火焰识别Python源码(附带QT界面)opencv QT5环境
查看数: 6263 | 评论数: 9 | 收藏 1
发布时间: 2021-4-18 15:59
火焰识别源码,亲测有用,下载后需要搭建opencv  QT5的环境。不懂得话可以私聊我 # -*- coding: cp936 -*- import sys import threading #线程模块 import cv2 import numpy as np import time import os ...
ID:786205 发表于 2022-5-10 10:01
您好 我在Ubuntu系统里运行您的代码 报错了,错误如下:
QObject::moveToThread: Current thread (0x107c340) is not the object's thread (0x1745370).
Cannot move to target thread (0x107c340)
qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "/home/wyh/.local/lib/python3.8/site-packages/cv2/qt/plugins" even though it was found.
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: xcb, eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, webgl.
您看这该如何解决
ID:58930 发表于 2022-4-20 20:15
建议楼主写一个程序流程,相比会更完美,同时增强自己的文字功底。
ID:512969 发表于 2022-4-16 08:49
具体怎么使用啊楼主
ID:171525 发表于 2022-4-14 17:04
PYTHON 都有哪些库?
ID:661945 发表于 2022-1-29 16:14
图像识别方面的吧~~~
ID:974144 发表于 2021-10-22 14:41
现在好多python代码,早知道不学C语言了
