查看: 1979|回复: 8
哪位大神指点一下,网上的程序烧录进单片机没反应,也不知道哪里错了
ID:1009425 发表于 2023-12-6 13:47 | 显示全部楼层 |阅读模式
sfr P3              = 0xB0;
sfr LEDWTML         = 0xce;
sfr LEDWTMH         = 0xcf;
sfr LEDAT1          = 0xc7;
sfr PWMEN           = 0x90;
sfr PWM2DIVL        = 0xad;
sfr PWM2DIVH        = 0xae;
sfr PWM2DUTL        = 0x9f;
sfr PWM2DUTH        = 0x91;
sfr PWM2CKD         = 0xb3;
sfr PWM2CON         = 0xbb;
sfr LEFLG           = 0xbf;
#define CKCON (*(unsigned char volatile xdata *)0x8030)
#define P34F  (*(unsigned char volatile xdata *)0x801C)
#define LEDUTL (*(unsigned char volatile xdata *)0x8060)
#define LEDUTH (*(unsigned char volatile xdata *)0x8061)
#define PWMIE(N) (N<<7) //N=0-1
#define PWMTOG(N) (N<<6) //N=0-1
#define PWMMOD(N) (N<<3) //N=0-7
#define PWMPOL(N) (N<<2) //N=0-1
#define PWMCKS_SYS 0
#define PWMCKS_IL 1
#define PWMCKS_IH 2     //LEFLG
#define LEF1 (1<<3)
#define LEBSY1 (1<<2)
#define IHCKE (1<<7)
void PWM_init(void)
P3   =16;
P34F = 5; //设置 P34 为 PWM 引脚功能
CKCON |= IHCKE; //打开 IRCH 时钟
PWM2DIVH = 0; //设置位周期时间
PWM2DIVL = 20;
PWM2DUTH = 0; //设置位码 0 时间
PWM2DUTL = 6;
LEDUTH = 0; //设置位码 1 时间
LEDUTL = 13;
PWM2CON = PWMIE(0) | PWMTOG(0) | PWMMOD(3) | PWMPOL(0) | PWMCKS_IH; //设置IRCH 为PWM时钟源,发送 3 个字节后插入暂停时间
PWM2CKD = 0; //设置预分频系数,设置为 0 表示不分频
LEDWTMH = 0; //设置暂停时间
LEDWTML = 50;
PWMEN |= (2<<2); //PWM2 使能
code unsigned char LED_DAT[][3] = //LED 数据表
{0xff,0x00,0x00},
{0xff,0xff,0x00},
{0x00,0xff,0x00},
{0x00,0xff,0xff},
{0x00,0x00,0xff},
{0xff,0x00,0xff},
void main(void)
unsigned char i;
unsigned char color_index=0;
PWM_init();
for(i=0;i<24;i++) //每级 RGB LED 为 3 个字节数据,8 级为 24 字节
while(LEFLG & LEBSY1); //等待数据全部发送
LEDAT1 = LED_DAT[color_index][i%3]; //写入 LED 数据到 LEDAT 寄存器
color_index ++; //循环变色
if(color_index> 6) color_index =0;
ID:161164 发表于 2023-12-7 09:36 | 显示全部楼层
啥芯片?
预期反应是啥?
没反应又是啥?
ID:1009425 发表于 2023-12-12 14:49 | 显示全部楼层
1.“PWMEN |= (2<<2); //PWM2 使能” 改为 “PWMEN |= (1<<2); //PWM2 使能”
2.需要复位280us以上
ID:1009425 发表于 2024-1-20 12:47 | 显示全部楼层
//航顺8位单片机,锦锐CA51F551S1,只可调光,调速,调灯组数,不会跑马。程序调试OK
sfr P3              = 0xb0;
sbit EA                         = 0xAF;
sfr LEDWTML         = 0xce;
sfr LEDWTMH         = 0xcf;
sfr LEDAT1             = 0xc7;
sfr PWMEN           = 0x90;
sfr PWM2CKD         = 0xb3;
sfr PWM2CON         = 0xbb;
sfr LEFLG           = 0xbf;
#define PWMCKS_IL    1
#define LEF1 (1<<3)
#define LEBSY1 (1<<6)
void main(void)
                EA = 1;
                CKCON =(1<<7);                                                        //打开IRCH时钟
    P34F  =5;
        PWM2CON = PWMIE(0) | PWMTOG(0) | PWMMOD(3) | PWMPOL(0) | PWMCKS_IH;                //设置PWM时钟源为IRCH
        PWM2CKD = 0;
        //设置PWMDIV、PWMDUT
        PWM2DIVH = 0;
        PWM2DIVL = 30;
        PWM2DUTH = 0;
        PWM2DUTL = 7;
        LEDUTH        = 0;
        LEDUTL        = 14;
        LEDWTMH        = 0;
        LEDWTML        = 50;
        //开全局中断
        unsigned int j,k;//定义一个16位无符号整形变量
        unsigned char i;
                static unsigned char color_index = 0;
            {0x00,0x2F,0x00},         //绿,红,蓝
                        {0x2F,0x00,0x00},
                        {0x00,0x00,0x2F},
                        {0x00,0x2F,0x2F},
            {0x2F,0x2F,0x00},
                        {0x2F,0x00,0x2F},
                        {0x2F,0x2F,0x2F},
                for(i=0;i<24;i++)              //LED个数i*3
                color_index ++;
                if(color_index> 6) color_index =0;    //LED数据组数N-1
      for(j=0;j<1500;j++)  //延时0.2s
            for(k=1000;k>0;k--);
ID:1009425 发表于 2024-1-20 15:49 | 显示全部楼层
8位2812点亮图片
8位2812
8位2812
WS2812.rar
1.52 KB, 下载次数: 1
ID:1009425 发表于 2024-1-20 15:53 | 显示全部楼层
lkc8210 发表于 2023-12-7 09:36
啥芯片?
预期反应是啥?
没反应又是啥?
ID:1009425 发表于 2024-1-20 19:45 | 显示全部楼层
锦锐CA51F551S1芯片手册
航顺-CA51F551S1.pdf
2.37 MB, 下载次数: 0
规格书与例程
ID:1009425 发表于 2024-1-20 19:47 | 显示全部楼层
啥芯片?
预期反应是啥?
没反应又是啥?
锦锐CA51F551S1,自带WS2812硬件驱动
ID:382454 发表于 2024-1-22 16:20 | 显示全部楼层
照抄也要抄的对啊。。。。。。。人才。
