按键切换流水灯模式问题(单片机外部中断)
查看数: 6785 | 评论数: 3 | 收藏 0
发布时间: 2018-3-7 18:59
如图,想用一个按键切换流水灯的多种流动模式,但是单片机程序不会,不知道是否需要用到中断。新手不是很会中断,求教程序如何编写
ID:289136 发表于 2018-3-8 12:56
可以定义一个变量记录按下的次数来控制流动方式
ID:164602 发表于 2018-3-8 08:22
我这里有一个与你说的类似的程序,它是用外部中断来切换点阵显示的程序,你自己看看,学习学习,再变成你自己的程序吧。
#include <reg52.h>
#define uint unsigned int     //宏定义
sbit KEY=P3^4;      //定义画面切换按键,可以不定义,外部中断会自己认的
uchar KY;
uchar disp;
uchar pic=0,num=0;      //pic为按键次数;num为中断次数
uchar code love[] = {
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0x3F,0x00,0x20,0x00,0x20,0x00,0x20,
0x00,0x20,0x00,0x20,0x00,0x20,0x00,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0x0F,
0x04,0x10,0x02,0x20,0x02,0x20,0x02,0x20,0x02,0x20,0x04,0x10,0xF8,0x0F,0x00,0x00,
0x00,0x00,0x00,0x00,0xFE,0x07,0x00,0x08,0x00,0x10,0x00,0x20,0x00,0x20,0x00,0x10,
0x00,0x08,0xFE,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0x3F,0x82,0x20,0x82,0x20,
0x82,0x20,0x82,0x20,0x82,0x20,0x82,0x20,0x82,0x20,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*LOVE*/
uchar code loveyou[] = {
0x78,0x00,0xFC,0x00,0xFE,0x01,0xFE,0x03,0xFE,0x07,0xFE,0x0F,0xFE,0x1F,0xFC,0x3F,
0xF8,0x7F,0xFC,0x3F,0xFE,0x1F,0xFE,0x0F,0xFE,0x07,0xFE,0x03,0xFE,0x01,0xFC,0x00,
0x78,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00/*心形图案*/
uchar code hehe[] = {
0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x01,0x40,0x01,0xC0,0x01,0x00,0x00,0x00,0x00,
0xF0,0x0F,0x08,0x10,0x04,0x20,0x00,0x00,0x00,0x00,0xF0,0x3F,0x08,0x00,0x04,0x00,
0x04,0x00,0x04,0x00,0x08,0x00,0xF0,0x3F,0x00,0x00,0x00,0x00,0x00,0x20,0x00,0x20,
0x00,0x20,0x00,0x20,0x00,0x20,0x00,0x00,0x00,0x00,0xF0,0x3F,0x08,0x00,0x04,0x00,
0x04,0x00,0x04,0x00,0x08,0x00,0xF0,0x3F,0x00,0x00,0x00,0x00,0x04,0x20,0x08,0x10,
0xF0,0x0F,0x00,0x00,0x00,0x00,0xC0,0x01,0x40,0x01,0xC0,0x01,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00/*呵呵o(∩_∩)o图案*/
unsigned char code hanzi[] = {
0x80,0x40,0x40,0x40,0x30,0x42,0x1E,0x42,0x10,0x42,0x10,0x42,0x10,0x42,0xFF,0x7F,
0x10,0x42,0x10,0x42,0x10,0x42,0x10,0x42,0x10,0x42,0x10,0x40,0x00,0x40,0x00,0x00,/*"生",0*/
/* (16 X 16 , 宋体 ) */
0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0xFF,0x82,0x40,0x82,0x40,0x82,0x40,0x82,0x40,
0x82,0x40,0x82,0x40,0x82,0x40,0xFE,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"日",1*/
0x00,0x01,0xE0,0x00,0x00,0x00,0xFF,0xFF,0x10,0x00,0x20,0x81,0x08,0x41,0x08,0x31,
0x08,0x0D,0xFF,0x03,0x08,0x0D,0x08,0x31,0xF8,0x41,0x00,0x81,0x00,0x81,0x00,0x00,/*"快",2*/
0x00,0x00,0x00,0x20,0xE0,0x10,0x9C,0x08,0x84,0x06,0x84,0x40,0x84,0x80,0xF4,0x7F,
0x82,0x00,0x82,0x00,0x83,0x02,0x82,0x04,0x80,0x08,0x80,0x30,0x00,0x00,0x00,0x00,/*"乐",3*/
0x20,0x00,0x24,0x08,0x24,0x48,0x24,0x84,0xFE,0x7F,0x23,0x02,0x22,0x41,0x20,0x40,
