单片机LCD1602汉字显示中文及详细注释 显示年月日汉字
查看数: 13688 | 评论数: 3 | 收藏 3
发布时间: 2020-6-10 17:09
1602是液晶显示内容,汉字显示对于初学者来说,有较大难度,我在学习过程中对前人的程序做了详细注释。希望可以帮助到列位黑友。
ID:319868 发表于 2021-5-23 11:42
上面各位遇到的问题我解决了,没有用忙判断。楼主有两个错误,一是写命令和写数据时序有问题,二是中文写入地址有问题,所以楼主的“日”字显示不出来,“年”地址是0x40,“月”地址是0x48,“日”地址应该是0x50,而不是0x56,因为是十六进制。代码如下:
3ìDò1|Äü£oÔúLCDéÏÏÔê¾2013Äê08ÔÂ21èÕ
          I Love Mcu
          Author
          x x x
******************í·ÎļtéùÃ÷**********************************************/
#include <reg51.h>
#include <intrins.h>
/*********************************¶Ë¿ú¶¨òå**********************************/
sbit rs=  P3^5;
sbit rw = P3^6;
sbit en = P3^4;
sbit busy=P1^7;
/********************************ÏÔê¾êy¾Y±í*********************************/
unsigned char day[]={0x1f,0x11,0x11,0x1f,0x11,0x11,0x1f,0x00}; //èÕμÄ×Ö·û±í
unsigned char month[]={0x1f,0x11,0x1d,0x11,0x1d,0x11,0x11,0x00}; //ÔÂμÄ×Ö·û±í
unsigned char year[] ={0x40,0x0f,0x12,0x0f,0x0a,0x1f,0x02,0x02}; //ÄêμÄ×Ö·û±í
unsigned char one[]={0x00,0x00,0x00,0x1F,0x00,0x00,0x00,0x00};//ò»
unsigned char two[]={0x00,0x00,0x0E,0x00,0x1F,0x00,0x00,0x00};//¶t
unsigned char three[]={0x00,0x1F,0x00,0x0E,0x00,0x1F,0x00,0x00};//èy
unsigned char time[] ={"20130821"};
unsigned char code1[]={"I Love Mcu"};
unsigned char author[]={"Author"};
unsigned char name[]={"X X X"};
oˉêy1|Äü:LCDÑóê±×ó3ìDò
void Delay(unsigned char x)
   int i,j;
   for(i=x;i>0;i--)
     for(j=110;j>0;j--);
oˉêy1|Äü£o2aêÔLCD×′ì¬êÇ·ñÃ|Âμ
¼ì2aÔ-òò£oμ¥Ƭ»ú′|àíËù¶è½Ï¿ì£¬¶øLCDμÄ′|àíËù¶è½ÏÂy
//bit lcd_check_busy()
//        P1=0Xff;
//        rs = 0;//Ö»òaéèÖÃáËrs=0,rw=1,¾íêÇòa¶áBFλ
//        rw = 1;
//        en = 0;
//        _nop_(); //ÕaèyDDμÄ×÷óÃêǽøDDò»¸ö¿Õ2ù×÷£¬¶áBFêyÖ죬è»oóê1Äüêä3öBFÖμ
//        en=1;
//        return busy; //èç1ûLCDÃ|£¬¾í·μ»ØÃ|(BF=1)
oˉêy1|Äü:D′Ö¸áîμ½LCD×ó3ìDò
void lcd_wcmd(unsigned char cmd)
//  while(lcd_check_busy()); //ÅD¶ÏLCDêÇ·ñÃ|Â죬Ã|2ÅD′¡£ÎòÔø¾-¸Ä3飡lcd_check_busy()£¬ÎT·¨Õy3£ÏÔê¾
        rs = 0;   //D′Ö¸áî(Ö»òars = 0,rw = 0¾íêÇD′Ö¸áî)
        rw = 0;
        en = 1;
        P1 = cmd;
        _nop_();
        Delay(5);
        en = 0;
oˉêy1|Äü:D′êy¾Yμ½LCD×ó3ìDò
void lcd_wdat(unsigned char dat)
        rs = 1;  //D′êy¾Y(Ö»òars = 1,rw = 0¾íêÇD′Ö¸áî)
        rw = 0;
        en = 1;
        P1 = dat;//Ïèê1Äü£¬2ÅÄü¶ádatêy¾Y
        _nop_();
        Delay(5);
        en = 0;
oˉêy1|Äü:é趨ÏÔê¾Î»ÖÃ×ó3ìDò
void lcd_pos(unsigned char pos)
        lcd_wcmd(pos | 0x80);//DDRAMμØÖ·éèÖã¬0x80=1000 0000£¬N = 1,·Öá½DDÏÔê¾£¬
        Delay(50);
}                        //ê×DDA6-A0=00H-2FH|posÖ죬′ÎDDA6-A0 = 40H-67H|posÖμ
oˉêy1|Äü:LCD3õê¼»ˉ×ó3ìDò£¨óD¸öòéÎ꣬3õê¼»ˉ3ìDò£¬Îaê2Ã′ÏÔ꾿a1Ø2»Ö±½óéèÎa0x0c£¿
                          êÇ2»êÇòòÎaòaÏèè«2¿1رÕ£¬2ÅÄüÇåÆá£¿£©
void lcd_init()  // òÔÏÂÖ¸áîÃûlcd_wcmdÖ»êÇóD¸öÃû×Ö¶øòÑ£¬0x38μè2ÅêÇ1ؼü
        lcd_wcmd(0x38);    //1|ÄüéèÖão8λêy¾Y£¬Ë«DDÏÔê¾£¬5*7μãÕó
        lcd_wcmd(0x08);    //ÏÔ꾿a1ØéèÖãoÏÔê¾1رÕ£¬ÎT1a±ê£¬2»éá˸--Ïè1رÕ
        lcd_wcmd(0x01);    //ÇåÆá
