单片机仿真秒表,用五位数码管显示,为什么个位和十位不显示
查看数: 3872 | 评论数: 7 | 收藏 1
发布时间: 2019-5-5 09:52
代码:#include<reg52.h> #define uint unsigned int #define uchar unsigned char sbit key1=P3^0; sbit key2=P3^1; sbit key3=P3^2; uchar temp,aa,m1,m2,m3,shi,ge; uchar code table[]={ 0x3f ...
ID:522450 发表于 2019-5-5 22:03
#include<reg52.h>
sbit key1=P3^0;
sbit key2=P3^1;
sbit key3=P3^2;
uchar temp,m1,m2,m3,shi,ge;uint aa;
0x3f,0x06,0x5b,0x4f, 0x66,0x6d,0x7d,0x07, 0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
void delay(uint z);
void display(uchar m1,uchar m2,uchar m3,uchar shi,uchar ge);
void initial();
  initial();
    if(key1==0)
            delay(10);
            if(key1==0)
            while(!key1);
                  TR0=1;
          if(key2==0)
            delay(10);
            if(key2==0)
            while(!key2);
                  TR0=0;
          if(key3==0)
            delay(10);
            if(key3==0)
              while(!key3);
                    temp=0;
                    m1=0;
                    m2=0;
                    m3=0;
                    shi=0;
                    ge=0;
                    TR0=0;
        display(shi,ge,m3,m2,m1);
void delay(uint z)
  uint x,y;
  for(x=z;x>0;x--)
                for(y=110;y>0;y--);
  P2=0xfd;
  P0=table[m1];
  delay(10);
  P2=0xfe;
  P0=table[m2];
  delay(10);
  P2=0xfb;
  P0=table[m3];
  delay(10);
  P2=0xf7;
  P0=table[ge];
  delay(10);
  P2=0xef;
  P0=table[shi];
  delay(10);
void initial()
  temp=0;
  TMOD=0x01;
  TH0=(65536-500)/256;
  TL0=(65536-500)%256;
  EA=1;
  ET0=1;
timer0() interrupt 1
  aa++;
  m3=aa/100;
  m2=aa%100/10;
  m1=aa%100%10;
  if(aa==999)
    aa=0;
          temp++;
          if(temp==99)
            temp=0;
           shi=temp/10;
           ge=temp%10;
又改了一下,1、显示顺序,2、位选信号,3、aa类型
试试。
ID:522450 发表于 2019-5-5 21:57
哦,忘了,aa的类型确实不对的,要改成uint aa;
其他试试看看
sbit key1=P3^0;
sbit key2=P3^1;
sbit key3=P3^2;
void delay(uint z);
void initial();
  initial();
    if(key1==0)
            delay(10);
            if(key1==0)
            while(!key1);
                  TR0=1;
          if(key2==0)
            delay(10);
            if(key2==0)
            while(!key2);
                  TR0=0;
          if(key3==0)
            delay(10);
            if(key3==0)
              while(!key3);
                    temp=0;
                    m1=0;
                    m2=0;
                    m3=0;
                    shi=0;
                    ge=0;
                    TR0=0;
        display(m1,m2,m3,shi,ge);
void delay(uint z)
  uint x,y;
  for(x=z;x>0;x--)
                for(y=110;y>0;y--);
{  P2=0xfb;
  P0=table[m1];
  delay(10);
  P2=0xf7;
  P0=table[m2];
  delay(10);
  P2=0xef;
  P0=table[m3];
  delay(10);
  P2=0xfd;
  P0=table[ge];
  delay(10);
  P2=0xfe;
  P0=table[shi];
  delay(10);
void initial()
  temp=0;
  TMOD=0x01;
  EA=1;
  ET0=1;
  aa++;
  m3=aa/100;
  m2=aa%100/10;
  m1=aa%100%10;
  if(aa==1000)
    aa=0;
          temp++;
          if(temp==99)
            temp=0;
           shi=temp/10;
           ge=temp%10;
位选信号搞错了,红色标注了修改过后的,其他的应该问题不大,按照我修改过的运行一次试试,应该没问题的。
ID:527416 发表于 2019-5-5 20:04
yzwzfyz 发表于 2019-5-5 12:22
等至aa=1000的时候,你就看到显示了。耐心等待吧。
1000就是1毫秒呀,很快的ne
ID:213173 发表于 2019-5-5 17:36
错误1:位码错误,应该是0xfe,0xfd,0xfb,0xf7,0xef。
错误2:数据类型错误,应该是uint aa。
错误3:1ms定时数据错误。
当然还有运行中的问题:按键干扰显示,数码管会闪烁等等。
ID:462827 发表于 2019-5-5 12:23
中断函数里shi和ge的获取要放到if(aa==1000)的花括号之外。
