求大佬解答下SHT30程序方面的问题
查看数: 5660 | 评论数: 4 | 收藏 0
发布时间: 2018-6-19 21:09
求大佬解答下SHT30 的程序问题
ID:400591 发表于 2019-10-5 20:47
我正在用的SHT30程序,模拟时序:
void IIC_Init(void)
  GPIO_InitTypeDef GPIO_InitStructure;
        RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA|RCC_APB2Periph_AFIO, ENABLE);
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_4|GPIO_Pin_1|GPIO_Pin_0;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
        SCL_1;
        SDA1_1;
        SCL_0;
        SDA1_0;
        SCL_1;
        SDA1_1;
        IIC_SCL_1;
        IIC_SCL_0;
        IIC_SCL_1;
        IIC_SCL_0;
        IIC_SDA1_1;
        IIC_SDA1_0;
        IIC_SDA1_1;
        IIC_SDA1_0;
        IIC_SDA1_1;
        IIC_SDA1_0;
        IIC_SDA1_1;
        IIC_SDA1_0;
        IIC_SDA2_1;
        IIC_SDA2_0;
        IIC_SDA2_1;
        IIC_SDA2_0;
        IIC_SDA3_1;
        IIC_SDA3_0;
        IIC_SDA3_1;
        IIC_SDA3_0;
        IIC_SDA4_1;
        IIC_SDA4_0;
        IIC_SDA4_1;
        IIC_SDA4_0;
调用方式:void I2Cstart(void)
void I2CStart1(void)
  SDA1_1;
  SCL_1;
  Delay_Nus(N1);
  SDA1_0;
  Delay_Nus(N1);
  SCL_0;
void I2CStart2(void)
  SDA2_1;
  SCL_1;
  Delay_Nus(N1);
  SDA2_0;
  Delay_Nus(N1);
  SCL_0;
void I2CStart3(void)
  SDA3_1;
  SCL_1;
  Delay_Nus(N1);
  SDA3_0;
  Delay_Nus(N1);
  SCL_0;
void I2CStart4(void)
  SDA4_1;
  SCL_1;
  Delay_Nus(N1);
  SDA4_0;
  Delay_Nus(N1);
  SCL_0;
停止:void I2CStop(void)
void I2CStop1(void)
  SCL_0;
  SDA1_0;
  Delay_Nus(N1);
  SCL_1;  Delay_Nus(N2);
  SDA1_1;//stop
  Delay_Nus(N1);
void I2CStop2(void)
  SCL_0;
  SDA2_0;
  Delay_Nus(N1);
  SDA2_1;//stop
  Delay_Nus(N1);
void I2CStop3(void)
  SCL_0;
  SDA3_0;
  Delay_Nus(N1);
  SDA3_1;//stop
  Delay_Nus(N1);
void I2CStop4(void)
  SCL_0;
  SDA4_0;
  Delay_Nus(N1);
  SDA4_1;//stop
  Delay_Nus(N1);
应答:void SendAck(void)
主器件为接收方,从器件为发送方,应答信号
void SendAck1(void)
  SCL_0;
  SDA1_0;//低电平表示应答
  Delay_Nus(N1);
  SCL_1;
  Delay_Nus(N1);
  SCL_0;
void SendAck2(void)
  SCL_0;
  SDA2_0;//低电平表示应答
  Delay_Nus(N1);
  SCL_1;
  Delay_Nus(N1);
  SCL_0;
void SendAck3(void)
  SCL_0;
  SDA3_0;//低电平表示应答
  Delay_Nus(N1);
  SCL_1;
  Delay_Nus(N1);
  SCL_0;
void SendAck4(void)
  SCL_0;
  SDA4_0;//低电平表示应答
  Delay_Nus(N1);
  SCL_1;
  Delay_Nus(N1);
  SCL_0;
非应答:void SendNotAck(void)
主器件为接收方,从器件为发送方
void SendNotAck1(void)
  SCL_0;
  SDA1_1;//高电平表示非应答
  Delay_Nus(N1);
  SCL_1;
  Delay_Nus(N1);
  SCL_0;
void SendNotAck2(void)
  SCL_0;
  SDA2_1;//高电平表示非应答
  Delay_Nus(N1);
  SCL_1;
  Delay_Nus(N1);
  SCL_0;
void SendNotAck3(void)
