好用的固件
- #include "Arduino.h"
- #include "config.h"
- #include "def.h"
- #include "types.h"
- #include "MultiWii.h"
- #include "IMU.h"
- #include "Sensors.h"
- void getEstimatedAttitude();
- void computeIMU () {
- uint8_t axis;
- static int16_t gyroADCprevious[3] = {0,0,0};
- int16_t gyroADCp[3];
- int16_t gyroADCinter[3];
- static uint32_t timeInterleave = 0;
- //we separate the 2 situations because reading gyro values with a gyro only setup can be acchieved at a higher rate
- //gyro+nunchuk: we must wait for a quite high delay betwwen 2 reads to get both WM+ and Nunchuk data. It works with 3ms
- //gyro only: the delay to read 2 consecutive values can be reduced to only 0.65ms
- #if defined(NUNCHUCK)
- annexCode();
- while((uint16_t)(micros()-timeInterleave)<INTERLEAVING_DELAY) ; //interleaving delay between 2 consecutive reads
- timeInterleave=micros();
- ACC_getADC();
- getEstimatedAttitude(); // computation time must last less than one interleaving delay
- f.NUNCHUKDATA = 1;
- while(f.NUNCHUKDATA) ACC_getADC(); // For this interleaving reading, we must have a gyro update at this point (less delay)
- for (axis = 0; axis < 3; axis++) {
- // empirical, we take a weighted value of the current and the previous values
- // /4 is to average 4 values, note: overflow is not possible for WMP gyro here
- imu.gyroData[axis] = (imu.gyroADC[axis]*3+gyroADCprevious[axis])>>2;
- gyroADCprevious[axis] = imu.gyroADC[axis];
- #else
- #if ACC
- ACC_getADC();
- #endif
- #if GYRO
- Gyro_getADC();
- #endif
- gyroADCp[axis] = imu.gyroADC[axis];
- annexCode();
- uint8_t t=0;
- while((uint16_t)(micros()-timeInterleave)<650) t=1; //empirical, interleaving delay between 2 consecutive reads
- if (!t) annex650_overrun_count++;
- #if GYRO
- Gyro_getADC();
- #endif
- gyroADCinter[axis] = imu.gyroADC[axis]+gyroADCp[axis];
- imu.gyroData[axis] = (gyroADCinter[axis]+gyroADCprevious[axis])/3;
- gyroADCprevious[axis] = gyroADCinter[axis]>>1;
- if (!ACC) imu.accADC[axis]=0;
- #endif
- #if defined(GYRO_SMOOTHING)
- static int16_t gyroSmooth[3] = {0,0,0};
- imu.gyroData[axis] = (int16_t) ( ( (int32_t)((int32_t)gyroSmooth[axis] * (conf.Smoothing[axis]-1) )+imu.gyroData[axis]+1 ) / conf.Smoothing[axis]);
- gyroSmooth[axis] = imu.gyroData[axis];
- #elif defined(TRI)
- static int16_t gyroYawSmooth = 0;
- imu.gyroData[YAW] = (gyroYawSmooth*2+imu.gyroData[YAW])/3;
- gyroYawSmooth = imu.gyroData[YAW];
- #endif
- // Simplified IMU based on "Complementary Filter"
- // Inspired by http://starlino.com/imu_guide.html
- // adapted by ziss_dm : http://www.multiwii.com/forum/viewtopic.php?f=8&t=198
- // The following ideas was used in this project:
- // 1) Rotation matrix: http://en.wikipedia.org/wiki/Rotation_matrix
- // 2) Small-angle approximation: http://en.wikipedia.org/wiki/Small-angle_approximation
- // 3) C. Hastings approximation for atan2()
- // 4) Optimization tricks: http://www.hackersdelight.org/
- // Currently Magnetometer uses separate CF which is used only
- // for heading approximation.
- //****** advanced users settings *******************
- /* Set the Low Pass Filter factor for ACC
- Increasing this value would reduce ACC noise (visible in GUI), but would increase ACC lag time
- Comment this if you do not want filter at all.