0x20,0x20,0xFF,0x13,0x20,0x0C,0x22,0x14,0x2C,0x22,0xA0,0x41,0x20,0xF8,0x00,0x00,/*"我",4*/
0x80,0x00,0x64,0x41,0x2C,0x21,0x34,0x91,0x24,0x89,0x24,0x87,0xEC,0x4D,0x32,0x55,
0x22,0x25,0x22,0x25,0x32,0x55,0x2E,0x4D,0x23,0x81,0xA2,0x80,0x60,0x80,0x00,0x00,/*"爱",5*/
0x00,0x01,0x80,0x00,0x60,0x00,0xF8,0xFF,0x07,0x00,0x40,0x10,0x20,0x0C,0x18,0x03,
0x0F,0x40,0x08,0x80,0xC8,0x7F,0x08,0x00,0x08,0x01,0x28,0x06,0x18,0x18,0x00,0x00,/*"你",6*/
0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0x33,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"!",7*/
}; //汉字编码
/********显示编码END*******************/
/**********函数声明******************/
void display1(void); //显示汉字子函数
void display2(void); //显示LOVE图案子函数
void display3(void); //显示心形图案子函数
void display4(void); //显示笑脸图案子函数
/*********n(us)延时子程序***********/
void DelayUs(uint M)
    uint x;
    for(x=0;x<=M;x++);
/**********INT0中断服务程序***********/
void intersvr0(void) interrupt 0 using 1
    KY=~KY;  //每个摇动来回水银开关会在摆幅两端分别产生下降沿中断,只提取其中一次(从左向右摇才显示)
    if(KY==0)
        num++;      //计算中断次数
        switch(pic)       //选择画面
            case 0:
                display1();break;
            case 1:
                display2();break;
            case 2:
                display3();break;
            case 3:
                display4();break;
            default:
                display1();
/*********显示子程序1(汉字)*********/
void display1(void)
    uchar i;
    if(num>10)
        disp++;
        num=0;
    }      //12个汉字分为3次显示完(每次显示4个),每中断10次切换
    if(disp>=2)
    disp=0;
    DelayUs(3400);      //此处延时时间依各硬件差别而各不相同,试着调整使得显示内容居中即可
    for(i=0;i<64;i++)
        P1=~hanzi[disp*128+i*2];
        P2=~hanzi[disp*128+i*2+1];
        DelayUs(95);
        P2=0xff;
        P1=0xff;
/***********显示子程序2(LOVE)********/
void display2(void)
    uchar i;
    DelayUs(2000);
    for(i=0;i<64;i++)
        P1=~love[i*2];
        P2=~love[i*2+1];
        DelayUs(130);
/*******显示子程序3(心形图案)*******/
void display3(void)
    uchar i;
    DelayUs(1100);
    for(i=0;i<64;i++)
        P1=~loveyou[i*2];
        P2=~loveyou[i*2+1];
        DelayUs(200);
/********显示子程序4(呵呵o(∩_∩)o图案)********/
void display4(void)
    uchar i;
    DelayUs(2500);
    for(i=0;i<64;i++)
        P1=~hehe[i*2];
        P2=~hehe[i*2+1];
        DelayUs(120);
/*****主函数*****/
void main(void)
    IT0=1;
    EX0=1;
    EA=1;       //开中断,下降沿中断
    KY=0;
    while(1)      //主程序中只检测按键
        if(KEY==0)      //画面切换键按下
            DelayUs(10000);    //按键去抖
            if(KEY==0);
            pic++;
                        if(pic>3)pic=0;
                        while(KEY==0);
ID:287932 发表于 2018-3-7 22:58
新手求教啊
