使用到的模块有9g舵机,步进电机人体感应模块,金属探测模块,LCD1602显示屏,原理图如下:
- #include "main.h"
- #include "HX711.h"
- #include "uart.h"
- #include "LCD1602.h"
- #include "temp.h"
- #define uchar unsigned char
- #define uint unsigned int
- typedef unsigned char u8;
- typedef unsigned short int u16;
- unsigned long HX711_Buffer = 0;
- unsigned long Weight_Maopi = 0;
- long Weight_Shiwu = 0;
- unsigned long Weight_Maopi1 = 0;
- long Weight_Shiwu1 = 0;
- long Weight_Shiwu3 = 000;
- long Weight_Shiwu4 = 10;
- unsigned char flag = 0;
- bit Flag_ERROR = 0;
- bit Flag_send = 0;
- sbit People= P3^6;
- sbit JINSHU= P3^2;
- unsigned char a;
- char qingpin=0;
- char shuju[]="0123456789";
- int TEMP=0;
- //校准参数
- //因为不同的传感器特性曲线不是很一致,因此,每一个传感器需要矫正这里这个参数才能使测量值很准确。
- //当发现测试出来的重量偏大时,增加该数值。
- //如果测试出来的重量偏小时,减小改数值。
- //该值可以为小数
- #define GapValue 390
- void Get_Maopi1();
- void Get_Weight1();
- char Key_Scan(char mode);
- void TaoCan(void);
- int LcdDisplay(int temp); //lcd显示
- void BuJing_Crole1(u16 j,u16 time);
- void BuJing_Crole2(u16 j,u16 time);
- //主函数
- sbit CTRL = P3^7; //舵机控制端口
- void delay_100ms(u16 x);
- u16 TIME = 20000; //PWM周期时间(单位us)
- u16 Min = 800; //高电平最小持续时间
- u16 Max = 2200; //高电平最大持续时间
- u16 aTime = 800; //高电平持续时间
- u8 Degree = 200; //单位时间宽度
- u8 R_TH0 = 0, R_TL0 = 0; //定时器0计数重载值
- void main()
- char flage=0;
- CTRL = 0;
- R_TL0 = 65536 - TIME;
- R_TH0 = (65536 - TIME) >> 8;
- //设置定时器0
- TMOD = 0x01; //16位计数
- TL0 = R_TL0;
- TH0 = R_TH0;
- ET0 = 1; //定时器0中断开关打开
- TR0 = 1; //定时器0计数开始
- //设置定时器1
- TMOD |= 0x10; //16位计数
- TL1 = 65536 - aTime;
- TH1 = (65536 - aTime) >> 8;
- ET1 = 1; //定时器1中断开关打开
- TR1 = 0; //定时器1计数停止
- EA = 1;
- //中断总开关打开
- Init_LCD1602();//屏幕初始化
- aTime=2300;//关垃圾桶盖
- Delay_ms(1000); //延时,等待传感器稳定
- Get_Maopi1(); //称毛皮重量,误差校验
- while(1)
- if(People==1&&flage==0)
- flage=1;
- aTime=1400;//开盖
- LCD1602_write_com(0x80);
- LCD1602_write_word("People:Y");
- BuJing_Crole1(2000,3);
- Delay_ms(1500);
- while(1)
- while(1)
- if(JINSHU==1)
- LCD1602_write_word("JS:Y");
- Delay_ms(1500);
- LCD1602_write_com(0x89);
- BuJing_Crole2(260,3);
- else{
- LCD1602_write_word("JS:N");
- Delay_ms(1500);
- BuJing_Crole2(26
- 0,3);
- while(1)
- LCD1602_write_com(0x80+0x40);//1602位置命令
- Get_Weight1(); //称重
- LCD1602_write_word("W:");
- LCD1602_write_data(Weight_Shiwu1/1000 + 0X30);
- LCD1602_write_data(Weight_Shiwu1%1000/100 + 0X30);
- LCD1602_write_data(Weight_Shiwu1%100/10 + 0X30);
