基于matlab中的GUI串口调试程序(发送与接收,很全面),可以调试检测串口,参数设置灵活,在GUI面板上操作简易。
源程序下载:
matlab中GUI的串口调试程序.zip
(13.33 KB, 下载次数: 721)
源码:
- function varargout = untitled(varargin)
- % UNTITLED M-file for untitled.fig
- % UNTITLED, by itself, creates a new UNTITLED or raises the existing
- % singleton*.
- % H = UNTITLED returns the handle to a new UNTITLED or the handle to
- % the existing singleton*.
- % UNTITLED('CALLBACK',hObject,eventData,handles,...) calls the local
- % function named CALLBACK in UNTITLED.M with the given input arguments.
- % UNTITLED('Property','Value',...) creates a new UNTITLED or raises the
- % existing singleton*. Starting from the left, property value pairs are
- % applied to the GUI before untitled_OpeningFcn gets called. An
- % unrecognized property name or invalid value makes property application
- % stop. All inputs are passed to untitled_OpeningFcn via varargin.
- % *See GUI Options on GUIDE's Tools menu. Choose "GUI allows only one
- % instance to run (singleton)".
- % See also: GUIDE, GUIDATA, GUIHANDLES
- % Edit the above text to modify the response to help untitled
- % Last Modified by GUIDE v2.5 07-Sep-2013 13:47:05
- % Begin initialization code - DO NOT EDIT
- gui_Singleton = 1;
- gui_State = struct('gui_Name', mfilename, ...
- 'gui_Singleton', gui_Singleton, ...
- 'gui_OpeningFcn', @untitled_OpeningFcn, ...
- 'gui_OutputFcn', @untitled_OutputFcn, ...
- 'gui_LayoutFcn', [] , ...
- 'gui_Callback', []);
- if nargin && ischar(varargin{1})
- gui_State.gui_Callback = str2func(varargin{1});
- end
- if nargout
- [varargout{1:nargout}] = gui_mainfcn(gui_State, varargin{:});
- else
- gui_mainfcn(gui_State, varargin{:});
- end
- % End initialization code - DO NOT EDIT
- % --- Executes just before untitled is made visible.
- function untitled_OpeningFcn(hObject, eventdata, handles, varargin)
- % This function has no output args, see OutputFcn.
- % hObject handle to figure
- % eventdata reserved - to be defined in a future version of MATLAB
- % handles structure with handles and user data (see GUIDATA)
- % varargin command line arguments to untitled (see VARARGIN)
- % 初始化
- set(handles.caiji,'UserData',0);
- setappdata(handles.save,'ApplicationData',0);
- % Choose default command line output for untitled
- handles.output = hObject;
- % Update handles structure
- guidata(hObject, handles);
- % UIWAIT makes untitled wait for user response (see UIRESUME)
- % uiwait(handles.figure1);
- % --- Outputs from this function are returned to the command line.
- function varargout = untitled_OutputFcn(hObject, eventdata, handles)
- % varargout cell array for returning output args (see VARARGOUT);
- % Get default command line output from handles structure
- varargout{1} = handles.output;
- % --- Executes on button press in on.
