8086CPU红绿灯程序 仿真出现了问题 哪位大佬帮我看一下
查看数: 2224 | 评论数: 2 | 收藏 0
发布时间: 2020-12-3 20:36
仿真出现了问题,还没有找到原因,望大佬解惑
ID:851182 发表于 2020-12-3 20:39
; You may customize this and other start-up templates;
; The location of this template is c:\emu8086\inc\0_com_template.txt
org 100h
DATA SEGMENT
     PORTA EQU 218H
     PORTB EQU 219H
     PORTC EQU 21AH
     PTCON8255 EQU 21BH
     PORT0 EQU 238H
     PORT1 EQU 239H
     PORT2 EQU 240H
     PTCON8253 EQU 241H
DATA ENDS
CODE SEGMENT
     ASSUME DS:DATA,CS:CODE
INIT:   MOV AX,DATA
        MOV DS,AX
        MOV DX,PTCON8253
        MOV AL,36H
        OUT DX,AL
        MOV DX,PORT0
        MOV AX,2710H
        OUT DX,AL
        MOV DX,0AH
        OUT DX,AL
        MOV DX,PTCON8253
        MOV AL,71H
        OUT DX,AL
        MOV DX,PTCON8253
        MOV AL,96H
        OUT DX,AL
        MOV DX,PORT2
        MOV AL,64H
        OUT DX,AL
        MOV DX,PTCON8255
        MOV AL,80H
        OUT DX,AL
        MOV DX,PORTA
        MOV AL,0
        OUT DX,AL
        MOV DX,PORTB
        MOV AL,0FH
        OUT DX,AL
        MOV DX,PORTC
        MOV AL,0FH
        OUT DX,AL
STA:    MOV DX,PORTA
        MOV AL,0A0H
        OUT DX,AL
        MOV DX,PORTB
        MOV AL,0F0H
        OUT DX,AL
        MOV DX,PORTC
        MOV AL,50H
        OUT DX,AL
        MOV DX,PORT1
        MOV AX,0BB8H
        OUT DX,AL
        MOV AL,AH
        OUT DX,AL
        SCAN1:MOV AL,0
              MOV DX,PTCON8255
              MOV AL,90H
              OUT DX,AL
              MOV DX,PORTA
              IN  AL,DX
              AND AL,0FH
              CMP AL,1
              JNZ SCAN1
         FLA1:MOV DX,PTCON8255
              MOV AL,80H
              OUT DX,AL
              MOV DX,PORTC
              MOV AL,0F0H
              OUT DX,AL
              MOV DX,PORTB
              MOV AL,50H
              OUT DX,AL
              MOV CX,0
        TEST1:MOV DX,PTCON8255
              MOV AL,82H
              OUT DX,AL
              MOV DX,PORTB
              IN  AL,DX
              AND AL,0FH
              MOV AH,AL
              MOV DX,PTCON8255
              MOV AL,82H
              OUT DX,AL
              MOV DX,PORTB
              IN  AL,DX
              AND AL,0FH
              XOR AL,AH
              ADD CL,AL
              CMP CL,9
              JNZ TEST1
              MOV DX,PTCON8255
              MOV AL,80H
              OUT DX,AL
              MOV DX,PORTA
              MOV AL,50H
              OUT DX,AL
              MOV DX,PORTB
              MOV AL,0F0H
              OUT DX,AL
              MOV DX,PORTC
              MOV AL,0A0H
              MOV DX,PORT1
              MOV AX,0BB8H
              OUT DX,AL
              MOV AL,AH
              OUT DX,AL
        SCAN2:MOV AL,0
              MOV DX,PTCON8255
              MOV AL,90H
              OUT DX,AL
              MOV DX,PORTA
              IN  AL,DX
              AND AL,0FH
              CMP AL,1
              JNZ SCAN2
         FLA2:MOV DX,PTCON8255
              MOV AL,80H
              OUT DX,AL
              MOV DX,PORTC
              MOV AL,0F0H
              OUT DX,AL
              MOV DX,PORTB
              MOV AL,0A0H
              OUT DX,AL
        TEST2:MOV DX,PTCON8255
              MOV AL,88H
              OUT DX,AL
              MOV DX,PORTC
              IN  AL,DX
              AND AL,0FH
              MOV AH,AL
              MOV DX,PTCON8255
              MOV AL,88H
              OUT DX,AL
              MOV DX,PORTC
              IN  AL,DX
              AND AL,0FH
              XOR AL,AH
              ADD CL,AL
              CMP CL,9
              JNZ TEST2
         CODE ENDS
              END STA
ret
