25 | 只看该作者
bit  T_run;             <==== 增加全局变量
------计时器/定时器0-----
        count++;
        if(T_run)               <==== 增加
        if(count>=20)
                        count=0;
                        if(sec==0)
                                if (min!=0)
                                        sec=59;
                                        min--;
                        else sec--;
          else                      <==== 增加
                 if(count >= 200)           <==== 增加
                           T_run = 1;                  <==== 增加
                           count = 0;                 <==== 增加
------主函数------
        init();
        init_1602();
        TR0 = 1         <==== 增加
                        delay(10);
                        if(keystop==0)
                                else              keystopc=0;
                                delay(5);
                                while(keystop==0);
                        switch(keystopc)
//                                case 1:TR0=0;break;                // 按键一次就停止计数
//                                case 0:TR0=1;break;
                                case 1:T_run=0;break;           <==== 修改
                                case 0:T_run=1;break;           <==== 修改
                               default:break;
                        delay(50);
                        if(keyh==0)
                                if(min!=110)
                                        min++;
                                count = 0;             <==== 增加
                        delay(5);
                        while(!keym);
                        delay(100);
                        if(keym==0)
                                if(min!=0)
                                        min--;
                                count = 0;                  <==== 增加
                        delay(5);
                        while(!keyh);
                min0=min/100;
                min1=min%100/10;
                min2=min%10;
                sec1=sec/10;
                sec2=sec%10;
惨不忍睹,只能改成这样了
ID:123289 发表于 2021-10-28 14:33 | 只看该作者
既然是计时就一定有开始和结束。
结束:可以由计时器计时10s后触发。
开始:谁触发呢?不用按键触发,也需要你设置一个触发的方式呀。哪怕你决定打个喷嚏也行啊。
ID:858009 发表于 2021-10-28 14:41 | 只看该作者
yzwzfyz 发表于 2021-10-28 14:33
既然是计时就一定有开始和结束。
结束:可以由计时器计时10s后触发。
开始:谁触发呢?不用按键触发,也 ...
这个是做一个倒计时的,只有两个按键,一个控制分钟加,一个控制分钟减
看能不能自动触发开始倒计时,设置倒计的时间后等待十秒,按键加和按键减没有被按下,测开始倒计时,启动定时器1
ID:311846 发表于 2021-10-28 15:10 | 只看该作者
看能不能自动触发开始倒计时,设 ...
那你再定时10秒啊!
ID:123289 发表于 2021-10-29 09:46 | 只看该作者
很简单的事!抓住要点:如何起,如何停。再想想,不要想程序如何写,想想逻辑上是否说得通。
ID:858009 发表于 2021-11-10 14:53 | 只看该作者
我想把那个暂停/启动按键去掉,例如设置10分钟倒计时,设置结束后等待10s启动倒计时
ID:858009 发表于 2021-11-10 14:57 | 只看该作者
原本使用一个按键控制启动和暂停
现在想使用设置好对应时间,等待10s左右,开启定时器进入倒计时,倒计时结束后定时器停止,蜂鸣器响3s停3s循环
ID:624769 发表于 2021-11-10 15:15 | 只看该作者
不是帮你改好了么?
你不要那个暂停/启动 直接删掉不就行了? 你程序试过没有? 是不是那个键按不按都没所谓?是的话,直接删了不就没有了?
ID:858009 发表于 2021-11-10 15:58 | 只看该作者
188610329 发表于 2021-11-10 15:15
不是帮你改好了么?
你不要那个暂停/启动 直接删掉不就行了? 你程序试过没有? 是不是那个键按不按都 ...
这个不能等待按键设置对应时间后等待10s再启动定时器进入倒计时,倒计时结束后,定时器一直在启动,没有中断停止
ID:858009 发表于 2021-11-10 16:00 | 只看该作者
不是帮你改好了么?
有两个加减按键设置时间的,倒计时结束后有蜂鸣器提示的,既要启动,也要停止
ID:624769 发表于 2021-11-10 16:21 | 只看该作者
qwettyuio 发表于 2021-11-10 15:58
这个不能等待按键设置对应时间后等待10s再启动定时器进入倒计时,倒计时结束后,定时器一直在启动,没有 ...
这么改就是设好时间后,等10秒启动啊,你不是要等10秒启动么? 定时器关了,怎么判断10秒?
至于停止,你原来怎么停的?你原来停的地方, 只要T_run = 0, 就停了啊,我只看到你按键的地方,所以那里我帮你写了 T_run = 0;
但是,其他地方,我没看到,你有其他停的地方,你手动把 T_run = 0, 反正, TR0 是不能 =0 的 不然,没办法10秒自己启动。
ID:624769 发表于 2021-11-10 16:23 | 只看该作者
你原程序里哪里有到时间蜂鸣器响的判断? 你原程序里没有,我帮你凭空加出来?