- LCD1602_write_data(Weight_Shiwu1%10 + 0X30);
- LCD1602_write_word("g");
- Delay_ms(1000);
- if(Weight_Shiwu1>=10)
- LCD1602_write_com(0x01);
- break;
- break;
- break;
- }else{
- flage=0;
- LCD1602_write_word("People:W");
- //称重
- void Get_Weight()
- Weight_Shiwu = HX711_Read();//读取HX711AD采集值
- Weight_Shiwu = Weight_Shiwu - Weight_Maopi; //获取净重
- if(Weight_Shiwu > 0) //判断采集值正负
- Weight_Shiwu = (unsigned int)((float)Weight_Shiwu/GapValue); //计算实物的实际重量
- else
- Weight_Shiwu = 0;//
- Weight_Shiwu1 = HX711_Read1();
- Weight_Shiwu1 = Weight_Shiwu1 - Weight_Maopi1; //获取净重
- if(Weight_Shiwu1 > 0)
- Weight_Shiwu1 = (unsigned int)((float)Weight_Shiwu1/GapValue); //计算实物的实际重量
- else
- Weight_Shiwu1 = 0;
- //获取毛皮重量
- void Get_Maopi()
- Weight_Maopi = HX711_Read();
- void Get_Maopi1()
- Weight_Maopi1 = HX711_Read1();
- //MS延时函数(12M晶振下测试)
- void Delay_ms(unsigned int n)
- unsigned int i,j;
- for(i=0;i<n;i++)
- for(j=0;j<123;j++);
- int LcdDisplay(int temp) //lcd显示
- unsigned char i, datas[] = {0, 0, 0, 0, 0}; //定义数组
- float tp;
- if(temp< 0) //当温度值为负数
- LCD1602_write_com(0x80); //写地址 80表示初始地址
- LCD1602_write_data('-'); //显示负
- //因为读取的温度是实际温度的补码,所以减1,再取反求出原码
- temp=temp-1;
- temp=~temp;
- tp=temp;
- temp=tp*0.0625*100+0.5;
- //留两个小数点就*100,+0.5是四舍五入,因为C语言浮点数转换为整型的时候把小数点
- //后面的数自动去掉,不管是否大于0.5,而+0.5之后大于0.5的就是进1了,小于0.5的就
- //算由?.5,还是在小数点后面。
- else
- LCD1602_write_data('+'); //显示正
- tp=temp;//因为数据处理有小数点所以将温度赋给一个浮点型变量
- //如果温度是正的那么,那么正数的原码就是补码它本身
- //算加上0.5,还是在小数点后面。
- datas[0] = temp / 10000;
- datas[1] = temp % 10000 / 1000;
- datas[2] = temp % 1000 / 100;
- datas[3] = temp % 100 / 10;
- datas[4] = temp % 10;
- LCD1602_write_com(0x82); //写地址 80表示初始地址
- LCD1602_write_data(datas[0]+0x30); //百位
- LCD1602_write_com(0x83); //写地址 80表示初始地址
- LCD1602_write_data(datas[1]+0x30); //十位
- LCD1602_write_com(0x84); //写地址 80表示初始地址
- LCD1602_write_data(datas[2]+0x30); //个位
- LCD1602_write_com(0x85); //写地址 80表示初始地址
- LCD1602_write_data('.'); //显示 ‘.’
- LCD1602_write_com(0x86); //写地址 80表示初始地址
- LCD1602_write_data(datas[3]+0x30); //显示小数点
- LCD1602_write_com(0x87); //写地址 80表示初始地址
- LCD1602_write_data(datas[4]+0x30); //显示小数点
- temp=datas[1]*10+datas[2];
- return temp;
- void timer0() interrupt 1 using 1
- TL0 = R_TL0;
- TH0 = R_TH0;
- TR1 = 1;
- CTRL = 1;
- //定时器1中断函数
- void timer1() interrupt 3 using 1
所有参考资料51hei提供下载:
智能垃圾桶.7z
(1.94 MB, 下载次数: 153)
