51单片机定时器LCD显示加音乐
- #include<reg51.h> //调用51单片机的头文件
- #define uchar unsigned char
- #define uint unsigned int
- //1602液晶相关I/O设置
- //sbit E=P2^3; //1602液晶的E脚接在P2.3口上
- //sbit RW=P2^4; //1602液晶的RW脚接在P2.4口上
- //sbit RS=P2^5; //1602液晶的RS脚接在P2.5口上
- sbit E=P2^7; //1602液晶的E脚接在P2.3口上
- sbit RW=P2^5; //1602液晶的RW脚接在P2.4口上
- sbit RS=P2^6; //1602液晶的RS脚接在P2.5口上
- sbit Busy=P0^7;
- //按键相关I/O设置
- sbit key1=P3^0;
- sbit key2=P3^1;
- sbit key3=P3^2;
- //sbit beep = P1^3;
- sbit beep = P1^5;
- uchar code word1[]={" TIME STOP "};
- uchar code word2[]={" TIME SET! "};
- uchar code word3[]={" TIME START "};
- unsigned char i;
- unsigned char menu;
- signed int Time_bai,Time_ge;
- bit Adjust;
- //1602液晶寄存器设置
- unsigned int DISbuf_ge,DISbuf_bai; //设置16位的unsigend int型寄存器用来暂存1602要显示的内容
- uchar code SONG_TONE[]={212,212,190,212,159,169,212,212,190,212,142,159,
- 212,212,106,126,159,169,190,119,119,126,159,142,159,0};
- uchar code SONG_LONG[]={9,3,12,12,12,24,9,3,12,12,12,24,
- 9,3,12,12,12,12,12,9,3,12,12,12,24,0};
- void Display();
- void DelayMS(uint ms)
- uchar t;
- while(ms--)
- for(t=0;t<120;t++);
- void PlayMusic()
- uint i=0,j,k;
- while(SONG_LONG[i]!=0||SONG_TONE[i]!=0)
- { //播放各个音符,SONG_LONG 为拍子长度
- for(j=0;j<SONG_LONG[i]*20;j++)
- beep=~beep;
- if(Adjust==1)
- break;
- //SONG_TONE 延时表决定了每个音符的频率
- for(k=0;k<SONG_TONE[i]/3;k++);
- DelayMS(70);
- i++;
- void led()
- P2 = P2 << 1; //第一次循环,led1亮,其他都不亮
- if(P2 == 0x00) //全部移出
- P2 = 0x01;
- //名称:1602液晶用延时函数
- void Delay1602(unsigned int t)
- unsigned int k; //定义一个16位寄存器用来做延时用
- for(k=0;k<t;k++); //延时
- //名称:1602液晶忙检测函数
- void LCD1602_busy(void)
- Busy=1; //将P0.7置1,为读状态做准备
- RS=0; //RS=0、RW=1、E=1时,忙信号输出到DB7,由P0.7读入
- RW=1; //RS=0、RW=1、E=1时,忙信号输出到DB7,由P0.7读入
- E=1; //RS=0、RW=1、E=1时,忙信号输出到DB7,由P0.7读入
- while(Busy==1); //由P0.7读入1,表示1602液晶忙,需要等待
- E=0; //读完以后,恢复E的电平
- //名称:1600写命令函数
- //适用:给力者GL9单片机开发学习系统
- //公司:宁波芯动电子有限公司
- //网址:www.MovingChip.com
- //日期:20120914
- void LCD1602_Write_com(unsigned char combuf)
- RS=0; //选择指令寄存器
- RW=0; //选择写状态
- P0=combuf; //将命令字通过P0口送至DB
- E=1; //E高电平将命令字写入1602液晶
- E=0; //写完以后,恢复E的电平
- //名称:1602写命令函数(带忙检测)
- void LCD1602_Write_com_busy(unsigned char combuf)
- LCD1602_busy(); //调用忙检测函数
- LCD1602_Write_com(combuf); //调用忙检测函数
- //名称:1602写数据函数(带忙检测)
- void LCD1602_Write_data_busy(unsigned char databuf)
- RS=1; //选择数据寄存器
- RW=0; //选择写状态
- P0=databuf; //将命令字通过P0口送至DB
- //名称:1602液晶显示地址写函数
- //公司:宁波芯动电子有限公司
- //日期:20120914
- void LCD1602_Write_address(unsigned char x,unsigned char y)
- x&=0x0f; //列地址限制在0-15间
- y&=0x01; //行地址限制在0-1间
- if(y==0) //如果是第一行
- LCD1602_Write_com_busy(x|0x80); //将列地址写入
- else //如果是第二行
- LCD1602_Write_com_busy((x+0x40)|0x80); //将列地址写入
- //名称:1602液晶初始化函数
- void LCD1602_init(void)
- Delay1602(1500); //调用延时函数
