STC15单片机矩阵键盘的代码哪里出错了,大佬可以帮我看看吗
查看数: 1579 | 评论数: 7 | 收藏 0
发布时间: 2025-3-7 23:23
这个STC15单片机的矩阵键盘代码哪里出错了呀,大佬帮我看看吧,给我矩阵键盘的代码也可以
ID:1110477 发表于 2025-3-17 03:50
谭1234 发表于 2025-3-15 08:25
这写法看着都头疼
sbit R1 = P3^0;
sbit R2 = P3^1;
为啥键值要加大
ID:1132182 发表于 2025-3-15 08:25
这写法看着都头疼
sbit R1 = P3^0;
sbit R2 = P3^1;
sbit R3 = P3^2;
sbit R4 = P3^3;
sbit C1 = P4^4;
sbit C2 = P4^2;
sbit C3 = P3^5;
sbit C4 = P3^4;
uchar Key_Open(void)
  uchar key = 0;
  C1 = 0;C2 = 1;C3 = 1;C4 = 1;
  if(R1 == 0) key = 7;
  if(R2 == 0) key = 6;
  if(R3 == 0) key = 5;
  if(R4 == 0) key = 4;
  C1 = 1;C2 = 0;C3 = 1;C4 = 1;
  if(R1 == 0) key = 11;
  if(R2 == 0) key = 10;
  if(R3 == 0) key = 9;
  if(R4 == 0) key = 8;
  C1 = 1;C2 = 1;C3 = 0;C4 = 1;
  if(R1 == 0) key = 15;
  if(R2 == 0) key = 14;
  if(R3 == 0) key = 13;
  if(R4 == 0) key = 12;
  C1 = 1;C2 = 1;C3 = 1;C4 = 0;
  if(R1 == 0) key = 19;
  if(R2 == 0) key = 18;
  if(R3 == 0) key = 17;
  if(R4 == 0) key = 16;
  return key;
ID:1132182 发表于 2025-3-15 08:20
跳线帽没接到矩阵?
ID:1145512 发表于 2025-3-14 18:00
你这个暂时看不出问题,我附上我之前参加蓝桥杯时候的矩阵键盘代码#include "ALL.H"
#include "REG52.H"
/*矩阵键盘编号
1     2    3    4   P3_0
5     6    7    8   P3_1
9    10   11   12   P3_2
13   14   15   16   P3_3
P4_4 P4_2 P3_5 P3_4
unsigned char Matric_Scan(){
        unsigned char Num=0;
        P3_0=0;
        P3_1=P3_2=P3_3=1;
        P4_4=P4_2=P3_5=P3_4=1;
        if(P4_4==0){
                Num=1;
        else if(P4_2==0){
                Num=2;
        else if(P3_5==0){
                Num=3;
        else if(P3_4==0){
                Num=4;
        P3_1=0;
        P3_0=P3_2=P3_3=1;
        if(P4_4==0){
      Num=5;
        else if(P4_2==0){
                Num=6;
        else if(P3_5==0){
                Num=7;
        else if(P3_4==0){
                Num=8;
        P3_2=0;
        P3_0=P3_1=P3_3=1;
        if(P4_4==0){
      Num=9;
        else if(P4_2==0){
                Num=10;
        else if(P3_5==0){
                Num=11;
        else if(P3_4==0){
                Num=12;
        P3_3=0;
        P3_0=P3_1=P3_2=1;
        if(P4_4==0){
      Num=13;
        else if(P4_2==0){
                Num=14;
        else if(P3_5==0){
                Num=15;
        else if(P3_4==0){
                Num=16;
        return Num;
void Matric_Show_Num(){
        if(Matric_Scan()==1){
                        Display(1,1);
                else if(Matric_Scan()==2){
                        Display(1,2);
                else if(Matric_Scan()==3){
                        Display(1,3);
                else if(Matric_Scan()==4){
                        Display(1,4);
                else if(Matric_Scan()==5){
                        Display(1,5);
                else if(Matric_Scan()==6){
                        Display(1,6);
                else if(Matric_Scan()==7){
                        Display(1,7);
                else if(Matric_Scan()==8){
                        Display(1,8);
                else if(Matric_Scan()==9){
                        Display(1,9);
                else if(Matric_Scan()==10){
                        Display(1,10);
                else if(Matric_Scan()==11){
                        Display(1,11);
                else if(Matric_Scan()==12){
                        Display(1,12);
                else if(Matric_Scan()==13){
                        Display(1,13);
                else if(Matric_Scan()==14){
                        Display(1,14);
                else if(Matric_Scan()==15){
                        Display(1,15);
                else if(Matric_Scan()==16){
                        Display(1,16);
应该会有帮助
ID:1145512 发表于 2025-3-14 17:55
代码上看,没啥问题,你是现象出问题了还是什么
ID:891003 发表于 2025-3-8 10:45
这个不好回答!代码跟硬件需要配合,原理图都没有,我个人才疏学淺,不懂回答。
ID:1133081 发表于 2025-3-8 06:55
这个程序用在51内核的MCU具有普适性
  1. #include <reg52.h>
  2. #define uint unsigned int
  4. uchar key=0;                                        //定义键值全局变量
  5. void keyscan()                                        //按键扫描程序
  6. {
  7.         static bit sign=0;                        //按键状态标志
  8.         static uint count=0;                //消抖计数变量
  9.         uchar num=0;                                //临时变量
  10.         P3=0xf0;                                        //赋值P3 1111 0000
  11.         if(P3!=0xf0)                                //检测有按键按下
  12.         {
  13.                 count++;                                //消抖计数
  14.                 if(count>=100 && sign==0)//100~10000,根据循环周期调整约10~20ms
  15.                 {
  16.                         sign=1;                                //按键状态标志置1
  17.                         num=P3;                                //保存P3值xxxx 0000,x为0或1
  18.                         num|=0x0f;                        //保存num按位或0x0f值xxxx 1111
  19.                         P3=num;                                //赋值P3 xxxx 1111
  20.                         switch(P3)
  21.                         {
  22.                                 case 0xee: key= 1; break;
  23.                                 case 0xde: key= 2; break;
  24.                                 case 0xbe: key= 3; break;
  25.                                 case 0x7e: key= 4; break;
  26.                                 case 0xed: key= 5; break;
  27.                                 case 0xdd: key= 6; break;
  28.                                 case 0xbd: key= 7; break;
  29.                                 case 0x7d: key= 8; break;
  30.                                 case 0xeb: key= 9; break;
  31.                                 case 0xdb: key=10; break;
  32.                                 case 0xbb: key=11; break;
  33.                                 case 0x7b: key=12; break;
  34.                                 case 0xe7: key=13; break;
  35.                                 case 0xd7: key=14; break;
  36.                                 case 0xb7: key=15; break;
  37.                                 case 0x77: key=16; break;
  38.                         }
  39.                 }
  40.         }
  41.         else                                                //键抬起
  42.         {
  43.                 sign=0;                                        //按键自锁标志清0
  44.                 count=0;                                //消抖计数清0
  45.         }
  46. }
  47. void main()                                                //主函数
  48. {
  49.         while(1)
  50.         {
  51.                 keyscan();                                //按键扫描程序
  52.                 P1=~key;                                //LED显示键码1~16,低电平亮
  53.         }
  54. }