  SCL_0;
  SDA3_1;//高电平表示非应答
  Delay_Nus(N1);
  SCL_1;
  Delay_Nus(N1);
  SCL_0;
void SendNotAck4(void)
  SCL_0;
  SDA4_1;//高电平表示非应答
  Delay_Nus(N1);
  SCL_1;
  Delay_Nus(N1);
  SCL_0;
等待应答?unsigned char WaitAck(void)
等待从器件接收方的应答
unsigned char WaitAck1(void)
        unsigned char errtime=255;//因故障接收方无ACK,超时值为255
  SDA1_1;//SDA,SCL均高,释放数据线准备接收应答
  SCL_1;
  Delay_Nus(N1);
  //切换为输入
  // {GPIOA->CRL&=0XFF0FFFFF;GPIOA->CRL|=(u32)8<<20;}//利用上拉此行可省略
  while(GPIOA->IDR&PIN_SDA1)//判断从设备输出SDA是否为1,
    errtime--;
    if(!errtime){I2CStop1();SystemError=0x11;return 0;}
  SCL_0;Delay_Nus(N1);
  return 1;
unsigned char WaitAck2(void)
  SDA2_1;//SDA,SCL均高,释放数据线准备接收应答
  SCL_1;
  Delay_Nus(N1);
  //切换为输入
  while(GPIOA->IDR&PIN_SDA2)//判断从设备输出SDA是否为1,
    errtime--;
    if(!errtime){I2CStop2();SystemError=0x11;return 0;}
  return 1;
unsigned char WaitAck3(void)
  SDA3_1;//SDA,SCL均高,释放数据线准备接收应答
  SCL_1;
  Delay_Nus(N1);
  //切换为输入
  while(GPIOA->IDR&PIN_SDA3)//判断从设备输出SDA是否为1,
    errtime--;
    if(!errtime){I2CStop3();SystemError=0x11;return 0;}
  return 1;
unsigned char WaitAck4(void)
  SDA4_1;//SDA,SCL均高,释放数据线准备接收应答
  SCL_1;
  Delay_Nus(N1);
  //切换为输入
  while(GPIOA->IDR&PIN_SDA4)//判断从设备输出SDA是否为1,
    errtime--;
    if(!errtime){I2CStop4();SystemError=0x11;return 0;}
  return 1;
发送字节:void I2CSendByte(unsigned char ch)
发送一个字节
void I2CSendByte1(unsigned char ch)
  unsigned char i=8;
  while(i--)
    if((ch&0x80)==0x80){SDA1_1;}//字节的最高位为1,SDA=1,否则SDA=0
    else{SDA1_0;}
    ch<<=1;
    Delay_Nus(N1);
    SCL_1;
    Delay_Nus(N1);
    SCL_0;
    Delay_Nus(N1);
void I2CSendByte2(unsigned char ch)
  unsigned char i=8;
  while(i--)
    if((ch&0x80)==0x80){SDA2_1;}//字节的最高位为1,SDA=1,否则SDA=0
    else{SDA2_0;}
    ch<<=1;
    Delay_Nus(N1);
    SCL_1;
    Delay_Nus(N1);
    SCL_0;
    Delay_Nus(N1);
void I2CSendByte3(unsigned char ch)
  unsigned char i=8;
  while(i--)
    if((ch&0x80)==0x80){SDA3_1;}//字节的最高位为1,SDA=1,否则SDA=0
    else{SDA3_0;}
    ch<<=1;
    Delay_Nus(N1);
    SCL_1;
    Delay_Nus(N1);
    SCL_0;
    Delay_Nus(N1);
void I2CSendByte4(unsigned char ch)
  unsigned char i=8;
  while(i--)
    if((ch&0x80)==0x80){SDA4_1;}//字节的最高位为1,SDA=1,否则SDA=0
    else{SDA4_0;}
    ch<<=1;
    Delay_Nus(N1);
    SCL_1;
    Delay_Nus(N1);
    SCL_0;
    Delay_Nus(N1);
接收字节:Byte I2CReceieveByte(void)
接收一个字节
unsigned char I2CReceieveByte1(void)
  unsigned char i=8;
  unsigned char ddata=0;
  SDA1_1;
  while(i--)
    ddata<<=1;
    SCL_0;
    Delay_Nus(N1);//等待从器件送出数据
    SCL_1;
