查看: 5337|回复: 7
关于Proteus仿真1602液晶的问题,JHD-2x16-i2c这个元件
ID:97554 发表于 2020-6-23 10:00 | 显示全部楼层
#include <reg51.h>
#include <intrins.h>
sbit SCL=P2^1;
sbit SDA=P2^2;
void delay(void);
void delay_ms(uint ms);
void write_dat(uchar dat);
void write_ndat(uchar *dat, uchar length);
void write_cmd(uchar cmd);
void write_CGRAM(void);
void lcd_init(void);
void display(void);
void display2(void);
uchar code tab1[]="ABCDEFGHIJKLMNOP";
uchar code tab2[]="1234567890abcdef";
uchar code zimu[][8]={{0x00,0xff,0x04,0x04,0xff,0x04,0x04,0xff},                //王
        {0x00,0x00,0xff,0x15,0xff,0x15,0xff,0x00},                //田
        {0x00,0x00,0x00,0x00,0xff,0x00,0x00,0x00},                //一
        {0x00,0x00,0x0e,0x00,0x00,0xff,0x00,0x00},                //二
        {0x00,0x00,0x0e,0x00,0x0e,0x00,0xff,0x00},                //三
        {0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55},
        {0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55}};
void main(void)
        //P2M0 = 0X00;        P2M1 = 0X00;                //P2端口配置为准双向口
        lcd_init();
//             write_CGRAM();
                display();
                display2();
void delay(void)                                        //几us的延时
        uchar i = 2;
        while(i--);
void delay_ms(uint ms)                //大约ms级的延时
        uint i,j;
        for(j=0;j<ms;j++)
                for(i=0;i<1000;i++);
void i2c_start(void)                        //开始信号
{        //SCL为高时,SDA下降沿
        SDA = 1;
        SCL = 1;
        delay();
        SDA = 0;
        delay();
void i2c_stop(void)                                //停止信号
{        //SCL为高时,SDA上升沿
        SDA = 0;
        SCL = 1;
        delay();
        SDA = 1;
        delay();
void ack(void)                                                //ACK应答
{        //第九个时钟,应答检测
        SCL = 0;
        delay();
        SDA = 1;
        SCL = 1;
        while(SDA);
        delay();
        SCL = 0;
        delay();
void i2c_write(uchar dat)        //写8bit数据
        uchar i;
        for(i = 0; i < 8; i++)
                SCL = 0;
                SDA = dat & 0x80;
                delay();
                SCL = 1;
                dat <<= 1;
                delay();
        ack();
uchar i2c_read(void)                        //读8bit数据
        uchar temp,i;
        for (i = 0;i < 8;i++)
                SCL = 1;
                delay();
                temp <<= 1;
                temp |= SDA;
                SCL = 0;
                delay();
        SDA = 1;
        SCL = 1;
        delay();
        SCL = 0;
        delay();
        return temp;
        write_ndat(&dat,1);
void write_ndat(uchar *dat, uchar length)        //写数据
        uchar i;
        i2c_start();                                                        //开始
        i2c_write(0x7c);                                        //写从机地址
        for(i=0;i<length-1;i++)                //写length长度地址
                i2c_write(0xc0);                                //写数据指令
                i2c_write(dat[i]);
        i2c_write(0x40);                                        //传输数据停止标志位
        i2c_write(dat[i]);
        i2c_stop();        //停止
void write_cmd(uchar cmd)                //写指令
        i2c_start();                                                        //开始
        i2c_write(0x7c);                                        //从机地址
        i2c_write(0x80);                                        //写指令
        i2c_write(cmd);
        i2c_stop();        //停止
void write_CGRAM(void)                        //造字
        uchar i;
        write_cmd(0x40);                                        //CGRAM地址
        for(i=0;i<8;i++)
                write_ndat(&zimu[i-1][8],8);
void lcd_init(void)                                        //初始化
        write_cmd(0X38);                                        //2行模式,5*8点阵
        write_cmd(0x0c);                                        //开显示
        write_cmd(0x01);                                        //清显示
        delay_ms(2);
        write_cmd(0x06);                                         //光标设置
void display(void)
        write_cmd(0x80);                                        //第一行
        write_ndat(tab1,16);                                //显示数据
        write_cmd(0xc0);                                        //第二行
        delay_ms(800);
        delay_ms(2);
void display2(void)
        write_ndat(tab2,16);                                //显示数据
        delay_ms(800);
        delay_ms(2);
void display3(void)
        delay_ms(800);
        delay_ms(2);
51模拟IIC驱动,你试下吧。
参与人数 1黑币 +40 收起 理由
admin + 40 回帖助人的奖励!
ID:97554 发表于 2020-6-23 10:03 | 显示全部楼层
上边不是写着CONTROLLER: AIP31068吗?不是PCF8574
