查看: 5259|回复: 5
创意流水灯问题
ID:76027 发表于 2015-4-26 12:25 | 显示全部楼层
刚学C,改了一个,看看行不行.
#include <reg52.h>
#include <intrins.h>
sbit dula=P2^6;
sbit wela=P2^7;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f};
uchar t0,num;
void display(uchar shu);
void init();
void delay(uint z);
void keyscan();
        init();
                display(num);
void init()
        TMOD=0x01;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        EA=1;
        ET0=1;
        TR0=1;
void timer0()  interrupt 1
        t0++;
                if(t0==20)
                        t0=0;
                        num++;
                        if(num==1)
                                P1=0xfe;
                        else if(num==2)
                                P1=0xfd;
                        else if(num==3)
                                P1=0xfb;
                        else if(num==4)
                                P1=0xf7;
                        else if(num==5)
                                P1=0xef;
                        else if(num==6)
                                P1=0xdf;
                        else if(num==7)
                                P1=0xbf;
                        else if(num==8)
                                P1=0;
                                num=0;
void display(uchar shu)//显示子函数
        uchar ge;
        ge=shu%10;
        dula=1;
        P0=table[ge];
        dula=0;
        P0=0xff;
        wela=1;
        P0=0xfe;
        wela=0;
        delay(1);
void delay(uint z)//延时子函数
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
