查看: 5985|回复: 3
单片机传送带产品计数器仿真及源程序
仿真图如下,程序及仿真文件可在附件中下载
单片机源程序:
  1. #include <reg51.h>
  2. #include <intrins.h>
  3. #define uchar  unsigned char
  4. #define uint   unsigned int
  5. #define ulong   unsigned long
  6. //用液晶屏显示参数
  7. uchar code zifx0[]="0123456789abcdef";
  8. uchar code zifu0[]="Now Number:0000";
  9. uchar code zifu1[]="Set Number:0000";
  10. sbit  RS=P3^1;        //写信号
  11. sbit  RWW=P3^3;        //读信号
  12. sbit  E=P3^4;   //使能信号
  13. #define e1   E=1
  14. #define rd1  RWW=1
  15. #define rs1  RS=1
  16. #define e0   E=0
  17. #define rd0  RWW=0
  18. #define rs0  RS=0
  19. #define PP P1
  20. //延时函数ms
  21. void _delay_ms(uint t)
  22. {
  23.    uint i,j;
  24.    for(i=0;i<t;i++)
  25.      for(j=0;j<120;j++);
  26. }
  27. //延时函数us
  28. void _delay_us(uchar t)
  29. {
  30.    while(t>0)t--;
  31. }
  32. //写1602控制字
  33. void  lcd1602_writecrtl(uchar  dat)
  34. {
  35.   rd0;//读信号置0
  36.   rs0;//写信号置0
  37.   _delay_us(5);
  38.   PP=dat;
  39.   e1;//使能信号置1
  40.   _delay_us(5);
  41.   e0;//使能信号置0
  42. }
  43. //写1602数据
  44. void  lcd1602_writenumber(uchar dat)
  45. {
  46.   rd0;//读信号置0
  47.   rs1;//写信号置1
  48.   _delay_us(5);
  49.   PP=dat;
  50.   e1;//使能信号置1
  51.   _delay_us(5);
  52.   e0;//使能信号置0
  53. }
  54. //1602初始化
  55. void  lcd1602_init()
  56. {
  57.   lcd1602_writecrtl(0x38); //显示模式
  58.   lcd1602_writecrtl(0x06); //显示光标移动位置
  59.   lcd1602_writecrtl(0x0c); //显示开及光标设置
  60.   lcd1602_writecrtl(0x01); //显示清屏
  61. }
  62. //显示地址
  63. void  lcd1602_adr(uchar dat)
  64. {
  65.   lcd1602_writecrtl(0x80 | dat);
  66. }
  67. //行显示-
  68. void LCD1602_string(uchar hang,uchar lie,uchar const *p)
  69. {
  70.         uchar a;
  71.         if(hang == 1) a = 0x00;
  72.         if(hang == 2) a = 0x40;
  73.         a = a + lie - 1;
  74.         lcd1602_adr(a);
  75.         while(1)
  76.         {
  77.                 if(*p == '\0') break;
  78.                 lcd1602_writenumber(*p);
  79.                 p++;
  80.         }
  81. }
  82. uint  keyn1=16;//按键值
  83. uint  keyn=16;//缓冲
  84. #define PK P2
  85. //按键扫描
  86. void key_z()
  87. {
  88. PK=0X0F;
  89. if(!(PK==0X0F))
  90. {
  91.     if(!(PK==0X0F))
  92.    {
  93.     keyn1=0;
  94.     keyn=0;
  95.     PK=0X0F;
  96.     if(PK==0X0E)         keyn1=0;
  97.     if(PK==0X0D)         keyn1=1;
  98.     if(PK==0X0B)         keyn1=2;
  99.     if(PK==0X07)         keyn1=3;
  100.     PK=0XF0;
  101.     if(PK==0XE0)         keyn=0+keyn1;
  102.     if(PK==0XD0)         keyn=4+keyn1;
  103.     if(PK==0XB0)         keyn=8+keyn1;
  104.     if(PK==0X70)         keyn=12+keyn1;
  105.     switch(keyn)
  106.     {
  107.             case 0: keyn1=1; break;
  108.             case 4: keyn1=2; break;
  109.             case 8: keyn1=3; break;
  110.             case 12:keyn1=10; break;
  111.             case 1: keyn1=4; break;
  112.             case 5: keyn1=5; break;
  113.             case 9: keyn1=6; break;
  114.             case 13:keyn1=11; break;
  115.             case 2: keyn1=7; break;