        lcd_wcmd(0x06);    //êäèë·½ê½éèÖão1a±ê×Ô¶ˉÔöò»
        Delay(100);
        lcd_wcmd(0x0c);    //ÏÔ꾿a1ØéèÖãoÏÔ꾿aÆô£¬ÎT1a±ê£¬2»éá˸--Ôù¿aÆô
oˉêy1|Äü£o½¨á¢ÄêÔÂèÕ×Ö·û
void lcd_setup()    //Ï轨á¢ÄêÔÂèÕ×Ö·û
        unsigned int i;
        lcd_wcmd(0x40);   //1|ÄüéèÖÃP0=0x40=0010 0000£¬4룬ò»DDÏÔê¾£¬5*7μãÕóÏÔê¾
        for(i=0;i<8;i++)
    lcd_wdat(year[i]);
                Delay(50);
        lcd_wcmd(0x48);
        for(i=0;i<8;i++)
                lcd_wdat(month[i]);
                Delay(50);
        lcd_wcmd(0x50);
        for(i=0;i<8;i++)
                lcd_wdat(day[i]);
                Delay(50);
        lcd_wcmd(0x58);
        for(i=0;i<8;i++)
                lcd_wdat(one[i]);
                Delay(50);
        lcd_wcmd(0x60);
        for(i=0;i<8;i++)
                lcd_wdat(two[i]);
                Delay(50);
        lcd_wcmd(0x68);
        for(i=0;i<8;i++)
                lcd_wdat(day[i]);
                Delay(50);
oˉêy1|Äü:Ö÷3ìDò
void main(void)
        unsigned char i;
        lcd_init();               //3õê¼»ˉLCD
  lcd_setup();              //½¨á¢×Ö·û
          lcd_pos(0x00);
                for(i=0;i<4;i++)
                        lcd_wdat(time[i]);     //ÏÔê¾2013
                lcd_pos(0x04);             //éèÖÃÆeê¼μØÖ·êÇ0x05£¬0x05|0x80=0x85
                lcd_wdat(0x00);            //D′Ö¸áP0=0x00
                lcd_pos(0x06);  //éèÖÃÆeê¼μØÖ·êÇ0x07£¬0x05|0x80=0x87
                for(i=4;i<6;i++)
                        lcd_wdat(time[i]);     //ÏÔê¾08
                lcd_pos(0x09);             //éèÖÃÆeê¼μØÖ·êÇ0x0a£¬0x0a|0x80=0x8a
                lcd_wdat(0x01);            //D′êy¾Y£¬P0=0x01
                lcd_pos(0x0b);            //éèÖÃÆeê¼μØÖ·êÇ0x0c£¬0x0c|0x80=0x8c
                for(i=6;i<8;i++)
                        lcd_wdat(time[i]);    //ÏÔê¾21
                lcd_pos(0x0e);            //éèÖÃÆeê¼μØÖ·êÇ0x0f£¬0x0f|0x80=0x8f
                lcd_wdat(0x02);           //D′êy¾Y£¬P0=0x02
                lcd_pos(0x43);            //éèÖÃÆeê¼μØÖ·êÇ0x43£¬0x43|0x80=0xc3
                for(i=0;i<10;i++)
                        lcd_wdat(code1[i]); //ÏÔê¾I Love Mcu
//                for(i=0;i<17;i++)
//                        lcd_wcmd(0x18); //0001 1000ÏÔê¾×Ö·ûƽòÆò»¸ö×Ö·ûλ(0001)£¬
//                        Delay(50);    //ÏÔê¾×Ö·ûÕûìå×óòÆ1λ(1000)
//                lcd_wcmd(0x01);     //ÇåÆá
//                Delay(50);
//                lcd_pos(0x05);
//                Delay(50);
//                for(i=0;i<6;i++)
//                        lcd_wdat(author[i]);
//                        Delay(50);
//                lcd_pos(0x41);
//                Delay(50);
//                for(i=0;i<13;i++)
//                        lcd_wdat(name[i]);
//                        Delay(50);
//                Delay(10);
//                lcd_wcmd(0x01);
ID:753618 发表于 2020-6-11 20:02
是的,需要等一分钟左右,具体原因不清楚。开始怀疑是写指令和数据时判断LCD忙的条件有误,改为非忙后,反而无法显示汉字。
ID:753618 发表于 2020-6-10 19:31
可以显示,但是要过一段时间,具体原因我不清楚。
