五线四相步进电机,求一个控制程序(实物见图)
查看数: 4169 | 评论数: 3 | 收藏 0
发布时间: 2019-7-22 10:13
电路应该是这样连的吧?
ID:188389 发表于 2019-8-27 21:51
/* 两个ULN2003驱动两个5线4相步进电机 */
/*  步进电机四相端口*/
#define pMotor_A_A_Init()                        GPIO_Init(GPIOC,GPIO_PIN_7,GPIO_MODE_OUT_PP_LOW_FAST)
#define pMotor_A_B_Init()                        GPIO_Init(GPIOC,GPIO_PIN_6,GPIO_MODE_OUT_PP_LOW_FAST)
#define pMotor_A_C_Init()                        GPIO_Init(GPIOC,GPIO_PIN_5,GPIO_MODE_OUT_PP_LOW_FAST)
#define pMotor_A_D_Init()                        GPIO_Init(GPIOC,GPIO_PIN_3,GPIO_MODE_OUT_PP_LOW_FAST)
#define pMotor_B_A_Init()                        GPIO_Init(GPIOD,GPIO_PIN_0,GPIO_MODE_OUT_PP_LOW_FAST)
#define pMotor_B_B_Init()                        GPIO_Init(GPIOD,GPIO_PIN_2,GPIO_MODE_OUT_PP_LOW_FAST)
#define pMotor_B_C_Init()                        GPIO_Init(GPIOD,GPIO_PIN_3,GPIO_MODE_OUT_PP_LOW_FAST)
#define pMotor_B_D_Init()                        GPIO_Init(GPIOD,GPIO_PIN_4,GPIO_MODE_OUT_PP_LOW_FAST)
                                                 /*  A   AB   B    BC   C    CD   D    DA  */
uint8_t Beat_A_Code[8] = {0x80,0xC0,0x40,0x60,0x20,0x28,0x08,0x88}; //步进电机A四相八拍驱动
uint8_t Beat_B_Code[8] = {0x01,0x05,0x04,0x0C,0x08,0x18,0x10,0x11}; //步进电机B四相八拍驱动
int16_t motor_A_Beats = 0;
int16_t motor_B_Beats = 0;
uint8_t index_A = 0;
uint8_t index_B = 0;
#pragma vector=0x19
__interrupt void TIM4_UPD_OVF_IRQHandler(void) //定时中断 1ms
        /* 步进电机A转动控制流量值大于4L */
        if(motor_A_Beats != 0)
                if(motor_A_Beats > 0)                //正转
                        index_A++;
                        index_A &= 0x07;
                        motor_A_Beats--;
                else                                            //反转
                        index_A--;
                        index_A &= 0x07;
                        motor_A_Beats++;
                temp0 = GPIOC->ODR;
                temp0 &= 0x17;
                temp0 |= Beat_A_Code[index_A];
                GPIOC->ODR = temp0;
                GPIOC->ODR &= 0x17;
        /* 步进电机B转动控制流量值小于等于4L */
        if(motor_B_Beats != 0)
                if(motor_B_Beats > 0)                //正转
                        index_B++;
                        index_B &= 0x07;
                        motor_B_Beats--;
                else                                                //反转
                        index_B--;
                        index_B &= 0x07;
                        motor_B_Beats++;
                temp2  = GPIOD->ODR;
                temp2 &= 0xE2;
                temp2 |= Beat_B_Code[index_B];
                GPIOD->ODR = temp2;
                GPIOD->ODR &= 0xE2;
        TIM4_ClearITPendingBit(TIM4_IT_UPDATE);
/*  步进电机四相端口*/
#pragma vector=0x19
                        index_A++;
                        index_A &= 0x07;
                        motor_A_Beats--;
                else                                            //反转
                        index_A--;
                        index_A &= 0x07;
                        motor_A_Beats++;
                temp0 = GPIOC->ODR;
                temp0 &= 0x17;
                GPIOC->ODR = temp0;
                GPIOC->ODR &= 0x17;
                        index_B++;
                        index_B &= 0x07;
                        motor_B_Beats--;
                else                                                //反转
                        index_B--;
                        index_B &= 0x07;
                        motor_B_Beats++;
                temp2  = GPIOD->ODR;
                temp2 &= 0xE2;
                GPIOD->ODR = temp2;
