求教流水灯开慢到快,关快到慢程序思路,试着delay来判断,不懂占空比5%~100%怎么取值固定,小白。流水程序看视频学写的,delay按着一些理解来写的,软件void delay报错不对。。。。
#include <reg51.h> // <reg51.h>程序电脑实验
sbit key1=P3^0;
unsigned char dat1[4]={0xf1,0xf2,0xf4,0xf8};
unsigned char dat2[4]={0xfc,0xf9,0xf3,0xf6};
unsigned char dat3[4]={0xfe,0xfd,0xfb,0xf7};
unsigned char MODE;
unsigned int count;
void delay (unsigned int x);
void mode1(void);
void mode2(void);
void mode3(void);
void keyscan(void);
void main(void)
keyscan();
switch(MODE)
case 0: P0=0xff;break;
case 1: mode1();break;
case 2: mode2();break;
case 3: mode3();break;
delay(1);
void delay(unsigned int x)
unsigned int i,j;
for(i=0;i<x;i++)
for(j=0;j<120;j++);//12T
void mode1(void)
static unsigned char i;
static unsigned int j;
P0=dat1;
for(j=500;j>50;j--) //慢到快,怎么固定到快?不知道对不对
if(++j>=50)
j=50
i=++i%4;
MODE=0
for(j=50;j<50;j++) //快到慢?关闭?
if(++j>=50)
void mode2(void)
P0=dat2;
if(++j>=50)
j=50
i=++i%4;
MODE=0
if(++j>=50)
void mode3(void)
P0=dat3;
if(++j>=50)
j=50
i=++i%4;
MODE=0
if(++j>=50)
void keyscan(void)
if(key1==0)
if(count<501)count++;
if(count==500)
sign=~sign;
if(sign)
slow=MODE;
MODE=0;
else MODE=slow;
if(count>20 && count<500
++MODE;
if(MODE>3)
MODE=1;
count=0;
