查看: 3121|回复: 1
51单片机外部中断int0应用 原理图加程序注释-学习笔记
ID:413181 发表于 2018-10-21 17:35 | 显示全部楼层 |阅读模式
51单片机外部中断int0应用电路原理图如下:
  1. #include <reg52.h>
  3. #define uint unsigned int
  4. uchar code DSY_CODE[]=
  5. {
  6.          0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x7f,0x6f,0x00
  7. };
  8. uchar Display_Buffer[3]={0,0,0};//依次存放个位,十位,百位
  9. uint Count = 0;
  10. sbit Clear_Key = P3^6;
  11. void Show_Count_ON_DSY()
  12. {
  13.          Display_Buffer[2] = Count / 100;        //取百位值
  14.         Display_Buffer[1] = Count % 100 /10;        //取十位值
  15.         Display_Buffer[0] = Count % 10;                        //取个位置
  16.         if(Display_Buffer[2]==0)
  17.         {
  18.                  Display_Buffer[2] = 0x0a;
  19.                 if(Display_Buffer[1]==0)
  20.                 {
  21.                          Display_Buffer[1]=0x0a;
  22.                 }
  23.         }
  24.         P0 = DSY_CODE[Display_Buffer[0]];
  25.         P1 = DSY_CODE[Display_Buffer[1]];
  26.         P2 = DSY_CODE[Display_Buffer[2]];
  27. }
  28. void main()
  29. {
  30.          P0 = 0xff;                //关闭所有的数码管显示
  31.         P1 = 0xff;
  32.         P2 = 0xff;
  33.         IE = 0x81;        //0x81=10000001B,定义:EA/-/ET2/ES/ET1/EX1/ET0/EX0。打开EA总中断开和EX0外部中断开关。
  34.         IT0 = 1;        //跳变沿出发方式(下降沿)
  35.         while(1)
  36.         {
  37.                  if(Clear_Key == 0)
  38.                         Count = 0;
  39.                 Show_Count_NO_DSY();
  40.         }
  41. }
  42. void EX_INT0() interrupt 0 //外部中断0服务函数
  43. {
  44.          Count ++;
  45. }
知识点:1 数码管段码表
共阴数码管段码表
unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
共阳段码表
unsigned char code stab[]={0xff,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,
0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e};
001INT0中断计数.docx (120.56 KB, 下载次数: 8)
参与人数 1黑币 +5 收起 理由
wosiboos + 5 赞一个!
ID:402951 发表于 2018-10-21 22:28 | 显示全部楼层
不错。很直得学习。
