12864结构体菜单
- #include "stm32f10x.h"
- #include"stm32f10x_conf.h"
- extern u8 stm[]; //外部定义nova logo
- extern u8 lan[],ya[],cai[],ji1[],zhong[],duan[];
- extern u8 qing[],dian[],zi[];
- u16 count=0;
- u8 func_index=0;
- u8 buffer[15]={'
- ,'N','O','V','A',0x00}; //发送buffer
- u8 BUFFER[8]={0};//接收buffer
- u8 bf_number; //接收字节指示
- void (*current_operation_index)(); //执行当前显示函数
- typedef struct
- u8 current; //当前状态号
- u8 up;//向上翻索引号
- u8 down;//向下翻索引号
- u8 enter;//确认索引号
- u8 num_ent;//编码器确认键
- void (*current_operation)(); //要执行的函数
- } key_table;
- key_table table[32]=
- {0,0,1,3,0,(*fun1)},
- {1,0,2,7,1,(*fun2)}, //菜单元素列表
- {2,1,2,11,2,(*fun3)},
- {3,3,4,0,3,(*fun4)},
- {4,3,5,0,4,(*fun5)},
- {5,4,6,0,5,(*fun6)},
- {6,5,6,0,6,(*fun7)},
- {7,7,8,15,7,(*fun8)},
- {8,7,9,19,8,(*fun9)},
- {9,8,10,23,9,(*fun10)},
- {10,9,10,1,10,(*fun11)},
- {11,11,12,28,11,(*fun12)},
- {12,11,13,31,12,(*fun13)},
- {13,12,14,13,13,(*fun14)},
- {14,13,14,2,14,(*fun15)},
- {15,15,16,15,25,(*fun16)},
- {16,15,17,16,25,(*fun17)},
- {17,16,18,17,25,(*fun18)},
- {18,17,18,7,18,(*fun19)},
- {19,19,20,19,26,(*fun20)},
- {20,19,21,20,26,(*fun21)},
- {21,20,22,21,26,(*fun22)},
- {22,21,22,8,22,(*fun23)},
- {23,23,24,23,27,(*fun24)},
- {24,23,24,9,24,(*fun25)},
- {25,7,7,7,7,(*fun26)},
- {26,8,8,8,8,(*fun27)},
- {27,9,9,9,9,(*fun28)},
- {28,28,29,30,28,(*fun29)},
- {29,28,29,30,29,(*fun30)},
- {30,11,11,11,11,(*fun31)},
- {31,12,12,12,12,(*fun32)}
- int main(void)
- { u8 num;
- //SystemInit(); // 初始系统时钟,3.5版本库在启动文件里已经把时钟初始为72MHZ ,不需要自己初始化了。
- //LED_Init(); //led 初始化
- key_Init(); //按键初始化
- delay_init(36); //延时初始化
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //中断分组
- SPI_GPIO_Config(); //SPI端口初始化
- //EXTIX_Init(); //外部中断初始化
- spi_init(); // SPI初始化
- usart_init();
- /* config the led */
- ENC_Init(); //定时器4编码器模式初始化
- //Timerx_Init( 0,0);
- // WKUP_Init(); // 待机模式初始化 ,不注释掉,得按WAKP来开机
- delay_ms(5);
- initial_lcd();//液晶初始化
- clear_screen(); //clear all dots
- Lcdwritecom(0xb0); //设置页地址
- //GPIO_ResetBits(GPIOB,GPIO_Pin_1);
- while(1)
- blue_init();
- // BL_PW_OFF ; //高电平关断蓝牙模块电压
- Lcdwritecom(0xaf); /*开显示*/
- clear_screen();
- delay_ms(20);
- display_128x64(stm);
- delay_ms(1000);
- delay_ms(1000);
- delay_ms(1000);
- delay_ms(1000);
- display_graphic_16x16(4,32,qing);
- display_graphic_16x16(4,48,qing);
- display_graphic_16x16(4,64,dian);
- display_graphic_16x16(4,80,zi);
- delay_ms(1000);
- delay_ms(1000);
- delay_ms(1000);
- delay_ms(1000);
- display_graphic_16x16(4,80,zhong);
- display_graphic_16x16(4,16,lan);
- display_graphic_16x16(4,32,ya);
- display_graphic_16x16(4,48,cai);
- display_graphic_16x16(4,64,ji1);
- display_graphic_16x16(4,96,duan);
- delay_ms(1000);
- delay_ms(1000);
- while(1)
- num=KEY_Scan();//得到键值
- if(num)
- switch(num)
- case 1:
- func_index=table[func_index].up; break; //向上翻
- case 2:
- func_index=table[func_index].down; break; //向下翻
- case 3:
- func_index=table[func_index].enter; break; //确认
- case 4:
- func_index=table[func_index].num_ent; break;
- current_operation_index=table[func_index].current_operation;
- (*current_operation_index)();//执行当前操作函数
Keil代码下载(仅供参考):
液晶菜单.7z
(647.55 KB, 下载次数: 141)