- unit = n power of 2 */
- // this one is also used for ALT HOLD calculation, should not be changed
- #ifndef ACC_LPF_FACTOR
- #define ACC_LPF_FACTOR 4 // that means a LPF of 16
- #endif
- /* Set the Gyro Weight for Gyro/Acc complementary filter
- Increasing this value would reduce and delay Acc influence on the output of the filter*/
- #ifndef GYR_CMPF_FACTOR
- #define GYR_CMPF_FACTOR 600
- #endif
- /* Set the Gyro Weight for Gyro/Magnetometer complementary filter
- Increasing this value would reduce and delay Magnetometer influence on the output of the filter*/
- #define GYR_CMPFM_FACTOR 250
- //****** end of advanced users settings *************
- #define INV_GYR_CMPF_FACTOR (1.0f / (GYR_CMPF_FACTOR + 1.0f))
- #define INV_GYR_CMPFM_FACTOR (1.0f / (GYR_CMPFM_FACTOR + 1.0f))
- typedef struct fp_vector {
- float X,Y,Z;
- } t_fp_vector_def;
- typedef union {
- float A[3];
- t_fp_vector_def V;
- } t_fp_vector;
- typedef struct int32_t_vector {
- int32_t X,Y,Z;
- } t_int32_t_vector_def;
- typedef union {
- int32_t A[3];
- t_int32_t_vector_def V;
- } t_int32_t_vector;
- int16_t _atan2(int32_t y, int32_t x){
- float z = (float)y / x;
- int16_t a;
- if ( abs(y) < abs(x) ){
- a = 573 * z / (1.0f + 0.28f * z * z);
- if (x<0) {
- if (y<0) a -= 1800;
- else a += 1800;
- } else {
- a = 900 - 573 * z / (z * z + 0.28f);
- return a;
- float InvSqrt (float x){
- union{
- int32_t i;
- float f;
- } conv;
- conv.f = x;
- conv.i = 0x5f3759df - (conv.i >> 1);
- return 0.5f * conv.f * (3.0f - x * conv.f * conv.f);
- // Rotate Estimated vector(s) with small angle approximation, according to the gyro data
- void rotateV(struct fp_vector *v,float* delta) {
- fp_vector v_tmp = *v;
- v->Z -= delta[ROLL] * v_tmp.X + delta[PITCH] * v_tmp.Y;
- v->X += delta[ROLL] * v_tmp.Z - delta[YAW] * v_tmp.Y;
- v->Y += delta[PITCH] * v_tmp.Z + delta[YAW] * v_tmp.X;
- static int32_t accLPF32[3] = {0, 0, 1};
- static float invG; // 1/|G|
- static t_fp_vector EstG;
- static t_int32_t_vector EstG32;
- #if MAG
- static t_int32_t_vector EstM32;
- static t_fp_vector EstM;
- #endif
- void getEstimatedAttitude(){
- uint8_t axis;
- int32_t accMag = 0;
- float scale, deltaGyroAngle[3];
- uint8_t validAcc;
- static uint16_t previousT;
- uint16_t currentT = micros();
- scale = (currentT - previousT) * GYRO_SCALE; // GYRO_SCALE unit: radian/microsecond
- previousT = currentT;
- // Initialization
- deltaGyroAngle[axis] = imu.gyroADC[axis] * scale; // radian
- accLPF32[axis] -= accLPF32[axis]>>ACC_LPF_FACTOR;
- accLPF32[axis] += imu.accADC[axis];
- imu.accSmooth[axis] = accLPF32[axis]>>ACC_LPF_FACTOR;
- accMag += (int32_t)imu.accSmooth[axis]*imu.accSmooth[axis] ;
- rotateV(&EstG.V,deltaGyroAngle);
- #if MAG
- rotateV(&EstM.V,deltaGyroAngle);
- #endif
- accMag = accMag*100/((int32_t)ACC_1G*ACC_1G);
- validAcc = 72 < (uint16_t)accMag && (uint16_t)accMag < 133;
- // Apply complimentary filter (Gyro drift correction)
- // If accel magnitude >1.15G or <0.85G and ACC vector outside of the limit range => we neutralize the effect of accelerometers in the angle estimation.
