查看: 2977|回复: 3
ht1621驱动断码屏。全显时,com4上的段不显示
ID:289495 发表于 2018-11-8 09:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
10黑币
测试发现,点亮的断码越多,com4上的段显示越暗,全部显示后,com4上的段就没显示了
怎么回事啊?
来自 2#
ID:289495 发表于 2018-11-16 08:42 | 只看该作者
已解决,硬件问题
ID:289495 发表于 2018-11-15 11:20 | 只看该作者
这是程序
#include "lcd.h"
#include "sys.h"
unsigned char tab9[]={
0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,
unsigned char tab0[]={
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
void Delayns(void)
        __asm("nop");__asm("nop");__asm("nop");__asm("nop");__asm("nop");__asm("nop");
void Delay_t(uint t)
        uint i,j;
        for(i=0;i<t;i++)
        for(j=0;j<80;j++);
//PB3--CS
//PB4--背光
//PB5--WR
//PB6--DATA
void Initial_LCD()
        GPIO_InitTypeDef  GPIO_InitStructure;
        RCC_AHBPeriphClockCmd( RCC_AHBPeriph_GPIOB, ENABLE);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3|GPIO_Pin_4 |GPIO_Pin_5|GPIO_Pin_6;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
        GPIO_Init(GPIOB, &GPIO_InitStructure);
        LCD_CS_H();
        LCD_WR_H();
        LCD_DATA_H();
        LCD_RD_L();
        delay_ms(10);
        LCD_RD_H();
        delay_ms(100);
        Write_command(0x30);//select 1/4 dut & 1/3 bias
        Write_command(0x02);//RC 256K
        Write_command(0x52);//system enable
        Write_command(0x06);//LCD ON
void Write_ID(unsigned char ID,unsigned char cnt)
   unsigned char i;
   for(i=0;i<cnt;i++)
           LCD_WR_L();
           delay_us(5);
           if(ID&0x80)
                 LCD_DATA_H();
                LCD_DATA_L();
           LCD_WR_H();
           delay_us(5);
           ID<<=1;
void Write_data_bit(unsigned char dat,unsigned char cnt)
        unsigned char i;
        for(i=0;i<cnt;i++)
                LCD_WR_L();
                delay_us(5);
                if(dat&0x01)
                        LCD_DATA_H();
                        LCD_DATA_L();
                //delay_us(5);
                LCD_WR_H();
                delay_us(5);
                dat>>=1;
//写命令函数
void Write_command(unsigned char Command_byte)
        LCD_CS_L();
        delay_us(5);
        Write_ID(0x80,4);
        Write_ID(Command_byte,8);
        LCD_CS_H();
//写一个数据
void Singal_data_write(unsigned char address,unsigned char dat)
        LCD_CS_L();
        delay_us(5);
        Write_ID(0xa0,3);//write   101
        Write_ID(address,6);//address from 0x00
        Write_data_bit(dat,4);
        LCD_CS_H();delay_us(5);
//写所有数据
void Writeall_data_1621(unsigned char *p)
        unsigned char i;
        unsigned char temp_data;
        LCD_CS_L();
        delay_us(5);
        Write_ID(0x00,6);//address from 0x00
        for(i=0;i<48;i++)
                temp_data =p;
                Write_data_bit(temp_data,4);
        LCD_CS_H();
#include "sys.h"
#include "lcd.h"
extern unsigned char tab8[];
extern unsigned char tab2[];
extern unsigned char tab9[];
extern unsigned char tab5[];
extern unsigned char tab0[];
extern unsigned char tab4[];
int main(void)
        delay_init(48);
       Initial_LCD();
        delay_ms(1000);
        delay_ms(1000);
        Writeall_data_1621(tab0);   //清屏
        delay_ms(100);
               Writeall_data_1621(tab9);                        Delay_t(3000);//全部显示
ID:337808 发表于 2018-12-13 22:08 | 只看该作者
//写所有数据
void Write_All_data_1621(unsigned char *p)
        unsigned char i;
        LCD_CS_L();
        delay_us(5);
        Write_ID(0xA0,3);//write   101
        for(i=0;i<48;i++)
                temp_data = p++;        //原文为temp_data=p; 请楼主赐教????
        LCD_CS_H();
