Error[Pe147]: declaration is incompatible with "__interwork __softfp...
查看数: 8038 | 评论数: 1 | 收藏 0
发布时间: 2018-3-7 17:33
使用IAR 6.4(7.0)编译工程报错 Error[Pe147]: declaration is incompatible with "__interwork __softfp unsigned long __get_PSP(void)" 把core_cm3.h里面这句给注释掉,然后加上一句 #if defined (__IC ...
ID:1 发表于 2018-11-7 00:58
好资料,51黑有你更精彩!!!
