#include<reg51.h>
sbit a=P1^0; //led1
sbit b=P1^1;
sbit c=P1^2;
sbit d=P1^3;
sbit h1=P0^0; //红外对管
sbit h2=P0^1; //红外对管
sbit h3=P0^4; //红外对管
int go,back,left,right,clean,clean_over,xunji,xunji_over;
int flag_uart=0;
int flag_on=0;
void UsartConfiguration(); //串口初始化
if(flag_uart==1)
ES=0;
flag_uart=0;
switch(flag_on)
case 1: go=1; break;
case 2: back=1; break;
case 3: left=1; break;
case 4: right=1; break;
case 5: clean=1; break;
case 6: xunji=1; break;
case 7: clean_over=1; break;
case 8: xunji_over=1; break;
ES=1;
flag_on=0;
if(go==1)
a=0;
//串口初始化
SCON=0X50; //设置为工作方式1
TMOD=0X20; //设置计数器工作方式2
PCON=0X80; //波特率加倍
TH1=0XFd; //计数器初始值设置,注意波特率是9600
TL1=0XFd;
ES=1; //打开接收中断
EA=1; //打开总中断
TR1=1; //打开计数器
//串口中断:中断入口号4
void Usart() interrupt 4
int receiveData;
receiveData=SBUF;//出去接收到的数据
RI = 0;//清除接收中断标志位
//new
flag_uart = 1;
if(receiveData==97) flag_on=1;
else if(receiveData=='i') flag_on=2;
else if(receiveData=='j') flag_on=3;
else if(receiveData=='k') flag_on=4;
else if(receiveData=='l') flag_on=5;
else if(receiveData=='m') flag_on=6;
else if(receiveData=='n') flag_on=7;
else if(receiveData=='o') flag_on=8;
SBUF=receiveData; //将接收到的数据放入到发送寄存器
while(!TI); //等待发送数据完成
TI=0; //清除发送完成标志位
