short-Cricuit Constraint;Between Polygon Region (0 holes(s))AD PCB板子DRC时出错
查看数: 10214 | 评论数: 2 | 收藏 0
发布时间: 2018-1-23 19:52
AD求助~PCB板子DRC时出现这个错误一直找不到 short-Cricuit Constraint;Between Polygon Region (0 holes(s)) Bottom Layer And Via(55.067mm,39.548mm)from Top Layer to Bottom Layer Location:[X = 0mm][Y = 0mm ...
ID:939211 发表于 2021-6-17 11:19
我把覆铜去掉再重新画线,就解决了
ID:379554 发表于 2018-7-26 17:40
怎么解决的啊?我也遇到了