- function on_Callback(hObject, eventdata, handles)
- % hObject handle to on (see GCBO)
- clc;
- s1 = instrfind('Type','serial','Port','COM1','Tag',''); % 查看端口是否存在
- s2 = instrfind('Type','serial','Port','COM2','Tag','');
- s3 = instrfind('Type','serial','Port','COM3','Tag',''); % 查看端口是否存在
- s4 = instrfind('Type','serial','Port','COM4','Tag','');
- % 获取参数值
- if (isempty(s1) && get(handles.port,'Value')==1 ) % 如果端口1存在,存创建端口
- s = serial('COM1'); % 创建串口号
- if(get(handles.botelv,'Value')==1) % 设置串口参数
- s.BaudRate = 1200;
- elseif(get(handles.botelv,'Value')==2)
- s.BaudRate = 2400;
- elseif(get(handles.botelv,'Value')==3)
- s.BaudRate = 4800;
- elseif(get(handles.botelv,'Value')==4)
- s.BaudRate = 9600;
- elseif(get(handles.botelv,'Value')==5)
- s.BaudRate = 19200;
- elseif(get(handles.botelv,'Value')==6)
- s.BaudRate = 38400;
- elseif(get(handles.botelv,'Value')==7)
- s.BaudRate = 76800;
- elseif(get(handles.botelv,'Value')==8)
- s.BaudRate = 115200;
- end
- if(get(handles.jiaoyanw,'Value')==1)
- s.Parity = 'none'; % 无校验位
- elseif(get(handles.jiaoyanw,'Value')==2)
- s.Parity = 'odd'; % 偶校验
- elseif(get(handles.jiaoyanw,'Value')==3)
- s.Parity = 'even'; % 奇校验
- end
- if(get(handles.dataw,'Value')==1) % 数据位
- s.DataBits = 8;
- elseif(get(handles.dataw,'Value')==2)
- s.DataBits = 7;
- elseif(get(handles.dataw,'Value')==3)
- s.DataBits = 6;
- elseif(get(handles.dataw,'Value')==4)
- s.DataBits = 5;
- end
- if(get(handles.stopw,'Value')==1) % 停止位
- s.StopBits = 1;
- elseif(get(handles.stopw,'Value')==2)
- s.StopBits = 1.5;
- elseif(get(handles.stopw,'Value')==3)
- s.StopBits = 2;
- end
- s.Timeout = 0.1;
- s.InputBufferSize = 3072;
- s.OutputBufferSize = 3072;
- s.ReadAsyncMode = 'continuous';
- handles.sbuff = s;
- s.BytesAvailableFcnMode = 'byte';
- s.BytesAvailableFcnCount = 10;
- s.BytesAvailableFcn = {@recive_data, handles};
- fopen(s);
- set(handles.caiji,'Enable','On');
- set(handles.off,'Enable','On');
- set(handles.on,'Enable','Off');
- set(handles.edit1,'String','打开成功!');
- set(handles.exit,'Enable','Off');
- set(handles.edit1,'backgroundcolor',[0 1 0]);
- elseif (isempty(s2) && get(handles.port,'Value')==2 ) % 如果端口2存在,存创建端口
- s = serial('COM2'); % 创建串口号
- end
- end
- s.DataBits = 8;
- s.DataBits = 7;
- s.DataBits = 6;
- s.DataBits = 5;
- end
- s.StopBits = 1;
- s.StopBits = 1.5;
- s.StopBits = 2;
- end
- s.Timeout = 0.1;
- fopen(s);
- elseif (isempty(s3) && get(handles.port,'Value')==3 ) % 如果端口3存在,存创建端口
- s = serial('COM3'); % 创建串口号
- end
- end
- s.DataBits = 8;
- s.DataBits = 7;
- s.DataBits = 6;
- s.DataBits = 5;
- end
- s.StopBits = 1;
- s.StopBits = 1.5;
- s.StopBits = 2;
- end
- s.Timeout = 0.1;
- fopen(s);
- elseif (isempty(s4) && get(handles.port,'Value')==4 ) % 如果端口4存在,存创建端口
- s = serial('COM4'); % 创建串口号
- end
- end
- s.DataBits = 8;
- s.DataBits = 7;
- s.DataBits = 6;
- s.DataBits = 5;
- end
- s.StopBits = 1;
- s.StopBits = 1.5;
- s.StopBits = 2;
- end
- s.Timeout = 0.1;
- fopen(s);
- else
- msgbox('串口不存在或被占用!');
- set(handles.edit1,'String','打开失败!');
- set(handles.edit1,'backgroundcolor',[1 0/255 0]);
- end
- % 中断处理程序
- function recive_data(t, event, handles)
- if(getappdata(handles.caiji,'ApplicationData')~=0) % 收到单击采集信号的信息
- g = handles.sbuff;
- [out,huanchongcout] = fread(g,10); % 读取数据
- % plot(handles.axes1,out);
- % 解析数据
- if(out(1)==128 && bitxor(bitxor(bitxor(bitxor(out(2),out(3)),out(4)),out(5)),out(6)) == out(7))
- data2 = dec2bin(out(2),8);
- data3 = dec2bin(out(3),8);
- data4 = dec2bin(out(4),8);
- data5 = dec2bin(out(5),8);
- data6 = dec2bin(out(6),8);
- cur_data0 = 0; % 初始化脉冲值
- cur_data1 = dec2bin(cur_data0,32); % 转成二进制,有效位数为32
- cur_data1(1:4) = data6(5:8);
- cur_data1(5:11) = data5(2:8);
- cur_data1(12:18) = data4(2:8);
- cur_data1(19:25) = data3(2:8);
- cur_data1(26:32) = data2(2:8);
- cur_data2 = cur_data1;
- set(handles.current_data,'String',bin2dec(cur_data2));
- end
- if(getappdata(handles.save,'ApplicationData') ~=0) % 开始存储数据
- File = get(handles.save_play,'String');
- fid = fopen(File,'a');
- fprintf(fid,'%d\t',bin2dec(cur_data2));
- fprintf(fid,'\n');
- fclose(fid);
- end
- end
- % --- Executes on button press in off.