    Delay_Nus(N1);
    //切换为输入
                if(READ_SDA1)ddata++;//非0,
    Delay_Nus(N1);
  return ddata;
unsigned char I2CReceieveByte2(void)
  unsigned char i=8;
  SDA2_1;
  while(i--)
    ddata<<=1;
    SCL_0;
    SCL_1;
    Delay_Nus(N1);
    //切换为输入
                if(READ_SDA2)ddata++;//非0,
    Delay_Nus(N1);
  return ddata;
unsigned char I2CReceieveByte3(void)
  unsigned char i=8;
  SDA3_1;
  while(i--)
    ddata<<=1;
    SCL_0;
    SCL_1;
    Delay_Nus(N1);
    //切换为输入
                if(READ_SDA3)ddata++;//非0,
    Delay_Nus(N1);
  return ddata;
unsigned char I2CReceieveByte4(void)
  unsigned char i=8;
  SDA4_1;
  while(i--)
    ddata<<=1;
    SCL_0;
    SCL_1;
    Delay_Nus(N1);
    //切换为输入
                if(READ_SDA4)ddata++;//非0,
    Delay_Nus(N1);
  return ddata;
void SHT_INI(void)
  I2CStart1();
  I2CSendByte1(0x88);//器件的写地址
    Delay_Nus(N2);
  WaitAck1();
  I2CSendByte1(0x20);//
    Delay_Nus(N2);
  WaitAck1();
  I2CSendByte1(0x2F);//
    Delay_Nus(N2);
  WaitAck1();
void SHT_SoftReset(void)
  I2CStart1();
    Delay_Nus(N2);
  WaitAck1();
  I2CSendByte1(0x30);//
    Delay_Nus(N2);
  WaitAck1();
  I2CSendByte1(0xA2);//
    Delay_Nus(N2);
  WaitAck1();
  I2CStop1();}
void SHT_Heat(void)
  I2CStart1();
    Delay_Nus(N2);
  WaitAck1();
    Delay_Nus(N2);
  WaitAck1();
  I2CSendByte1(0x6D);//
    Delay_Nus(N2);
  WaitAck1();
  I2CStop1();
void SHT_DisHeat(void)
  I2CStart1();
    Delay_Nus(N2);
  WaitAck1();
    Delay_Nus(N2);
  WaitAck1();
  I2CSendByte1(0x66);//
    Delay_Nus(N2);
  WaitAck1();
  I2CStop1();
void ReadSHT1(unsigned char ad,unsigned char count,unsigned char *buff)
  unsigned char i;
  I2CStart1();
    Delay_Nus(N2);
  WaitAck1();
  I2CSendByte1(0x2C);//
    Delay_Nus(N2);
  WaitAck1();
  I2CSendByte1(0x06);//
    Delay_Nus(N2);
  WaitAck1();
  I2CStart1();
  I2CSendByte1(0x89);//器件的读地址
    Delay_Nus(N2);
   WaitAck1();
  SCL_1;//释放SCL
  //切换为输入
        //{GPIOA->CRL&=0XFF0FFFFF;GPIOA->CRL|=(u32)8<<20;}//利用上拉此行可省略
  while((GPIOA->IDR&PIN_SCL)==0)//等待转换完毕
  I2CStart1();
    Delay_Nus(N2);
  WaitAck1();
  for(i=0;i<count;i++)//连续读取count个数值
    buff[i]=I2CReceieveByte1();
    if(i!=count-1)SendAck1();//除非最后一个字节,其它都要从MASTER发应答
  SendNotAck1();
  I2CStop1();
ID:400591 发表于 2018-9-20 16:33
楼主,啥问题?
ID:187258 发表于 2018-6-20 22:52
wooooooo 发表于 2018-6-20 10:06
因CPU连接的外围器件较多,一般放在中心区域,外围器件根据与CPU的连接关系而确定布局位置。原则是连线最短 ...
什么意思,请问我这个是程序的问题还是硬件的问题啊,谢谢
ID:354780 发表于 2018-6-20 10:06
因CPU连接的外围器件较多,一般放在中心区域,外围器件根据与CPU的连接关系而确定布局位置。原则是连线最短、过孔最少
