查看: 3829|回复: 1
stm32定时器制舵机,电调,电机,pwm调速度三合一程序源码
此程序用stm32定时器,调节pwm,来控制电机的速度。
  1. #include  "pwm.h"
  2. #include  "stm32f10x_tim.h"
  3. #include "pbdata.h"
  4. void PWM_Init(void)
  5. {
  6.
  7.
  8.          GPIO_InitTypeDef GPIO_InitStructure;
  9.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
  10.     RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE);
  11.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);
  12.         GPIO_InitStructure.GPIO_Pin=GPIO_Pin_6|GPIO_Pin_7;
  13.         GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
  14.         GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;
  15.         GPIO_Init(GPIOA,&GPIO_InitStructure);
  16.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);
  17.     RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE);
  18.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);
  19.         GPIO_InitStructure.GPIO_Pin=GPIO_Pin_0;
  20.         GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
  21.         GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;
  22.         GPIO_Init(GPIOB,&GPIO_InitStructure);
  23.
  24. }
  25. unsigned char TIM3_Configuration(u16 pulse)
  26. {
  27.         TIM_TimeBaseInitTypeDef  TIM_TimeBaseStruct;
  28.         TIM_OCInitTypeDef TIM_OCInitStructure;
  29.         //GPIO_PinRemapConfig(GPIO_PartialRemap_TIM3,ENABLE);
  30.         //定时器初始化
  31.         TIM_DeInit(TIM3);
  32.         TIM_TimeBaseStruct.TIM_Period=20000-1;//20000-1周期为20ms,因为寄存器要自加1,所以先减1
  33.         TIM_TimeBaseStruct.TIM_Prescaler=72-1;//预分频
  34.         TIM_TimeBaseStruct.TIM_ClockDivision=TIM_CKD_DIV1;
  35.         TIM_TimeBaseStruct.TIM_CounterMode=TIM_CounterMode_Up;//向上
  36.         TIM_TimeBaseInit(TIM3,&TIM_TimeBaseStruct);
  37.
  38.         //pwm 初始化
  39.         TIM_OCInitStructure.TIM_OCMode=TIM_OCMode_PWM1;
  40.         TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable;
  41.         TIM_OCInitStructure.TIM_Pulse=pulse;                 //高电平所占的时间
  42.         TIM_OCInitStructure.TIM_OCPolarity=TIM_OCPolarity_High;
  43.         TIM_OC1Init(TIM3,&TIM_OCInitStructure);
  44.         TIM_OC1PreloadConfig(TIM3,TIM_OCPreload_Enable);
  45.         TIM_Cmd(TIM3,ENABLE);
  46.         return pulse;
  47. }
  48. unsigned char TIM3A_Configuration(u16 pulse1)
  49. {
  50.         TIM_TimeBaseInitTypeDef  TIM_TimeBaseStruct;
  51.         TIM_OCInitTypeDef TIM_OCInitStructure;
  52.         //        GPIO_PinRemapConfig(GPIO_PartialRemap_TIM3,ENABLE);
  53.         //定时器初始化
  54.         TIM_DeInit(TIM3);
  55.         TIM_TimeBaseStruct.TIM_Period=20000-1;//20000-1周期为20ms,因为寄存器要自加1,所以先减1
  56.         TIM_TimeBaseStruct.TIM_Prescaler=72-1;//预分频
  57.         TIM_TimeBaseStruct.TIM_ClockDivision=TIM_CKD_DIV1;
  58.         TIM_TimeBaseStruct.TIM_CounterMode=TIM_CounterMode_Up;//向上
  59.         TIM_TimeBaseInit(TIM3,&TIM_TimeBaseStruct);
  60.
  61.         //pwm 初始化
  62.         TIM_OCInitStructure.TIM_OCMode=TIM_OCMode_PWM1;
  63.         TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable;
  64.         TIM_OCInitStructure.TIM_Pulse=pulse1;                 //高电平所占的时间
  65.         TIM_OCInitStructure.TIM_OCPolarity=TIM_OCPolarity_High;
  66.         TIM_OC2Init(TIM3,&TIM_OCInitStructure);
  67.         TIM_OC2PreloadConfig(TIM3,TIM_OCPreload_Enable);
  68.         TIM_Cmd(TIM3,ENABLE);
  69.         return pulse1;
  70. }
  71. unsigned char TIM3DIANTIAO1_Config(u16 diantiao_pulse)
  72.   {
  73.         TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  74.         TIM_OCInitTypeDef  TIM_OCInitStructure;
  75.   TIM_TimeBaseStructure.TIM_Period = 19999;       //当定时器从0计数到999,即为1000次,为一个定时周期
  76.   TIM_TimeBaseStructure.TIM_Prescaler = 71;            //设置预分频:不预分频,即为72MHz
  77.   TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1 ;        //设置时钟分频系数:不分频
  78.   TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //向上计数模式
  79.   TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
  80.   TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;            //配置为PWM模式1
  81.   TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  82.   TIM_OCInitStructure.TIM_Pulse = diantiao_pulse;           //设置跳变值,当计数器计数到这个值时,电平发生跳变
  83.   TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;  //当定时器计数值小于CCR1_Val时为高电平
  84.   TIM_OC3Init(TIM3, &TIM_OCInitStructure);         //使能通道3
  85.   TIM_OC3PreloadConfig(TIM3, TIM_OCPreload_Enable);
  86.    TIM_ARRPreloadConfig(TIM3, ENABLE);                         // 使能TIM3重载寄存器ARR
  87.   TIM_Cmd(TIM3, ENABLE);
  88.
  89.   return diantiao_pulse;
  90. }
Keil代码 舵机,电调,电机三合一.7z (191.09 KB, 下载次数: 77)
收藏收藏2 分享淘帖 顶顶 踩踩
ID:289512 发表于 2018-3-31 09:16 | 只看该作者
谢谢楼主分享,找资料当中。