- LCD1602_Write_com(0x38); //8位数据总线,两行显示模式,5*7点阵显示
- Delay1602(500); //调用延时函数
- LCD1602_Write_com_busy(0x38); //8位数据总线,两行显示模式,5*7点阵显示
- LCD1602_Write_com_busy(0x08); //显示功能关,无光标
- LCD1602_Write_com_busy(0x01); //清屏
- //LCD1602_Write_com_busy(0x06); //写入新的数据后,光标右移,显示屏不移动
- LCD1602_Write_com_busy(0x0C); //显示功能开,无光标
- //名称:1602液晶指定地址显示函数
- void LCD1602_Disp(unsigned char x,unsigned char y,unsigned char buf)
- LCD1602_Write_address(x,y); //先将地址信息写入
- LCD1602_Write_data_busy(buf); //再写入要显示的数据
- //名称:1602液晶将字符输出到液晶显示
- void Print(unsigned char x,unsigned char y,unsigned char *str)
- while(*str!='\0')
- LCD1602_Write_data_busy(*str);
- str++;
- //名称:Delay10ms延时10毫秒函数
- void Delay10ms(void) //误差 0us
- unsigned char a,b,c;
- for(c=1;c>0;c--)
- for(b=38;b>0;b--)
- for(a=130;a>0;a--);
- void keyscan()
- if(key1==0) //检测按键K1是否按下
- Delay10ms(); //消除抖动
- while(key1==0);
- menu++;
- if(menu==3)
- menu=1;
- Adjust=1;
- if(menu==1)
- Print(0,0,word2);
- DISbuf_bai=0;
- DISbuf_ge=0;
- LCD1602_Disp(2,1,DISbuf_bai/1000+'0'); //在第1行的第1列显示千位
- LCD1602_Disp(3,1,(DISbuf_bai%1000)/100+'0'); //在第1行的第2列显示百位
- LCD1602_Disp(4,1,':');
- LCD1602_Disp(5,1,(DISbuf_ge%100)/10+'0'); //在第1行的第3列显示十位
- LCD1602_Disp(6,1,DISbuf_ge%10+'0'); //在第1行的第4列显示个位
- if(key2==0) //检测按键K1是否按下
- while(key2==0);
- Time_ge++;
- if(Time_ge>59)
- Time_ge=0;
- Time_bai++;
- if(key3==0) //检测按键K1是否按下
- while(key3==0);
- Time_ge--;
- if(Time_ge<0)
- Time_ge=59;
- Time_bai--;
- if(menu==2)
- while(key2==0);
- Print(0,0,word3);
- Adjust=0;
- while(key3==0);
- Print(0,0,word1);
- Adjust=1;
- if(Adjust==0)
- Print(0,0,word3);
- else
- Print(0,0,word1);
- LCD1602_Disp(9,1,Time_bai/10+'0'); //在第1行的第1列显示千位
- LCD1602_Disp(10,1,Time_bai%10+'0'); //在第1行的第2列显示百位
- LCD1602_Disp(11,1,':');
- LCD1602_Disp(12,1,Time_ge/10+'0'); //在第1行的第3列显示十位
- LCD1602_Disp(13,1,Time_ge%10+'0'); //在第1行的第4列显示个位
- void Display()
- LCD1602_Disp(2,1,DISbuf_bai/10+'0'); //在第1行的第1列显示千位
- LCD1602_Disp(3,1,DISbuf_bai%10+'0'); //在第1行的第2列显示百位
- LCD1602_Disp(5,1,DISbuf_ge/10+'0'); //在第1行的第3列显示十位
- if(DISbuf_ge==Time_ge && DISbuf_bai==Time_bai)
- Adjust=1;
- //名称: 主函数
- void main(void) //主函数,单片机开机后就是从这个函数开始运行
- LCD1602_init(); //调用1602液晶初始化函数
- //***定时器Timer0初始化***
- TMOD&=0xF0; //将TMOD的低4位定时器0控制部分清零
- TMOD|=0x01; //设置定时器0为方式1
- TL0=0xFF; //设置定时器0初值低8位
- TH0=0x4B; //设置定时器0初值高8位
- TR0=1; //启动定时器0
- ET0=1; //Timer0中断允许
- //***开全局中断设置****
- //定时器Timer0设置了中断允许,此处要开全局中断
- EA=1; //开全局中断
- menu=2;
- Adjust=1;
- Time_bai=1;
- Time_ge=0;
- DISbuf_bai=0;
- DISbuf_ge=0;
- Print(0,0,word1);
- beep=1;
- P0 = 0x01;
- while(1) //死循环,单片机初始化后,将一直运行这个死循环
- if(Adjust==0) //非调节模式下显示时间和控制灯
- Display();
- PlayMusic(); //播放生日快乐
- //DelayMS(500); //播放完后暂停一段时间
- else
- beep = 1;
Project8.zip
(53.13 KB, 下载次数: 25)
