- #include<reg52.h>
- sbit KEY1 = P3^0;
- sbit KEY2 = P3^1;
- sbit KEY3 = P3^2;
- sbit KEY4 = P3^3;
- unsigned char code LedChar[] = {
- 0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8,
- 0x80, 0x90, 0x88, 0x83, 0xC6, 0xA1, 0x86, 0x8E
- unsigned char LedBuff[6] = {
- 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF
- unsigned char KeySta[4] = {1,1,1,1};
- unsigned char T0RH = 0;
- unsigned char T0RL = 0;
- bit kd = 0;
- bit lk = 1;
- bit stopwatchRefresh = 1;
- bit stopwatchRunning = 0;
- unsigned char DecimalPart = 0;
- unsigned int IntegerPart = 0;
- void ConfigTimer0(unsigned int ms);
- void stopwatchDisplay();
- void KeyDriver();
- void main()
- EA = 1;
- ConfigTimer0(2);
- while(1)
- if(stopwatchRefresh)
- stopwatchRefresh = 0;
- stopwatchDisplay();
- KeyDriver();
- unsigned long tmp;
- tmp = 11059200/12;
- tmp = (tmp*ms)/1000;
- tmp = 65536 - tmp;
- tmp +=18;
- T0RH = (unsigned char)(tmp>>8);
- T0RL = (unsigned char)tmp;
- TMOD &=0xf0;
- TMOD |=0X01;
- TH0 = T0RH;
- TL0 = T0RL;
- ET0 = 1;
- TR0 = 1;
- signed char i;
- unsigned char buf[4];
- LedBuff[0] = LedChar[DecimalPart%10];
- LedBuff[1] = LedChar[DecimalPart/10];
- buf[0] = IntegerPart%10;
- buf[1] = IntegerPart/10%10;
- buf[2] = IntegerPart/100%10;
- buf[3] = IntegerPart/1000%10;
- for(i=3;i>=1;i--)
- if(buf[ i]==0)
- LedBuff[i+2]=0xFF;
- }else break;
- for(;i>=0;i--)
- LedBuff[i+2] = LedChar[buf[ i]];
- LedBuff[2] &=0x7f;
- void Stopwatchjc()
- signed char i;
- static unsigned char Dec[10] = 0;
- static unsigned int Int[10] = 0;
- static char cnt = 0;
- static char cnt1 = 0;
- Dec[cnt] = DecimalPart;
- Int[cnt] = IntegerPart;
- cnt++;
- if(kd == 1)
- LedBuff[0] = LedChar[Dec[cnt1]%10];
- LedBuff[1] = LedChar[Dec[cnt1]/10];
- buf[0] = Int[cnt1]%10;
- buf[1] = Int[cnt1]/10%10;
- buf[2] = Int[cnt1]/100%10;
- buf[3] = Int[cnt1]/1000%10;
- for(i=3;i>=1;i--)
- if(buf[ i]==0)
- }else break;
- for(;i>=0;i--)
- cnt1++;
- void Stopwatchsy()
- stopwatchRunning = 0;
- kd = 1;
- stopwatchRefresh = 1;
- void StopwatchAction()
- stopwatchRunning = ~stopwatchRunning;
- void StopwatchReset()
- lk = 0;
- DecimalPart = 0;
- IntegerPart = 0;
- void KeyDriver()
- static unsigned char backup[4] = {1,1,1,1};
- unsigned char i;
- for(i=0;i<4;i++)
- if (KeySta[ i] != backup[ i])
- if (backup[ i] == 0)
- if(i==0)
- Stopwatchjc();
- else if(i==1)
- Stopwatchsy();
- else if(i==2)
- StopwatchReset();
- else if(i==3)
- StopwatchAction();
- backup[ i] = KeySta[ i];
- void LedScan()
- static unsigned char i=0;
- P0 = 0xFF;
- switch(i) //??1y1ms′óμíμ??????¢D?ò???êy??1ü
- case 0:P2=0x01;i++; P0= LedBuff[0]; break;
- case 1:P2=0x02;i++; P0= LedBuff[1]; break;
- case 2:P2=0x04;i++; P0= LedBuff[2]; break;
- case 3:P2=0x08;i++; P0= LedBuff[3]; break;
- case 4:P2=0x10;i++; P0= LedBuff[4]; break;
- case 5:P2=0x20;i=0; P0= LedBuff[5]; break;
- default :break;
- void KeyScan()
- static unsigned char keybuf[4] ={ 0xFF,0xFF,0xFF,0xFF};
- keybuf[0] = (keybuf[0]<<1) | KEY1;
- keybuf[1] = (keybuf[1]<<1) | KEY2;
- keybuf[2] = (keybuf[2]<<1) | KEY3;
- keybuf[3] = (keybuf[3]<<1) | KEY4;
- for(i=0;i<4;i++)
- if (keybuf[ i] == 0x00)
- KeySta[ i] = 0;
- else if (keybuf[ i] == 0xFF)
- KeySta[ i] = 1;
- else
- void StowatchCount()
- if(stopwatchRunning)
- DecimalPart++;
- if(DecimalPart>=100)
- DecimalPart=0;
- IntegerPart++;
- if(IntegerPart>=10000)
- IntegerPart=0;
- stopwatchRefresh=1;
- void InterruptTimer0() interrupt 1
- static unsigned char ter10ms = 0;
- TH0 = T0RH;
- TL0 = T0RL;
- LedScan();
- KeyScan();
- ter10ms++;
- if (ter10ms>=5)
- ter10ms = 0;
- StowatchCount();
复制代码 |
