查看: 1328|回复: 0
求助大神帮忙看下步进电机单片机程序,不转 谢谢!
ID:298727 发表于 2018-4-12 10:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
5黑币
想通过上位机控制p1口的两个步进电机,但是电机就是转不了
#include<reg52.h>
#define uint  unsigned int
//------8ÅÄ-----
uchar code zz[]={0x55,0x11,0x99,0x88,0xaa,0x22,0x66,0x44};   //Õýת
uchar code fz[]={0x44,0x66,0x22,0xa,0x88,0x99,0x11,0x55};   //·´×ª
uchar state=0;
uint Time=60;
unsigned char receiveData='0';
void UsartConfiguration();
void delay(uint ms)
uint t;
while(ms--)
  for(t=0;t<120;t++);
void motor_zz()
uint j;
for(j=0;j<8;j++)
  P1=zz[j];
  delay(Time);
void motor_fz()
uint j;
for(j=0;j<8;j++)
  P1=fz[j];
  delay(Time);
  while(state==0)
   if(receiveData=='z')
    state=1;
    receiveData='0';
    break;
   if(receiveData=='f')
    state=2;
    receiveData='0';
    break;
   P1=0x11;
  while(state==1)
   if(receiveData=='t')
    state=0;
    receiveData='0';
    break;
    state=1;
    receiveData='0';
    break;
    state=2;
    receiveData='0';
    break;
   if(receiveData=='+')
    Time=Time-5;
    if(Time<20)
    Time=20;
   if(receiveData=='-')
    Time=Time+5;
    if(Time>100)
    Time=100;
   motor_zz();
  while(state==2)
    state=0;
    receiveData='0';
    break;
    state=1;
    receiveData='0';
    break;
    state=2;
    receiveData='0';
    break;
    Time=Time-5;
    if(Time<20)
    Time=20;
    Time=Time+5;
    if(Time>100)
    Time=100;
   motor_fz();
SCON=0X50;
TMOD=0X21;
PCON=0X00;
TH1=0XFD;
TL1=0XFD;
ES=1;
EA=1;
TR1=1;
void Usart() interrupt 4
receiveData=SBUF;
RI = 0;
