红绿灯设计求帮忙调试,调试很久数码管显示不出来
查看数: 5486 | 评论数: 9 | 收藏 0
发布时间: 2014-12-20 12:45
#include <reg52.h> #define uchar unsigned char #define uint  unsigned int sbit wela =P2^3; sbit dula =P2^4; sbit  red = P1^4; sbit  yellow = P1^3; sbit &n ...
ID:70778 发表于 2014-12-21 00:28
非常感谢。可以用了。
ID:67992 发表于 2014-12-20 22:29
ID:67992 发表于 2014-12-20 22:28
#include <reg52.h>
sbit wela =P2^3;
sbit dula =P2^4;
sbit red = P1^4;
sbit yellow = P1^3;
sbit green=P1^2;
uchar shi,ge;
uchar code table[] = { 0x3f, 0x06, 0x5b, 0x4f, 0x66, 0x6d, 0x7d, 0x07,0x7f, 0x6f};
bit flag1s = 1;
void Timer0_init();
void light_crol();
void delay(uint x);
void LedScan();
    Timer0_init();
    while (1)
    {         LedScan();
        if (flag1s)
            flag1s = 0;
             light_crol();
void Timer0_init()
    TMOD = 0x01;
    TH0 = (65536-50000)/256 ;
    TL0 = (65536-50000)%256 ;
    EA = 1;
    ET0 = 1;
    TR0 = 1;
void light_crol()
{   uchar num=1;
    static unsigned char color = 2;
    static unsigned char timer = 0;
    if (timer == 0)
        switch (color)
            case 0:
                red=1;
                green=1;
                if(num%2)
                color = 1;
                                color = 2;
                timer = 2;
                yellow=0;
                if(num==11)
                 num=1;
                break;
            case 1:
                yellow=1;
                green=1;
                color = 0;
                timer = 29;
                red=0;
                num++;
                break;
            case 2:
                red=1;
                yellow=1;
                color = 0;
                timer = 39;
                green=0;
                num++;
                break;
                default:
                break;
        timer--;
    ge =timer%10;
    shi =timer/10;
void LedScan()
                   wela=1;
           P0=0xfe;
           wela=0;
           dula=1;
           P0=table[shi];
           dula=0;
           P0 = 0xff;
           delay(20);
                   wela=1;
           P0=0xfd;
           wela=0;
           dula=1;
           P0=table[ge];
           dula=0;
           P0 = 0xff;
           delay(20);
void InterruptTimer0() interrupt 1
    static unsigned int tmr1s = 0;
    TH0 =(65536-50000)/256 ;
    TL0 = (65536-50000)/256 ;
    tmr1s++;
    if (tmr1s >= 20)
        tmr1s = 0;
        flag1s = 1;
void delay(uint x)
    uint i,j;
    for(i=x;i>0;i--)
      for(j=110;j>0;j--);
ID:70778 发表于 2014-12-20 21:00
mqwu 发表于 2014-12-20 17:15
笔误, 要把Dula改成dula
您好,感谢您认真的修改和帮助,可是还是不正确。数码管依然显示不出来。而且修改后的二极管都不亮了。
ID:66032 发表于 2014-12-20 17:15
笔误, 要把Dula改成dula
ID:66032 发表于 2014-12-20 17:07
改了三处: 1。 timer 改为全局变量,2。修改函数LedScan(uchar m) 放到while(1)内,放在中断内每隔50ms 扫描一次太慢,3, 分离变量直接在LedScan()的形参内,无需在其它地方分离。
#include <reg52.h>
sbit wela =P2^3;
sbit dula =P2^4;
sbit  red = P1^4;
sbit  yellow = P1^3;
sbit  green=P1^2;
uchar shi,ge;
bit flag1s = 1;
void Timer0_init();
void light_crol();
void delay(uint x);
         Timer0_init();
    while (1)
        LedScan(timer/10);
        LedScan(timer%10);
        if (flag1s)
            flag1s = 0;
             light_crol();
void Timer0_init()
    TMOD = 0x01;
    EA = 1;
    ET0 = 1;
    TR0 = 1;
void light_crol()
{uchar num=1;
   // static unsigned char timer = 0;
    if (timer == 0)
        switch (color)
            case 0:
                 red=1;
                green=1;
                if(num%2)
                color = 1;
                else color = 2;
                timer = 2;
             yellow=0;
                if(num==11)
                 num=1;
                break;
            case 1:
                yellow=1;
                green=1;
                color = 0;
                timer = 29;
                red=0;
                num++;
                break;
            case 2:
                red=1;
                yellow=1;
                color = 0;
                timer = 39;
                green=0;
                num++;
                break;
                default:
                break;
        timer--;
   // ge =timer%10;
    //shi =timer/10;
void LedScan(uchar m)
      Dula=1;
      P0=table[m];
      Dula=0;
      P0=0xff;
      P0=0xfe;
      wela=1;
      delay(1);
      wela=0;
      P0=0xfd;
      wela=1;
      delay(10);
      wela=0;
  //  LedScan();
    tmr1s++;
    if (tmr1s >= 20)
        tmr1s = 0;
        flag1s = 1;
ID:70778 发表于 2014-12-20 15:28
admin 发表于 2014-12-20 12:53
电路图呢  最好贴出来一下 方便调试
你好,能帮忙改下吗?
ID:1 发表于 2014-12-20 12:53
电路图呢  最好贴出来一下 方便调试
