两个芯片的SPI通信问题?
查看数: 2758 | 评论数: 8 | 收藏 0
发布时间: 2022-10-11 15:42
我使用的是STM32F103C8T6和PCAP01来做SPI1通讯。在使用的过程中发现,SPI1有的时候使用没有问题,通讯正常,有的时候通信失败,SPI1用不了。如果是代码或者硬件有问题,那应该不能通讯,为什么有的时候好用,有的时 ...
ID:391219 发表于 2022-10-12 21:12
188610329 发表于 2022-10-12 12:49
晕死,被带沟里去了, 你说两个芯片SPI通讯, 潜意识就认为 是两个单片机了。弄了半天是 控制器件。
P ...
我都在一个板上,距离很近。我将速度降低,设置为:SPI_BaudRatePrescaler_256。今天试了一天,还是连接不上,前两天还好好的。现在将数值写入,读出来全是0xFF。还有没有其他可能?这个我的初始化代码。
void SPIx_I2Cx_GPIOs_Init(void* bus_type)
        GPIO_InitTypeDef GPIO_InitStructure;
        RCC_APB2PeriphResetCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB |
                         RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD |
                         RCC_APB2Periph_GPIOE | RCC_APB2Periph_AFIO,  DISABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB |
                         RCC_APB2Periph_GPIOE | RCC_APB2Periph_AFIO,  ENABLE);
        //SPI1_NSS
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;//PA4
        GPIO_Init(GPIOA,&GPIO_InitStructure);
  //SPI1_CLK
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;//PA5
  GPIO_Init(GPIOA, &GPIO_InitStructure);
        //SPI_MISO
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;//PA6
        //SPI_MOSI
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;//PA7
        SPI_I2S_DeInit(bus_type);
        //ía2¿ÖD¶Ïêäèë
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;//PD4
  GPIO_Init(GPIOD, &GPIO_InitStructure);
        //SPI ENABLE Æà1à1¤¾ßêä3ö
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;//PD3
        // SPIx Enable = 0 for SPI Mode // SPIx Enable = RSN for GP22
        GPIO_WriteBit(GPIOD, GPIO_Pin_3, Bit_RESET);
void SPIx_I2Cx_Interface_Init(void* bus_type)
        //3õê¼»ˉSPIx½ó¿ú
        SPI_InitTypeDef SPI_InitStructure;
        //RCC_SYSCLKConfig (RCC_SYSCLKSource_HSI);
        //RCC_HCLKConfig (RCC_SYSCLK_Div1);
        RCC_APB2PeriphResetCmd (RCC_APB2Periph_SPI1, DISABLE);
  RCC_APB2PeriphClockCmd (RCC_APB2Periph_SPI1, ENABLE);
        // All are defined in stm32f10x_spi.h
  SPI_InitStructure.SPI_Direction         = SPI_Direction_2Lines_FullDuplex;
  SPI_InitStructure.SPI_Mode              = SPI_Mode_Master;
  SPI_InitStructure.SPI_DataSize          = SPI_DataSize_8b;
  SPI_InitStructure.SPI_CPOL              = SPI_CPOL_Low;
  SPI_InitStructure.SPI_CPHA              = SPI_CPHA_2Edge;//
  SPI_InitStructure.SPI_NSS               = SPI_NSS_Soft;
  // SPI frequence devider
  SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256;
  SPI_InitStructure.SPI_FirstBit          = SPI_FirstBit_MSB;
  // Apply SPIx configuration
  SPI_Init(bus_type, &SPI_InitStructure);
  // Enabling the SPIx Interface
  SPI_Cmd(bus_type, ENABLE);
  // Enabling the NSS Output during transmission
  SPI_SSOutputCmd (bus_type, ENABLE);
        GPIO_WriteBit(GPIOA, GPIO_Pin_4, Bit_SET);
ID:624769 发表于 2022-10-12 12:49
1123qqw 发表于 2022-10-12 10:46
交换的数据为21位的浮点数。我怎么确保从机能收到呢?芯片手册并没有给如何设置,只是给了一个端口,设置 ...
PCAP01 没有用过,不清楚,不过SPI 操控器件, 时好时坏, 无非3个原因
1,线路没接好,有干扰,器件的供电没有,有效的滤波。(检查线路,排除干扰,增加滤波电容,从你的原理图上看,6脚这里应该添加 104电容)
2,主机的 SPI 驱动力不够,距离较远,1/0转换不及时  (添加上拉电阻)
3,SPI 设定的传输速度过快,接近器件的极限值。(降低SPI的速度,测试时建议调到最慢速度。)
ID:391219 发表于 2022-10-12 10:58
yzwzfyz 发表于 2022-10-12 08:27
你要保证,当你发送的时候,对方在收!!
建议用中断方式解决这个问题。
从机是PCAP01芯片,说明手册并没有给我如何设置,只是给了一个启动SPI的方式。
ID:391219 发表于 2022-10-12 10:46
188610329 发表于 2022-10-11 22:21
不是指 SPI 的传输速度 快慢,而是指  SPI  传指令 给 从机, 从机 接受到 指令, 处理,准备数据 回传给主 ...
交换的数据为21位的浮点数。我怎么确保从机能收到呢?芯片手册并没有给如何设置,只是给了一个端口,设置为低电平就能启动SPI通信。
ID:123289 发表于 2022-10-12 08:27
你要保证,当你发送的时候,对方在收!!
建议用中断方式解决这个问题。
ID:624769 发表于 2022-10-11 22:21
不是指 SPI 的传输速度 快慢,而是指  SPI  传指令 给 从机, 从机 接受到 指令, 处理,准备数据 回传给主机,这个过程需要时间的, 但是,时钟是主机发出的,主机是不知道 从机 准备没准备好的。 所以,这个指令的复杂程度,从机需要处理的时间, 主机这边要有  充分的等待, 才能 发出时钟 取数据。
同样,主机发出 CE/SS  信号,然后发数据 给从机, 这个时候,从机在干什么?  你能不能确保,这个时候从机就 等在 SPI 线程上 等待指令接收完毕,立刻处理? 如果,这个时候,从机在处理别的事情,你又没有机制,让从机停止工作,来处理SPI 发来的指令? 这是  双机通讯中必须考虑的问题。
因为,不知道你  双机 SPI 通讯 具体进行什么 数据交互,就只能推测这些了。
ID:391219 发表于 2022-10-11 19:36
188610329 发表于 2022-10-11 18:41
主机需要考虑从机的响应和处理速度。从机需要考虑在做任何处理时,都能停下手头的工作,响应主机的要求。
那您的意思是速度太快了吗?可是有的时候,我再重新烧录程序的时候,会全部复位在进行烧录。有的时候能通信,有的时候就不行。要是因为速度的话,每次重新开始的时候,不应该时好时坏。
