求大神帮我看下单片机串行口通信实验如何完成?
查看数: 2249 | 评论数: 2 | 收藏 0
发布时间: 2021-6-27 15:52
要求如下:利用AT89S52单片机的串行口通过RS232通信接口与PC机进行通信,让单片机把接收到的每一帧数据(即PC机发送给单片机的每一帧数据)直接再发送给PC机。(串行口波特率设定为9600Bit/s,使用工作方式1)注意: ...
ID:411135 发表于 2021-8-30 14:20
01.#include "reg51.h"
02.#include "LCD1602.h"
03.#include "i2c.h"
04.
05.sbit S1 =P2^1;
06.sbit S4 =P2^2;
07./**********************************
08.  参数声明
09.**********************************/
10.uint F=0;                       //频率
11.uint S=0,Pwm=0,Tra=0,AA=0;      //正弦波 方波 三角波 锯齿波信号
12.uchar zkb=30,bx=1;              //频率加/减 PWM占空比 波形选择
13.uchar t1=0,flagPwm=0,flag1=0;   //标志位
14.uchar  T=0;                     //周期
15.
16.uchar code num[]={ 0x7F,0x82,0x85,0x88,0x8B,0x8F,0x92,0x95,0x98,0x9B,0x9E,0xA1,0xA4,0xA7,0xAA,0xAD
17.        ,0xB0,0xB3,0xB6,0xB8,0xBB,0xBE,0xC1,0xC3,0xC6,0xC8,0xCB,0xCD,0xD0,0xD2,0xD5,0xD7
18.        ,0xD9,0xDB,0xDD,0xE0,0xE2,0xE4,0xE5,0xE7,0xE9,0xEB,0xEC,0xEE,0xEF,0xF1,0xF2,0xF4
19.        ,0xF5,0xF6,0xF7,0xF8,0xF9,0xFA,0xFB,0xFB,0xFC,0xFD,0xFD,0xFE,0xFE,0xFE,0xFE,0xFE
20.        ,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFD,0xFD,0xFC,0xFB,0xFB,0xFA,0xF9,0xF8,0xF7,0xF6
21.        ,0xF5,0xF4,0xF2,0xF1,0xEF,0xEE,0xEC,0xEB,0xE9,0xE7,0xE5,0xE4,0xE2,0xE0,0xDD,0xDB
22.        ,0xD9,0xD7,0xD5,0xD2,0xD0,0xCD,0xCB,0xC8,0xC6,0xC3,0xC1,0xBE,0xBB,0xB8,0xB6,0xB3
23.        ,0xB0,0xAD,0xAA,0xA7,0xA4,0xA1,0x9E,0x9B,0x98,0x95,0x92,0x8F,0x8B,0x88,0x85,0x82
24.        ,0x7F,0x7C,0x79,0x76,0x73,0x6F,0x6C,0x69,0x66,0x63,0x60,0x5D,0x5A,0x57,0x54,0x51
25.        ,0x4E,0x4B,0x48,0x46,0x43,0x40,0x3D,0x3B,0x38,0x36,0x33,0x31,0x2E,0x2C,0x29,0x27
26.        ,0x25,0x23,0x21,0x1E,0x1C,0x1A,0x19,0x17,0x15,0x13,0x12,0x10,0x0F,0x0D,0x0C,0x0A
27.        ,0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x03,0x02,0x01,0x01,0x00,0x00,0x00,0x00,0x00
28.        ,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x02,0x03,0x03,0x04,0x05,0x06,0x07,0x08
29.        ,0x09,0x0A,0x0C,0x0D,0x0F,0x10,0x12,0x13,0x15,0x17,0x19,0x1A,0x1C,0x1E,0x21,0x23
30.        ,0x25,0x27,0x29,0x2C,0x2E,0x31,0x33,0x36,0x38,0x3B,0x3D,0x40,0x43,0x46,0x48,0x4B
31.        ,0x4E,0x51,0x54,0x57,0x5A,0x5D,0x60,0x63,0x66,0x69,0x6C,0x6F,0x73,0x76,0x79,0x7C
32.                  };
33.
