这个简易单片机秒表为什么没反应?
查看数: 2639 | 评论数: 6 | 收藏 0
发布时间: 2023-7-30 11:42
#include<reg51.h> #define uchar unsigned char #define uint unsigned int sbit p3_3=P3^3; sbit p2_7=P2^7; char led_mod[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xbf}; char led_ ...
ID:1090051 发表于 2023-8-4 10:04
#include<reg51.h>
sbit p3_3=P3^3;
sbit p2_7=P2^7;
char led_com[]={0x01,0x02,0x04,0x08,0x10,0x20};
sbit BEER=P1^1;
int TENms,s,m;
char data_time[6];
void display()
        uint k;
        data_time[0]=m;
        data_time[1]=10;
        data_time[2]=s/10;
        data_time[3]=s%10;
        data_time[4]=TENms/10;
        data_time[5]=TENms%10;
        for(k=0;k<6;k++)
                        P2=0xff;
                        P3=led_com[k];
                        P2=led_mod[data_time[k]];
                if(k==3)
                        p2_7=0;
isr_10msT0() interrupt 1
                TH0=(65536-10000)/256;
                TL0=(65536-10000)%256;
                TENms++;
                BEER=0;
                if(TENms==100)
                        TENms=0;
                        s++;
                        BEER=1;
                if(s==60)
                        s=0;
                        m++;
                if(m==9&&s==59&&TENms==99)
                        m=9;
                        BEER=0;
                        TENms=0;
                        TR0=0;
void main(void)
                TENms=0;
                s=0;
                m=0;
                BEER=0;
                TMOD=0x01;
          ET0=1;
                EA=1;
                                        display();
                                        switch(P1&0xe0)
                                                case 0xc0:TR0=1;break;
                                                case 0xa0:TR0=0;TR0=0;break;
                                                case 0x60:TR0=0;TENms=0;s=0;m=0;TR0=0;break;
全部功能正常谢谢各位
ID:213173 发表于 2023-7-31 14:35
  1. #include<reg51.h>
  3. #define uint unsigned int
  4. sbit key=P1^5;
  5. //sbit p2_7=P2^7;
  6. sbit BEER=P1^1;
  7. uchar led_mod[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xbf};
  8. uchar led_com[]={0x01,0x02,0x04,0x08,0x10,0x20};
  9. uint TENms;
  10. uchar s,m,count,value;
  11. uchar data_time[6];
  12. bit begin,sign;
  13. void delayms(uint xms)
  14. {
  15.         uint i,j;
  16.         for(i=xms;i>0;i--)
  17.                 for(j=110;j>0;j--);
  18. }
  19. void display()
  20. {
  21.         static uchar k;
  22.         data_time[0]=led_mod[m];
  23.         data_time[1]=led_mod[10];
  24.         data_time[2]=led_mod[s/10];
  25.         data_time[3]=led_mod[s%10]&0x7f;
  26.         data_time[4]=led_mod[TENms/10];
  27.         data_time[5]=led_mod[TENms%10];
  28.         P2=0xff;
  29.         P3=led_com[k];
  30.         P2=data_time[k];
  31.         k=++k%6;
  32. }
  33. void isr_10msT0() interrupt 1
  34. {
  35.         TH0=(65536-10000)/256;
  36.         TL0=(65536-10000)%256;
  37.         if(begin)
  38.         {
  39.                 if(++TENms==100)
  40.                 {
  41.                         TENms=0;
  42.                         if(++s==60)
  43.                         {
  44.                                 s=0;
  45.                                 m++;
  46.                         }
  47.                 }
  48.         }
  49.         if(m==9 && s==59 && TENms==99)
  50.         {
  51.                 BEER=1;
  52.                 begin=0;
  53.         }
  54. }
  55. void key_scan(void)
  56. {
  57.         if(!key)
  58.         {
  59.                 if(++count>=10 && sign==0)
  60.                 {
  61.                         sign=1;
  62.                         value=++value%3;
  63.                         switch(value)
  64.                         {
  65.                                 case 0:TENms=0;s=0;m=0;BEER=0; break;
  66.                                 case 1:begin=1; break;
  67.                                 case 2:begin=0; break;
  68.                         }
  69.                 }
  70.         }
  71.         else
  72.         {
  73.                 count=0;
  74.                 sign=0;
  75.         }
  76. }
  77. void main(void)
  78. {
  79.         TENms=0;
  80.         s=0;
  81.         m=0;
  82.         BEER=0;
  83.         TMOD=0x01;
  84.         TH0=(65536-10000)/256;
  85.         TL0=(65536-10000)%256;
  86.         TR0=1;
  87.         ET0=1;
  88.         EA=1;
  89.         while(1)
  90.         {
  91.                 display();
  92.                 key_scan();
  93.                 delayms(1);
  94.         }
  95. }
ID:161164 发表于 2023-7-31 11:30
1。没消影
2。没延时
3。多余的延时
4。不能大于2^16(65536)
ID:584814 发表于 2023-7-31 08:27
这个坛里保姆不多,请先注释好程序,谢谢
ID:332444 发表于 2023-7-30 12:55
其他且不论先点一个数码管正常后再点第二直到所有正常后再调试其他功能