- // To do that, we just skip filter, as EstV already rotated by Gyro
- if ( validAcc )
- EstG.A[axis] = (EstG.A[axis] * GYR_CMPF_FACTOR + imu.accSmooth[axis]) * INV_GYR_CMPF_FACTOR;
- EstG32.A[axis] = EstG.A[axis]; //int32_t cross calculation is a little bit faster than float
- #if MAG
- EstM.A[axis] = (EstM.A[axis] * GYR_CMPFM_FACTOR + imu.magADC[axis]) * INV_GYR_CMPFM_FACTOR;
- EstM32.A[axis] = EstM.A[axis];
- #endif
- if ((int16_t)EstG32.A[2] > ACCZ_25deg)
- f.SMALL_ANGLES_25 = 1;
- else
- f.SMALL_ANGLES_25 = 0;
- // Attitude of the estimated vector
- int32_t sqGX_sqGZ = sq(EstG32.V.X) + sq(EstG32.V.Z);
- invG = InvSqrt(sqGX_sqGZ + sq(EstG32.V.Y));
- att.angle[ROLL] = _atan2(EstG32.V.X , EstG32.V.Z);
- att.angle[PITCH] = _atan2(EstG32.V.Y , InvSqrt(sqGX_sqGZ)*sqGX_sqGZ);
- #if MAG
- att.heading = _atan2(
- EstM32.V.Z * EstG32.V.X - EstM32.V.X * EstG32.V.Z,
- (EstM.V.Y * sqGX_sqGZ - (EstM32.V.X * EstG32.V.X + EstM32.V.Z * EstG32.V.Z) * EstG.V.Y)*invG );
- att.heading += conf.mag_declination; // Set from GUI
- att.heading /= 10;
- #endif
- #if defined(THROTTLE_ANGLE_CORRECTION)
- cosZ = EstG.V.Z / ACC_1G * 100.0f; // cos(angleZ) * 100
- throttleAngleCorrection = THROTTLE_ANGLE_CORRECTION * constrain(100 - cosZ, 0, 100) >>3; // 16 bit ok: 200*150 = 30000
- #endif
- #define UPDATE_INTERVAL 25000 // 40hz update rate (20hz LPF on acc)
- #define BARO_TAB_SIZE 21
- #define ACC_Z_DEADBAND (ACC_1G>>5) // was 40 instead of 32 now
- #define applyDeadband(value, deadband) \
- if(abs(value) < deadband) { \
- value = 0; \
- } else if(value > 0){ \
- value -= deadband; \
- } else if(value < 0){ \
- value += deadband; \
- #if BARO
- uint8_t getEstimatedAltitude(){
- int32_t BaroAlt;
- static float baroGroundTemperatureScale,logBaroGroundPressureSum;
- static float vel = 0.0f;
- uint16_t dTime;
- dTime = currentT - previousT;
- if (dTime < UPDATE_INTERVAL) return 0;
- if(calibratingB > 0) {
- logBaroGroundPressureSum = log(baroPressureSum);
- baroGroundTemperatureScale = (baroTemperature + 27315) * 29.271267f;
- calibratingB--;
- // baroGroundPressureSum is not supposed to be 0 here
- // see: https://code.google.com/p/ardupilot-mega/source/browse/libraries/AP_Baro/AP_Baro.cpp
- BaroAlt = ( logBaroGroundPressureSum - log(baroPressureSum) ) * baroGroundTemperatureScale;
- alt.EstAlt = (alt.EstAlt * 6 + BaroAlt * 2) >> 3; // additional LPF to reduce baro noise (faster by 30 ?s)
- #if (defined(VARIOMETER) && (VARIOMETER != 2)) || !defined(SUPPRESS_BARO_ALTHOLD)
- //P
- int16_t error16 = constrain(AltHold - alt.EstAlt, -300, 300);
- applyDeadband(error16, 10); //remove small P parametr to reduce noise near zero position
- BaroPID = constrain((conf.pid[PIDALT].P8 * error16 >>7), -150, +150);
- //I
- errorAltitudeI += conf.pid[PIDALT].I8 * error16 >>6;
- errorAltitudeI = constrain(errorAltitudeI,-30000,30000);
- BaroPID += errorAltitudeI>>9; //I in range +/-60
全部资料51hei下载地址:
MultiWii.zip
(152.07 KB, 下载次数: 59)