34./*********************************
35.  函数声明
36.**********************************/
37.void Fun_Sin();
38.void Fun_Triangle();
39.void Fun_Pwm();
40.void Fun_AA();
41.void TimerInit();
42.void KEY();
43.void Delay10ms();
44.
45./*******************************************
46.            主函数
47.*******************************************/
48.void main()        //主程序
49.{
50.  S1 = 1;
51.  S4 = 1;
52.        LcdInit();       //屏幕初始化
53.  TimerInit();     //定时器初始化
54.
55.        while(1)
56.        {
57.                KEY();                                           //按键检测
58.                switch(bx)
59.                {
60.                  case 1:Fun_Sin();      break;         //正弦波
61.                  case 2:Fun_Triangle(); break;   //三角波
62.                        case 3:Fun_Pwm();      break;         //方波
63.                  case 4:Fun_AA();       break;   //锯齿波
64.                }
65.
66.                if(flag1==1)
67.                {
68.                        T=1*t1;
69.      F=((1*100000)/T);
70.
71.                        LcdWriteCom(0x89);
72.                        LcdWriteData(T%1000/100+'0');
73.                        LcdWriteData(T%100/10+'0');
74.                        LcdWriteData(T%10+'0');
75.
76.                        LcdWriteCom(0x82+0x40);
77.                        LcdWriteData(F%10000/1000+'0');
78.                        LcdWriteData(F%1000/100+'0');                        //个位
79.                        LcdWriteData('.');
80.                        LcdWriteData(F%100/10+'0');          //小数后一位
81.                        LcdWriteData(F%10+'0');          //小数后两位
82.                }
83.                 flag1=0;
84.        }
85.}
86.
87./**********************************
88.           延迟10ms函数
89.**********************************/
90.void Delay10ms()
91.{
92.         uchar a,b,c;
93.    for(c=1;c>0;c--)
94.        for(b=38;b>0;b--)
95.            for(a=130;a>0;a--);
96.}
97./**********************************
98.           按键检测函数
99.**********************************/
100.void KEY()
101.{
102.        if(S1==0)
103.                {
104.                        Delay10ms();
105.                        if(S1==0)
106.                        {
107.                                bx=bx+1;
108.                                flag1=1;        //周期显示标志位
109.        case_1:
110.                                switch(bx)
111.                                {
112.                                        case 1:        LcdWriteCom(0x83);
113.        LcdWriteData('S');
114.        LcdWriteData('i');
115.        LcdWriteData('n');break;
116.                                        case 2:        LcdWriteCom(0x83);
117.        LcdWriteData('T');
118.        LcdWriteData('r');
119.        LcdWriteData('a');break;
120.                                        case 3:        LcdWriteCom(0x83);
121.        LcdWriteData('P');
122.        LcdWriteData('w');
123.        LcdWriteData('m');break;
124.                                        case 4:        LcdWriteCom(0x83);
125.        LcdWriteData('A');
126.        LcdWriteData('A');
127.        LcdWriteData(' ');break;
128.                                        default:bx=1;
129.                                  goto case_1;
130.                                }
131.
132.                        }
133.                        while(!S1);   //检测按键是否松开
134.                }
135.
136.                if(S4==0)
137.                {
138.                        Delay10ms();
139.                        if(S4==0)
140.                        {
141.                                zkb=zkb+10;
142.                                if(zkb>90)
143.                                {
144.                                        zkb=10;
145.                                }
146.
147.                                LcdWriteCom(0x8c+0x40);
148.                                LcdWriteData(zkb%100/10+'0');
149.                                LcdWriteData(zkb%10+'0');
150.                        }
151.                        while(!S4);   //检测按键是否松开
152.                }
153.}
154./**********************************
155.            正弦波1函数
156.**********************************/
157.void Fun_Sin()
158.{
159.        uchar i;
160.        t1=0;   //重置计数标志位
161.        TR0=1;            //开定时
162.        for(i=0;i<255;i++)
163.        {
164.                S=num[i];       //打点赋值
165.
