LCD1602显示实验数值显示有什么好方法
查看数: 1482 | 评论数: 1 | 收藏 1
发布时间: 2021-12-21 23:01
用LCD1602和16个按键实现十进制数的加减乘除四则运算 c是运算结果(即等号后面的数值)有没有比较好的方法显示 两个输入数的范围是0~32767,也就是运算结果范围也很大 从高到低或从低到高提取数字都行 但是要像下图 ...
ID:944932 发表于 2021-12-21 23:21
#include "r_lcd1602drv.h"
#include "r_matrixKeypad.h"
u8 keyValueTab[][2]={
                    {0xee,'1'},{0xed,'2'},{0xeb,'3'},{0xe7,'+'},
                    {0xde,'4'},{0xdd,'5'},{0xdb,'6'},{0xd7,'-'},
                    {0xbe,'7'},{0xbd,'8'},{0xbb,'9'},{0xb7,'*'},
                    {0x7e,'.'},{0x7d,'0'},{0x7b,'='},{0x77,'/'}
u8 GetKeyValue(u32 scanCode)
    int i;
    for(i=0;i<16;i++)
        if(scanCode==keyValueTab[i][0])
            return keyValueTab[i][1];
    return 0;
int main()
    r_lcd1602drv lcd;
    r_matrixKeypad keypad;
    uchar buf[20];
    u32 scanCode;
    float f=0,f1=0;
    u8  datBuf[20];
    u8  datBuf1[20];
    u8  datBufIdx=0;
    u8  datBufIdx1=0;
    u8 keyValue;
    u8 isPoint=0;
    u8 isadd=0;
    u8 isde=0;
    u32 pins[]={Pin3,Pin4,Pin5,Pin6,Pin7,Pin8,Pin9,Pin10};
    u32 rowPins[]={Pin5,Pin6,Pin7,Pin8};
    u32 colPins[]={Pin1,Pin2,Pin3,Pin4};
    InitSystem();
    lcd.SetRsPin(GPIOB,Pin0);
    lcd.SetRwPin(GPIOB,Pin1);
    lcd.SetEnPin(GPIOB,Pin2);
    lcd.SetDataPins(GPIOB,pins,8);
    lcd.Init();
    keypad.SetRowPort(GPIOA,rowPins,4);
    keypad.SetColPort(GPIOA,colPins,4);
    scanCode=keypad.GetScanCode();
        if(scanCode!=0)
          if(isde==1)
            isde=0;
            datBufIdx=0;
            datBufIdx1=0;
            lcd.Init();
            lcd.SetRowCol(0,0);
            for(u8 i=0;i<20;i++)
               datBuf[i]=0;
               datBuf1[i]=0;
          if((isadd=='+')|(isadd=='-')|(isadd=='*')|(isadd=='/'))
           keyValue=GetKeyValue(scanCode);
            if(keyValue>='0'&&keyValue<='9')
                datBuf1[datBufIdx1++]=keyValue;
                lcd.DispChar(keyValue);
            if(keyValue=='.')
                if(isPoint==0)
                    isPoint=1;
          if(isadd==0)
                datBuf[datBufIdx++]=keyValue;
            if(keyValue=='.')
                if(isPoint==0)
                    isPoint=1;
            if((keyValue=='+')|(keyValue=='-')|(keyValue=='*')|(keyValue=='/'))
              isadd=keyValue;
              isPoint=0;
            if(keyValue=='=')
               sscanf((char *)datBuf,"%f",&f);
               sscanf((char *)datBuf1,"%f",&f1);
              switch(isadd)
              case '+':f=f1+f;break;
              case '-':f=f-f1;break;
              case '*':f=f*f1;break;
              case '/':f=f/f1;break;
               lcd.SetRowCol(1,0);
               sprintf((char *)buf,"%.2f",f);
               lcd.DispString(buf);
               isPoint=0;
               datBufIdx=0;
               datBufIdx1=0;
               isde=1;
               isadd=0;