- function off_Callback(hObject, eventdata, handles)
- % hObject handle to off (see GCBO)
- s = handles.sbuff; % 传递
- fclose(s); % 关闭串口设备对象
- delete(s); % 删除内存中的串口设备对象
- clear s; % 清除工作区间的串口设备对象
- setappdata(handles.axes1,'ApplicationData',0); % 清空缓存数据
- set(handles.axes1,'UserData',0); % 将计数器清0
- set(handles.save,'UserData',0); % 将数据保存区清0
- set(handles.edit1,'String','串口关闭');
- set(handles.edit1,'backgroundcolor',[0 0/255 1]);
- set(handles.caiji,'Enable','Off');
- set(handles.on,'Enable','On');
- set(handles.save,'Enable','Off');
- set(handles.off,'Enable','Off');
- set(handles.exit,'Enable','On');
- % --- Executes on selection change in port.
- function port_Callback(hObject, eventdata, handles)
- % hObject handle to port (see GCBO)
- % Hints: contents = cellstr(get(hObject,'String')) returns port contents as cell array
- % contents{get(hObject,'Value')} returns selected item from port
- % --- Executes during object creation, after setting all properties.
- function port_CreateFcn(hObject, eventdata, handles)
- % handles empty - handles not created until after all CreateFcns called
- % Hint: popupmenu controls usually have a white background on Windows.
- % See ISPC and COMPUTER.
- if ispc && isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor'))
- set(hObject,'BackgroundColor','white');
- end
- % --- Executes on selection change in botelv.
- function botelv_Callback(hObject, eventdata, handles)
- % hObject handle to botelv (see GCBO)
- % Hints: contents = cellstr(get(hObject,'String')) returns botelv contents as cell array
- % contents{get(hObject,'Value')} returns selected item from botelv
- function botelv_CreateFcn(hObject, eventdata, handles)
- end
- % --- Executes on selection change in dataw.
- function dataw_Callback(hObject, eventdata, handles)
- % hObject handle to dataw (see GCBO)
- % Hints: contents = cellstr(get(hObject,'String')) returns dataw contents as cell array
- % contents{get(hObject,'Value')} returns selected item from dataw
- function dataw_CreateFcn(hObject, eventdata, handles)
- end
- % --- Executes on selection change in jiaoyanw.
- function jiaoyanw_Callback(hObject, eventdata, handles)
- % hObject handle to jiaoyanw (see GCBO)
- % Hints: contents = cellstr(get(hObject,'String')) returns jiaoyanw contents as cell array
- % contents{get(hObject,'Value')} returns selected item from jiaoyanw
- function jiaoyanw_CreateFcn(hObject, eventdata, handles)
- end
- % --- Executes on selection change in stopw.
