做的寻迹小车proteus仿真时,出现一个电机正转,一个反转,这是我程序出问题了吗
查看数: 2947 | 评论数: 5 | 收藏 1
发布时间: 2021-4-30 14:02
我用仿真寻迹时,出现一个正转,一个反转, 但仿真蓝牙时,就没有出现这种情况。
ID:96682 发表于 2021-5-1 16:28
用普通的直流电机调换线头就行了
ID:912376 发表于 2021-5-1 16:16
wc86110 发表于 2021-4-30 17:53
问题是没图程序不好找问题
我已经发了代码和原理图,您抽时间看一下,万分感谢
如果还是不明白,您可以留个邮箱,我把仿真程序和程序可以发给你,
ID:912376 发表于 2021-5-1 14:42
#include<reg52.h>
#define uint unsigned int
uchar temp,signal,tt1,t0,t1,t2,t3,t4,t5,t6;
void delay_1ms(uint d)
        uint i;
        while(d--)
                for(i=0;i<75;i++);
void motor_run()                   //电机起动
          P1=0x35;
        delay_1ms(200);
        P1=0x53;
        delay_1ms(10);
/*        ENA=1;
        OUT1=0;
        OUT2=1;
        delay_1ms(800);
        OUT2=0;
        delay_1ms(200);
        ENB=1;
        OUT4=0;
        OUT3=1;
        delay_1ms(800);
        OUT3=0;
        delay_1ms(200);
void motor_left()                         //左进
        P1=0x30;
        delay_1ms(200);
        P1=0x00;
        delay_1ms(20);
void motor_right()                   //右进
        P1=0x05;
        delay_1ms(200);
        P1=0x00;
        delay_1ms(20);
void motor_big_right()                         //粗右进
        P1=0x55;
        delay_1ms(200);
        P1=0x00;
        delay_1ms(20);
void motor_big_left()                                 //粗左转
        P1=0x33;
        delay_1ms(200);
        P1=0x00;
        delay_1ms(20);
void motor_stop()                                        //电机停止
         P1=0x00;
void motor_back()                                        //电机后退
        P1=0x53;
        t0=0;
        t1=0;
        t2=0;
        t3=0;
        t4=0;
        t5=0;
        t6=0;
        tt1=0;
        EA=1;
        ET1=1;
        TR1=1;
        TMOD=0x01;
        TH1=-(1000/256);
        TL1=-(1000%256);
                 temp=P2;
                signal=temp&0xff;                   //得到红外反向信号
                switch(signal)
                        case 0xff:           //无偏差
                                motor_run();
                                t0++;
                                if(t0==10)
                                        t0=0;
                                        motor_left();
                                        motor_right();
                                t1=t2=t3=t4=t5=t6=0;
                                break;
                        case 0xfd:           //1轮右偏
                                motor_big_left();
                                t1++;
                                if(t1==4)
                                        t1=0;
                                        motor_left();
                                t0=t2=t3=t4=t5=t6=0;
                                break;
                        case 0xef:            //4轮左偏
                                motor_big_right();
                                t2++;
                                if(t2==4)
                                        t2=0;
                                        motor_right();
                                t0=t1=t3=t4=t5=t6=0;
                                break;
                        case 0xfb:     //2轮右偏出轨
                        case 0xf9:           //1、2轮右偏
                                motor_big_left();
                                t3++;
                                if(t3==4)
                                        t3=0;
                                        motor_left();
                                t0=t1=t2=t4=t5=t6=0;
//                                delay_1ms(10);
                                break;
                        case 0xdf:           //5左偏出轨
                        case 0xcf:      //4、5轮左偏
                                motor_big_right();
                                t4++;
                                if(t4==4)
                                        t4=0;
                                        motor_right();
                                t0=t1=t2=t3=t5=t6=0;
//                                delay_1ms(10);
                                break;
                        case 0xfe:           //0最右偏出轨
                        case 0xfa:
                                motor_big_left();
                                t5++;
                                if(t5==1)
                                        t5=0;
                                        motor_left();
                                        motor_left();
                                t0=t1=t2=t3=t4=t6=0;
//                                delay_1ms(10);
                                break;
                        case 0xbf:     //6最左偏出轨
                        case 0x9f:
                                motor_big_right();
                                t6++;
                                if(t6==1)
                                        t6=0;
                                        motor_right();
                                        motor_right();
                                t0=t1=t2=t3=t4=t5=0;
//                                delay_1ms(10);
                                break;
                        case 0xeb:         //前两传感器压在黑线上
                        case 0xdb:         //后两传感器压在黑线上
                        case 0xbe:         //中间两传感器压在黑线上
                        case 0xac:                 //前四传感器压在黑线上
                        case 0x9a:                //后四传感器压在黑线上
                                motor_back();
                                delay_1ms(200);
                                motor_stop();
//                                delay_1ms(1000);
                        default:
//                                motor_back();
//                                delay_1ms(50);
//                                motor_left();
//                                motor_right();
                                break;
/*void time1() interrupt 3
        TH1=-(1000/256);
        TL1=-(1000%256);
        tt1++;
        if(tt1==300)
                motor_back();
        //        delay_1ms(1);
                tt1=0;
} */[/code]
ID:96682 发表于 2021-4-30 17:53
问题是没图程序不好找问题
