51单片机点阵仿真心形失败
查看数: 2723 | 评论数: 7 | 收藏 0
发布时间: 2023-10-11 22:57
大佬们,这位什么跑不起来啊想显示一个心形 #include <REGX52.H> unsigned  int key=0; unsigned int led[8]={         0x9F,0x07,0x01,0x80,0x80,0x01,0x07,0x9F} ...
ID:1096381 发表于 2023-10-17 21:23
  1. #include <REGX52.H>
  2. void Delay(unsigned int xms)
  3. {
  4.                 unsigned char i, j;
  5.                 while(xms--)
  6.                 {
  7.                                 i = 2;
  8.                                 j = 239;
  9.                                 do
  10.                                 {
  11.                                                 while (--j);
  12.                                 } while (--i);
  13.                 }
  14. }
  15. sbit RCK=P3^5;                //RCLK
  16. sbit SCK=P3^6;                //SRCLK
  17. sbit SER=P3^4;                //SER
  18. #define MATTROX_LED_PORT        P0
  19. /**
  20.   * @brief        74HC595写入一个字节
  21.   * @param  Byte 要写入的字节
  22.   * @retval  无
  23.   */
  24. void _74HC595_WriteBytr(unsigned char Byte)
  25. {
  26.         unsigned char i;
  27.         for(i=0;i<8;i++)
  28.         {
  29.                 SER=Byte&(0x80>>i);
  30.                 SCK=1;
  31.                 SCK=0;
  32.         }
  33.         RCK=1;
  34.         RCK=0;
  35. }
  36. /**
  37.   * @brief        LED点阵屏显示一列数据
  38.   * @param        Column 要选择的列0~7
  39.   * @param        Data 选择的列显示的数据  1亮,0灭
  40.   * @retval  无
  41.   */
  42. void MatrixLED_ShowColmn(unsigned char Column,Data)
  43. {
  44.         _74HC595_WriteBytr(Data);
  45.         MATTROX_LED_PORT=~(0x80>>Column);
  46.         Delay(1);
  47.         MATTROX_LED_PORT=0xFF;
  48. }
  49. void main( )
  50. {
  51.         SCK=0;
  52.         RCK=0;
  53.         while(1)
  54.         {
  55.                 MatrixLED_ShowColmn(0,0x30);
  56.                 MatrixLED_ShowColmn(1,0x48);
  57.                 MatrixLED_ShowColmn(2,0x44);
  58.                 MatrixLED_ShowColmn(3,0x22);
  59.                 MatrixLED_ShowColmn(4,0x44);
  60.                 MatrixLED_ShowColmn(5,0x48);
  61.                 MatrixLED_ShowColmn(6,0x30);
  62.
  63.         }
  64. }
ID:213173 发表于 2023-10-12 18:10
  1. #include <REG52.H>
  2. unsigned char key=0;
  3. unsigned char led[8]={
  4. 0x9F,0x07,0x01,0x80,0x80,0x01,0x07,0x9F};
  5.
  6. sbit ADDR0=P1^0;
  7. sbit ADDR1=P1^1;
  8. sbit ADDR2=P1^2;
  9. sbit ADDR3=P1^3;
  10. sbit ADDR4=P1^4;
  11. sbit ADDR5=P1^5;
  12. sbit ADDR6=P1^6;
  13. sbit ADDR7=P1^7;
  14.
  15. void main()
  16. {
  17.   TMOD=0x01;
  18.   TH0=0xfc;
  19.   TL0=0x66;
  20.   EA=1;
  21.   ET0=1;
  22.   TR0=1;
  23.   while(1)
  24.   {
  25.   }
  26. }
  27. void interruptTimer0() interrupt 1
  28. {
  29.         TH0=0xfc;
  30.         TL0=0x66;
  31.         P2=0x00;
  32.         switch(key)
  33.         {
  34.                 case 0: ADDR0=0;ADDR1=0;ADDR2=0;key++;P2=~led[0];break;
  35.                 case 1: ADDR0=1;ADDR1=0;ADDR2=0;key++;P2=~led[1];break;
  36.                 case 2: ADDR0=0;ADDR1=1;ADDR2=0;key++;P2=~led[2];break;
  37.                 case 3: ADDR0=1;ADDR1=1;ADDR2=0;key++;P2=~led[3];break;
  38.                 case 4: ADDR0=0;ADDR1=0;ADDR2=1;key++;P2=~led[4];break;
  39.                 case 5: ADDR0=1;ADDR1=0;ADDR2=1;key++;P2=~led[5];break;
  40.                 case 6: ADDR0=0;ADDR1=1;ADDR2=1;key++;P2=~led[6];break;
  41.                 case 7: ADDR0=1;ADDR1=1;ADDR2=1;key=0;P2=~led[7];break;
  42.                 default: break;
  43.         }
  44. }
ID:161164 发表于 2023-10-12 17:41
小臭臭废 发表于 2023-10-12 16:59
p2是准双向口也加上拉电阻吗
现实中的准双向口输出高电平只有2百多uA
仿真的加一下也无妨
ID:1094287 发表于 2023-10-12 16:59
lkc8210 发表于 2023-10-12 14:44
P2的消影是P2=0x00;
P2输出高电平要加上拉电阻
p2是准双向口也加上拉电阻吗
ID:161164 发表于 2023-10-12 14:44
P2的消影是P2=0x00;
P2输出高电平要加上拉电阻
ID:123289 发表于 2023-10-12 09:25
细心一点。CASE的地址8种组合,再核一下。
ID:277550 发表于 2023-10-12 09:14
问题1,#include <REG52.H>
问题2,不要在中断使用较占时的操作