- function stopw_Callback(hObject, eventdata, handles)
- % hObject handle to stopw (see GCBO)
- % Hints: contents = cellstr(get(hObject,'String')) returns stopw contents as cell array
- % contents{get(hObject,'Value')} returns selected item from stopw
- function stopw_CreateFcn(hObject, eventdata, handles)
- end
- function axes1_CreateFcn(hObject, eventdata, handles)
- % hObject handle to axes1 (see GCBO)
- % Hint: place code in OpeningFcn to populate axes1
- end
- % --- Executes on button press in caiji.
- function caiji_Callback(hObject, eventdata, handles)
- % hObject handle to caiji (see GCBO)
- % data = handles.data;
- % 发送信号,传递给中断,将信号暂存在采集控件中
- % t = str2num(get(handles.save_time,'String'));
- index = get(handles.save_lujin,'UserData'); % 是否设定存储路径
- [a,b] = fread(g);
- if ( b==0 )
- msgbox('当前无数据输入!');
- else
- if(get(handles.caiji,'UserData')==0)
- set(handles.caiji,'String','停止采集');
- set(handles.caiji,'BackgroundColor',[1 0 0]);
- setappdata(handles.caiji,'ApplicationData',1); % 用于传递给中断响应函数,可以接收并显示数据了
- set(handles.caiji,'UserData',1);
- if( index~=0 ) % 设定存储条件
- set(handles.save,'Enable','On');
- else
- end
- else
- set(handles.caiji,'String','开始采集');
- setappdata(handles.caiji,'ApplicationData',0);
- set(handles.caiji,'BackgroundColor',[0.8 0.8 0.8]);
- set(handles.save_time,'String',0);
- end
- end
- % --- Executes on button press in save.
- function save_Callback(hObject, eventdata, handles)
- % hObject handle to save (see GCBO)
- % 发送开始存储信号,并带有时间控制功能
- setappdata(handles.save,'ApplicationData',1);
- % g = handles.sbuff;
- % [data,b] = fread(g)
- t = str2num(get(handles.save_time,'String'));
- acc_time = t; % 中间变量
- set(handles.time_play,'String',num2str(t));
- for i = 1:t % 时间显示
- pause(0.995);
- set(handles.time_play,'String',num2str(acc_time-1));
- acc_time = acc_time-1;
- end
- % File = get(handles.save_play,'String'); % 获取存储路径
- % fopen(File);
- % fprintf(File,'%12.8e\t',data);
- % save ( File ,'uint8','data');
- % --- Executes on button press in exit.
- function exit_Callback(hObject, eventdata, handles)
- % hObject handle to exit (see GCBO)
- close(gcbf);
- function save_play_Callback(hObject, eventdata, handles)
- % hObject handle to save_play (see GCBO)
- % Hints: get(hObject,'String') returns contents of save_play as text
- % str2double(get(hObject,'String')) returns contents of save_play as a double
- function save_play_CreateFcn(hObject, eventdata, handles)
- % Hint: edit controls usually have a white background on Windows.
- end
- % --- Executes on button press in save_lujin.
- function save_lujin_Callback(hObject, eventdata, handles)
- % hObject handle to save_lujin (see GCBO)
- [file, pathname, index] = uiputfile({'*.txt';'*.dat';'*.mat'},'文件另存为');
- file1 = strcat(pathname,file);
- set(handles.save_play,'String',file1);
- set(handles.save_lujin,'UserData',index); % 判断是否设定了保存文件的路径
- function save_time_Callback(hObject, eventdata, handles)
- % hObject handle to save_time (see GCBO)
- % Hints: get(hObject,'String') returns contents of save_time as text
- % str2double(get(hObject,'String')) returns contents of save_time as a double
- function save_time_CreateFcn(hObject, eventdata, handles)
- end
- function time_play_CreateFcn(hObject, eventdata, handles)
- % hObject handle to time_play (see GCBO)
- function current_data_Callback(hObject, eventdata, handles)
- % hObject handle to current_data (see GCBO)
- % Hints: get(hObject,'String') returns contents of current_data as text
- % str2double(get(hObject,'String')) returns contents of current_data as a double
- function current_data_CreateFcn(hObject, eventdata, handles)
- end
