关于fpga编译时出错
查看数: 3021 | 评论数: 1 | 收藏 0
发布时间: 2017-10-5 10:57
ID:229281 发表于 2017-10-5 11:32
Internal Error: Sub-system: DEV, File: /quartus/ddb/dev/dev_basic_info.cpp, Line: 606
BASIC_INFO's HDR file c:/altera/11.0/quartus/common/devinfo/cycloneiii/ddb_cuda_hdr.ddb not installed
Stack Trace:
    0x47a46: DEV_BASIC_INFO::get_part_enum + 0x179f6 (DDB_DEV)
    0x1243f: DMGR_UTILITY::create_device + 0x109bf (DDB_DMGR)
    0x133be: DMGR_UTILITY::create_device + 0x1193e (DDB_DMGR)
    0x86ed3: scl_start + 0x82ac3 (SYNTH_SCL)
    0x716c0: scl_start + 0x6d2b0 (SYNTH_SCL)
    0x71abf: scl_start + 0x6d6af (SYNTH_SCL)
     0x3f67: DllSclStart + 0x2f67 (SYNTH_SCL)
    0x117eb: qexe_get_tcl_sub_option + 0x1dbb (comp_qexe)
    0x14997: qexe_process_cmdline_arguments + 0x537 (comp_qexe)
    0x14aa1: qexe_standard_main + 0xa1 (comp_qexe)
     0x1928: msg_exe_fini + 0xf8 (CCL_MSG)
     0x18cc: msg_exe_fini + 0x9c (CCL_MSG)
     0x57c4: MEM_UTILS_CHUNK_ALLOC::chunk_malloc + 0x194 (ccl_mem)
    0x2f084: msg_exe_main + 0x74 (CCL_MSG)
     0x8363: BaseThreadInitThunk + 0x13 (KERNEL32)
    0x670d0: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Quartus II 64-Bit Version 11.0 Build 157 04/27/2011 SJ Full Version
