查看: 3412|回复: 0
哪位大哥帮看看,那个temp为什么总不对
ID:53274 发表于 2013-8-20 13:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg52.h>
#include <intrins.h>
#define uint unsigned int
sbit dula=P2^6;
sbit wela=P2^7;
sbit DQ=P2^2;   //温度数据
uint temp;
float ftemp;        float tt;
uchar timecount;
uchar tflag,sflag;
unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,
                                0x07,0x7f,0x6f,0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,0x87,0xff,0xef,};
void delay(uint x)
        while(x--);
delay(1)          延时 7us
delay(7)          延时63us
delay(100)         延时 611us
void delay1(uint x)
        uint i,j;
        for(i=x;i>0;i--)
                for(j=110;j>0;j--);
void init_18b20()
        uint i;
        i=3000;
        DQ = 1;
        delay(1);
        DQ = 0;
        delay(100);
        DQ=1;
        while(DQ==0&&i>0) i--;
        delay(80);
        DQ=1;
//读字节
uchar readonebyte( )
        bit flag = 0;
        uchar i = 0, temp2 = 0;
        for(i = 0; i < 8; i++)
                temp2=temp2>>1;
                DQ=1;
                _nop_();
                DQ = 0;
                delay(1);
                DQ = 1;
                delay(1);
                flag = DQ;
                if(flag == 1)
                        temp2= temp2|0x80;
                delay(7);
                DQ = 1;
                _nop_();
                _nop_();
        return temp2;
//写字节
void writeonebyte(uchar date)
        uchar temp1= 0, i = 0;
        temp1= date;
                DQ = 0
                delay(2);
                DQ = temp1 & 0x01;
                delay(7);
                DQ = 1;
                temp1= temp1>>1;
void readtemp()
        uchar a=0,b=0;
        init_18b20();
        writeonebyte(0xcc);
        writeonebyte(0x44);
        delay1(1000);
        init_18b20();
        writeonebyte(0xcc);
        writeonebyte(0xbe);
        a=readonebyte();
        delay1(5);
        b=readonebyte();
        temp=b;
        temp<<=8;
        temp=temp|a;
        tt=temp*0.0625;
void display(uint temp1)                        //显示程序
        dula=1;
        P0=table[temp1/1000];
        dula=0;
        P0=0xff;
        wela=1;
        P0=0xfe;
        wela=0;
        delay(5);
/*        dula=1;
        P0=table[temp%100/10+10];
        dula=0;
        P0=0xff;
        wela=1;
        P0=0xfd;
        wela=0;
        delay(5);
        dula=1;
        P0=table[temp%100%10];
        dula=0;
        P0=0xff;
        wela=1;
        P0=0xfb;
        wela=0;
        delay(5);*/
                readtemp();
                display(temp);