  116.             case 6: keyn1=8; break;
  117.             case 10:keyn1=9;break;
  118.      case 14:keyn1=12;break;
  119.           case 3: keyn1=14;break;//*
  120.             case 7: keyn1=0;break;
  121.             case 11:keyn1=15;break;//#
  122.             case 15:keyn1=13;break;
  123.      }
  124.     }
  125.   else   keyn1=16;
  126.   PK=0X0F;while((!(PK==0X0F)));
  127. }
  128. }//LED
  129. sbit led1=P0^0;
  130. sbit beer=P3^5;
  131. sbit out=P3^6;
  132. sbit k1=P3^7;
  133. sbit P32=P3^2;
  134. //变量
  135. uint  now=0;
  136. uint  set=10;
  137. uint  bzbu=0;//设置
  138. uint  bz=0;//模式
  139. uint  qidong=0;//运行
  140. //显示控制
  141. void dis()
  142. {
  143.   //now
  144.   lcd1602_adr(0x0B);
  145.   lcd1602_writenumber(0x30+now%10000/1000);
  146.   lcd1602_writenumber(0x30+now%1000/100);
  147.   lcd1602_writenumber(0x30+now%100/10);
  148.   lcd1602_writenumber(0x30+now%10);
  149.   //set
  150.   lcd1602_adr(0x4B);
  151.   lcd1602_writenumber(0x30+set%10000/1000);
  152.   lcd1602_writenumber(0x30+set%1000/100);
  153.   lcd1602_writenumber(0x30+set%100/10);
  154.   lcd1602_writenumber(0x30+set%10);
  155.   if(bz==0)lcd1602_writenumber(' ');
  156.   if(bz==1)lcd1602_writenumber('<');
  157.    //启动
  158.   if(bz==0)
  159.   {
  160.     if(k1==0){qidong=(qidong+1)%2;if(qidong==1){led1=0;;out=0;}else {led1=1;out=1;}while(k1==0);}
  161.    }
  162.    //启动
  163.   if(qidong==1)
  164.   {
  165.     if(now>=set){qidong=0;led1=1;out=1;beer=0;_delay_ms(500);  }
  166.    }
  167.    //启动
  168.   if(qidong==0)
  169.   {
  170.     beer=1;
  171.    }
  172. }
  173. //按键功能函数
  174. void key()
  175. {
  176.   //扫描
  177.   key_z();
  178.   if(keyn1<16)
  179.   {
  180.    if((keyn1<10)&&(bz==1))
  181.         {
  182.          if(bzbu==0){set=keyn1;}
  183.          if(bzbu==1){set=set*10+keyn1;}
  184.          if(bzbu==2){set=set*10+keyn1;}
  185.          if(bzbu==3){set=set*10+keyn1;}
  186.          bzbu=(bzbu+1)%4;
  187.          }
  188.         if((keyn1==0x0a)&&(bz==0)){now=0;}//复位
  189.         if((keyn1==0x0b)&&(bz==1)){set=0;}//复位输入
  190.         if((keyn1==0x0c)&&(qidong==0)){bz=1;}//设置
  191.         if(keyn1==0x0d){bz=0;}//退出
  192.         keyn1=16;
  193.   }
  194. }
  195. //-----------------------
  196. void main()
  197. {
  198.   _delay_us(10);
  199.   _delay_ms(10);
  200.   //中断允许
  201.   IT0=1;
  202.   EX0=1;
  203.   EA=1;
  204.   //初始化
  205.   lcd1602_init();
  206.   LCD1602_string(1,1,zifu0);
  207.   LCD1602_string(1,1,zifu0);
  208.   LCD1602_string(2,1,zifu1);
  209.   while(1)
  210.   {
  211.    dis(); //显示
  212.    key();
  213.   }
  214. }
  215. //INT0中断函数
  216. void  EX_INT0() interrupt 0
  217. {
  218. if(qidong==1)
  219. {
  220.   _delay_ms(3);if(P32==0)now=now+1;
  221. }
  222. }
全部资料51hei下载地址:
传送带产品计数器仿真及源程序.rar (68.7 KB, 下载次数: 92)
收藏收藏4 分享淘帖 顶 踩
ID:464382 发表于 2019-1-8 10:17 | 只看该作者
好资料,51黑有你更精彩!!!
ID:467397 发表于 2019-1-14 14:33 | 只看该作者
楼主,可以提供一下汇编语言吗,c不太会
ID:687931 发表于 2020-4-30 14:24 | 只看该作者
在吗?楼主
