用32的串口发送指令给GY-MCU90615 模块,然后通过串口回传温度,GY-MCU90615 模块的主要用法如下,检查了很多遍,但本应该回传的帧的头格式数据都收不到,下面时我的主函数,求大神帮我看看,卡了好长时间了
- #include "led.h"
- #include "delay.h"
- #include "sys.h"
- #include "usart.h"
- #include "lcd.h"
- u8* rebuff[9];
- void USART1_IRQHandler(void)
- int i;
- if(USART_GetITStatus(USART1,USART_IT_RXNE))//如果收到数据
- for(i=0;i<9;i++)
- *rebuff[i]=USART_ReceiveData( USART1);//读数据
- // USART_FLAG_RXNE=0;//清除标志位
- void send_commend(unsigned char com)//发送字节命令
- if(USART_GetFlagStatus( USART1, USART_FLAG_RXNE)==0)
- USART_SendData(USART1, com);
- int main(void)
- u8 times=0;
- delay_init(); //延时函数初始化
- NVIC_Configuration();// 设置中断优先级分组
- uart_init(9600); //串口初始化为9600
- LED_Init(); //初始化与LED连接的硬件接口
- LCD_Init();USART_SendData
- POINT_COLOR=RED;
- (USART1, 0xA5);
- USART_SendData(USART1, 0xAE);
- USART_SendData(USART1, 0x53);//配置波特率为9600;
- while(1)
- times++;
- USART_SendData(USART1, 0xA5);
- USART_SendData(USART1, 0x45);
- USART_SendData(USART1, 0xEA);
- LCD_ShowString(30,40,200,24,24,rebuff[0]);
- if(times%30==0)LED0=!LED0;//闪烁LED,提示系统正在运行.
- delay_ms(10);
- //USART 3õê¼»ˉéèÖÃ
- USART_InitStructure.USART_BaudRate = bound;//
- USART_InitStructure.USART_WordLength = USART_WordLength_8b;
- USART_InitStructure.USART_StopBits = USART_StopBits_1;//
- USART_InitStructure.USART_Parity = USART_Parity_No;//
- USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//
- USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //
- USART_Init(USART1, &USART_InitStructure); //
- USART_ITConfig(USART1, USART_IT_RXNE , ENABLE);//开启中断
- USART_Cmd(USART1, ENABLE);