                GPIOD->ODR &= 0xE2;
ID:603085 发表于 2019-8-25 15:48
我的这一个是用uln2003驱动电路的
  1. #include <reg52.h>
  3. sbit jia_key=P3^7;         //定义加键
  4. sbit jian_key=P3^6;          //定义减键
  5. sbit zf_key=P3^5;          //定义正反键
  6. //sbit dula=P2^6;                  //数码管段选端定义
  7. //sbit wela=P2^7;                  //数码管位选端定义
  8. bit flag=0;                          //定义正反转的
  9. uchar num=0,show_num=2,maichong=4,table_begin=0;
  10. uchar code table1[]={0x01,0x02,0x04,0x08,0x08,0x04,0x02,0x01};        //在从0x01到0x08表示正转,从0x08到0x01表示反转,
  11. uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};//数码管显示数
  12. void delay(uchar i)        //延时函数
  13. {
  14.         uchar j,k;
  15.         for(j=i;j>0;j--)
  16.                 for(k=125;k>0;k--);
  17. }
  18. /*void display()
  19. {
  20.         dula=0;
  21.         P0=table[show_num];
  22.         dula=1;
  23.         dula=0;
  24.         wela=0;
  25.         P0=0XFE;
  26.         wela=1;
  27.         wela=0;
  28.         delay(5);
  29.         P0=table[0];
  30.         dula=1;
  31.         dula=0;
  32.         P0=0XFd;
  33.         wela=1;
  34.         wela=0;
  35.         delay(5);
  36. }  */
  37. void key()                //确定按键
  38. {
  39.         if(jia_key==0)
  40.         {
  41.                 delay(5);
  42.                 if(jia_key==0)
  43.                 {
  44.                         num++;
  45.                         if(num==4)
  46.                                 num=3;
  47.                         while(jia_key==0);
  48.                 }
  49.         }
  50.         if(jian_key==0)
  51.         {
  52.                 delay(5);
  53.                 if(jian_key==0)
  54.                 {
  55.                         if(num!=0)
  56.                         num--;
  57.                         else
  58.                                 num=0;
  59.                         while(jian_key==0);
  60.                 }
  61.         }
  62.         if(zf_key==0)
  63.         {
  64.                 delay(5);
  65.                 if(zf_key==0)
  66.                 {
  67.                         flag=~flag;
  68.                         while(zf_key==0);
  69.                 }
  70.         }
  71. }
  72. void dispose()                                //对按键的处理
  73. {
  74.         switch(num)
  75.         {
  76.                 case 0:
  77.                                 maichong=5;
  78.                                 break;
  79.                 case 1:
  80.                                 maichong=4;
  81.                                 break;
  82.                 case 2:
  83.                                 maichong=3;
  84.                                 break;
  85.                 case 3:
  86.                                 maichong=2;
  87.                                 break;
  88.         }
  89.         if(flag==0)                                         //正反变化的表示
  90.                 table_begin=0;
  91.         else
  92.                 table_begin=4;
  93. }
  94. void qudong()                //驱动电机转动,最重要的部分
  95. {
  96.         uchar j;
  97.         for(j=0+table_begin;j<4+table_begin;j++)
  98.         {
  99.                 P0=table1[j];        //控制正反转的
  100.                 delay(maichong*5);//控制速度的
  101.         }
  102. }
  103. void main()        //主函数
  104. {
  105.         while(1)
  106.         {
  107.                 key();
  108.                 dispose();
  109.                 qudong();
  110.         }
  111. }