166.                I2cStart();
167.                I2c_write_char(0x90);
168.                I2cAck();
169.                I2c_write_char(0x40);  //控制字 允许模拟输出 不自增单端  0100 0000
170.                I2cAck();
171.                I2c_write_char(S);     //放置需要转换的量
172.                I2cAck();
173.                I2cStop();
174.        }
175.        TR0=0;              //关定时
176.}
177./*******************************
178.          三角波2函数
179.********************************/
180.void Fun_Triangle()
181.{
182.        uchar i;
183.        t1=0;   //重置计数标志位
184.  TR0=1;        //开定时器
185.        for(i=0;i<255;i++)
186.        {
187.                Tra =i;
188.                I2cStart();
189.                I2c_write_char(0x90);
190.                I2cAck();
191.                I2c_write_char(0x40); //控制字 允许模拟输出 不自增单端  0100 0000
192.                I2cAck();
193.                I2c_write_char(Tra);
194.                I2cAck();
195.                I2cStop();
196.        }
197.        for(i=255;i>0;i--)
198.        {
199.                Tra =i;
200.                I2cStart();
201.                I2c_write_char(0x90);
202.                I2cAck();
203.                I2c_write_char(0x40); //控制字 允许模拟输出 不自增单端  0100 0000
204.                I2cAck();
205.                I2c_write_char(Tra);
206.                I2cAck();
207.                I2cStop();
208.        }
209.  TR0=0;         //关定时器
210.}
211./********************************
212.            方波3函数
213.********************************/
214.void Fun_Pwm()
215.{
216.        t1=0;   //重置计数标志位
217.  TR0=1;        //开定时器
218.
219.        for(flagPwm=0;flagPwm<100;flagPwm++)
220.        {
221.                if(flagPwm<zkb) //占空比为%30
222.                {
223.                        Pwm=0;
224.                }
225.                else
226.                {
227.                        Pwm=255;
228.                }
229.
230.                I2cStart();           //DA转换程序
231.                I2c_write_char(0x90);
232.                I2cAck();
233.                I2c_write_char(0x40);//控制字 允许模拟输出 不自增单端  0100 0000
234.                I2cAck();
235.                I2c_write_char(Pwm);
236.                I2cAck();
237.                I2cStop();
238.  }
239.  TR0=0;         //关定时器
240.}
241./***********************************
242.          锯齿波4函数
243.***********************************/
244.void Fun_AA()
245.{
246.        uchar i;
247.        t1=0;   //重置计数标志位
248.  TR0=1;        //开定时器
249.        for(i=255;i>0;i--)
250.        {
251.                AA =i;
252.                I2cStart();
253.                I2c_write_char(0x90);
254.                I2cAck();
255.                I2c_write_char(0x40); //控制字 允许模拟输出 不自增单端  0100 0000
256.                I2cAck();
257.                I2c_write_char(AA);
258.                I2cAck();
259.                I2cStop();
260.        }
261.  TR0=0;         //关定时器
262.}
263./*********************************
264.         定时器初始化函数
265.**********************************/
266.void TimerInit()
267.{
268.        TMOD|=0x01; //定时器0工作方式1
269.
270.        TH0=0xFC;   //  65536-1000+1
271.  TL0=0x18;
272.
273.        ET0=1;
274.        EA=1;       //定时器总开关
275.        TR0=0;      //中断开关
276.}
277./**********************************
278.           定时器中断函数
279.**********************************/
280.void Timer(void) interrupt 1   //中断
281.{
282.//  TR0=0;   //赋初值,定时器需在关闭状态
283.        TH0=0xfc;//  65536-1000+1
284.        TL0=0x18;//
285.//        TR0=1;
286.
287.        t1=t1+1; //计数中断个数 每个中断         1ms
288.
289.}
ID:411135 发表于 2021-8-30 14:18
1C-83-41-13-8C-08
