大佬试着您的程序,多打啦几次代码大概意识懂了,添加了几个模式想让它开时还是流水慢到快固定,关时快到慢关闭,切换后也是慢到快。程序keil没报错,仿真测试开始是慢到快,关没有效果直接关闭,再开还是快的流水。。。能帮我看看嘛
#include <reg51.h>
sbit key1=P3^0;
typedef unsigned char u8;MODE;slow;
typedef unsigned int u16;count;
typedef unsigned long u32;
unsigned char dat1[4]={0xf1,0xf2,0xf4,0xf8};
unsigned char dat2[4]={0xfc,0xf9,0xf3,0xf6};
unsigned char dat3[4]={0xfe,0xfd,0xfb,0xf7};
bit Power_On = 1;
bit sign;
u16 TMR_XX_ACC;
u16 TMR_XX_PRE = 500;
u8 index = 0;
void mode1(void);
void mode2(void);
void mode3(void);
void key_Proc();
void Delay_XD(unsigned int x);
void key_Proc()
if(key1==0)
if(count<501)count++;
if(count==500)//长按
sign=~sign;
if(sign)
slow=MODE;//保存键值下次开启还是在哪个模式
MODE = 0;//关闭流水
else MODE=slow; //还原键值
if(count>20 && count<500)//短按
++MODE;
if(MODE>3)
MODE=1;
count = 0;
while (1)
key_Proc();
switch(MODE)
case 0: P0=0xFF;break;
case 1: mode1();break;
case 2: mode2();break;
case 3: mode3();break;
Delay_XD(1);
unsigned int i,j;
for(i=0;i<x;i++)
for(j=0;j<120;j++);//12T
void mode1(void)
if(++TMR_XX_ACC >= TMR_XX_PRE)
TMR_XX_ACC=0;
if(TMR_XX_PRE != 500)
P0=dat1[index];
index = ++index %4;
P0 = 0xFF;
if(Power_On)
if(TMR_XX_PRE>20)//固定到快
TMR_XX_PRE -=10;
if(TMR_XX_PRE<500)//固定到慢
TMR_XX_PRE +=20;
void mode2(void)
TMR_XX_ACC=0;
P0=dat2[index];
index = ++index %4;
P0 = 0xFF;
if(Power_On)
TMR_XX_PRE -=10;
TMR_XX_PRE +=20;
void mode3(void)
TMR_XX_ACC=0;
P0=dat3[index];
index = ++index %4;
P0 = 0xFF;
if(Power_On)
TMR_XX_PRE -=10;
TMR_XX_PRE +=20;
